Headlights blink with turn signal
Got a video of it? Are you sure it's your headlights and not your daytime running light or something? Sounds like someone previously hacked up your lights.
I dont have daytime running lights. All of my lights flash with blinker, headlights, back lights, and cluster lights. Wierd thing is its only when car is in drive, when i put it in park it doesnt do it. Ill try and post a video later, and i dont think someone hacked it up
wtf.... gonna need to see this
https://acurazine.com/forums/first-g...signal-466005/
Sounds similar to this here
namely this post:
namely this post:
Hondas and Acuras use what is called a "multi-combo switch." This switch controls your turn signal indicators, headlights and dash lights. when this switch fails, any number of problems can occure. from headlights and signals lamps that fail to turn on, to what you are experiencing. I would suggest that you have this replaced. It is a tricky bit of work, and I would not suggest you try doing it yourself. The procedure for replacing this switch requires the removal of the steering wheel, and airbag mechanism. This can be potentially dangerouse to a novice. Your dealer or a good repair shop that specializes in Acura/Honda should be located and I would imagine the work should not take longer than an hour or two. Good luck.
You can expect the switch to be at least $100 used and maybe $250 new. Not including labor for installation.
Peace, Love and Acura...
That sounds like the problem im having! Its been pissing me off lately i dont even use blinkers anymore at night time lol and im not trying to get pulled over for that reason.
http://www.autopride.com/catalog-1/vehicle/acura/1998/cl/_/_/switch-multi-function-and-combinati
This look like the part? I appreciate the fast response
check out oemacuraparts.com for the part.
Coo thanks
acura/cl-coupe/35254sy8a01/1998-year/pre3-0-trim/4-speed-automatic-engine/electrical-exhaust-heater-fuel-cat/combination-switch-2-scat/?part_name=wire-assy-combination-switch
Im assuming its this part then.
