Headlight Observation
My alarm went off this morning... I ran outside, no one was there so I disarmed it and checked for damage. Nothing.
So I wanted to make sure my HIDs were still working, so I started the car and turned them on. Sure enough, the right lamp was out.
Here's where it got interesting, the left lamp was still on, but so were my high beams - but at low power. If I flicked the high switch, the left one came on at full power, the right one went off.
Long story short, I guess the ballast went bad from being turned on/off when the alarm went off and blew the fuse under the hood and kept blowing new ones. I replaced the fuse, and the headlights are back to normal (though I'm stuck with halogens again for now.)
I just thought it was strange because I've blown headlight bulbs several times and haven't had the high beams come on at reduced power. However, if the fuse is blown/removed, they will. Now I need to figure out how to utilize that "feature" for DRLs.
6spd FTW
Right, problem is that if you put it right in series with the bulb you need higher wattage resistors since they will be taking part of the load. Engine bay fires are no good. I will bring the haynes manual with me and see what causes that dimming to happen.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
That happened to me with my 4runner
happened to my cl when i bought it, it was wierd, lights were all messed up. One of my buddies, who's rly good in electric problems and so on, he just switch the computer to an accord one, and it worked good after
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
