fromt engine mount
fromt engine mount
replaced the front engine mount today and added prothane inserts but broke one of the bolts to the engine, is it gonna be ok with 2 bolts for now. im gonna try to see if some shop can fix the broken one. btw, do they have inserts for the rear mounts? i(some shop) will replace the front sway bar bushings maybe next week when the parts arrive.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Blenz
It'll be fine with just two bolts until you get it fixed. And yes they do make inserts for the rear mounts
finally got the bolt fixed on the front engine mount, wasnt able to get a pic but here are some pics of other install.
a lot more vibration now tho with the engine mount insert; just a couple of best upgrade recommended for suspension are front endlinks and rear sway bar.
that was tanabe, the tie bar didnt feel anything at all when i had that installed as well as for the upper rear. i suggest upgrade the rear sway. the mount insert and rear sway were straightforward, easy install. the bushings, had them done at the shop since i broke one of the bolts on the mount insert and had them fix it.
I felt a bit more tail happiness when I strapped on the rear upper bar, but now I just have the front and a 100lb woofer box on the rear axle...... looking at geting a rear lower tie bar though.... sways can come later
(Mid-Atlantic)
(Mid-Atlantic)
Gotta love polyruethayne
sockr1
10-01-2015 01:31 AM
