Fix it, Fix it, Fix it!
ur as welcome as cancer
I take hard turns usually and recently my car has started STAYING in the position I'm turning. I know if I turn the other way that I'll overcorrect myself, so I don't want to do that. It happened yesterday, but I thought that was just because it was wet outside, but it did it again today. It feels like the wheel suddenly tightens up and locks. WTF?!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by 5-speed
check power steering fluid
Nom Nom Nom Nom
Sounds liek your power steering doesn't have enough pressure for you to easily turn the wheel back and forth. If not, get it checked cuz your rack and pinion might be jacked up
4x4- fat chicks cant jump
its the type of steering system that it is our cls. basically, its a bar with teeth that is moved left and right with a pinion gear attached to the steering shaft. so its pretty much your steering box. no more hard cornering
Originally Posted by DaInFaMMuS1
sorry to thread hijack...but wtf is in your avatar swervinCL?? i cant figure it out. looks like a snake swallowed something
1 Post
yeah it's a snake that ate a "ewe" (sheep).
I don't understand what you mean by "my car has started STAYING in the position I'm turning."
does this mean that you can't turn the steering wheel back to center, or does it mean your tires break loose and you "drift" the corner?
1 Post
Originally Posted by 972xghost
o man a girl taking hard turns all the time, never heard of that before. j/k lol
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by ghost_masterCL
it's a girl? I thought it was a guy with a wig in that small ass pic.
Nom Nom Nom Nom
Only when your stopped. When your going, you wont have any problems turning the wheels because the car is in motion...
<~~~ Learned how to drive stick on an RX-7 with no power steering... Damnit I miss that car. I will get one.. I will I will I will.
(Mid-Atlantic)
(Mid-Atlantic)
yea but isnt it harder to drive a car without power steering but came stock with power steering then a car that never came with it???
1 Post
I drift the corners
if you're tires are losing traction when they didnt' before, then maybe they are just gettign low on tread. are you letting off of hte gas at all? that'll cause oversteer if you take the corner with high throttle, then let off mid turn.
SidhuSaaB
05-30-2020 12:40 AM
