Do all your lights flicker when the turn-signal is on?
Do your head-lights, instrument light, etc. flicker when your turn-signal is on, while you're stopped at a light idling? Mine does, and I just installed a new Die Hard battery in it this past Spring. I hope the alternator isn't going bad...but it's been doing that for a while now. I'm sure if it's the alternator not charging, my battery would of been dead a long time ago. Some sort of regulator perhaps?
Gimmie my points Biatch!
Re: Do all your lights flicker when the turn-signal is on?
its not cuz of acura....a lot of car doesn't that when it get to the point. I think Autozone will check out if ur alternator is putting out enought power. a lot of time having a powerful sound system can cause the alternator to be bad too....i'll run...but its just something small that's probablly mess up.
Old Man
I have a friend who had the same problem. We found that his positive cable was so corroded it could have fallen off at anytime. After we replaced it all the flickering, dimming. and the idle fluctuations went away.
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
