Cylinder misfires all around - help needed
Old 01-27-2007, 03:41 PM
twizy's Avatar
Car: 99 2.3L 5-speed with 121k
A week ago, while driving on the highway the check engine light starts flashing. I goto autozone and get the following codes:
P0300
P0301
P0303
P1399
Clearly there is massive misfiring going on with the engine. I replaced the plugs and wires a month ago and car was running fine until this happened.
Other symptoms/observations:
- The day the check engine started flashing it was extremely cold, like maybe 20 farenheit.
- When I come to a stop and push the clutch down, the car will stall everytime unless I give the car some gas.
- When I stall out and crank the car to restart, the crank takes awhile to restart.
- Cars idle is choppy and inconsistent.
- Car cannot accelerate smoothly. The car shakes, stumbles and shudders extremely hard when I attempt to accelerate.
Soooo, any suggestions or recommendations on where should I start to try and figure out this headache?
Old 01-27-2007, 03:43 PM
where is....
AznX TL's Avatar
check your distributor
Old 01-27-2007, 03:44 PM
where is....
AznX TL's Avatar
if i were you i'd take it to a shop and get it scanned
Old 01-29-2007, 09:15 PM
twizy's Avatar
help wanted
Old 01-29-2007, 09:33 PM
732xghost's Avatar
buy my F23!!!!
Old 01-29-2007, 09:58 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
Originally Posted by 972xghost
buy my F23!!!!
you just couldn't resist could u?
Old 01-29-2007, 10:06 PM
732xghost's Avatar
nope.
Old 01-30-2007, 09:25 AM
Matt
STL+3.0CL's Avatar
Twizy... any news or an update on this? Did you take it to the shop?
Old 01-30-2007, 04:34 PM
twizy's Avatar
i am going to replace the distributor cap and rotor this weekend. i really hope it is that simple, but deep down i'm thinking its something more serious. ideas are still welcome! thanks
Old 01-30-2007, 08:02 PM
(Mid-Atlantic)
While you're replacing your dist, put your wires in the right order, they may be out of order, otherwise, could be your timing is off
Old 01-30-2007, 08:57 PM
One custom CL
SupraManAG's Avatar
really sounds like the cap is worn yet those new wires seem a lil fishy to me
Old 01-31-2007, 07:26 AM
twizy's Avatar
if after cap and rotor, car still runs bad, i will put in the old wires and try that. if it still runs crappy after all that, i will go ahead and scrap this damn engine and get an H22. this engine is giving me way too many headaches and i'm unwilling to pour anymore $$ into it. i already need new rings which will run $1500 for parts/labor. are there any CLs near metro NY that have an H22? i'd love to see one in person before i take the plunge. its going to cost me 5k for the swap out the door. that includes complete engine, tranny, labor, and maintenance.
Old 01-31-2007, 08:35 AM
732xghost's Avatar
your from NY metro??
well theres SupramanAG and possibly a few others that we dont even know about. and theres ALOT of accords.
but my offer is still on the table, 500 bills for a complete F23A1 swap. but if you have the money i would go with the H22A.
Old 01-31-2007, 08:36 AM
(Mid-Atlantic)
If you put new wires in, chances are you put the wires in the wrong order
Old 01-31-2007, 08:51 AM
One custom CL
SupraManAG's Avatar
dont come to me
ill make u get an H22
Old 01-31-2007, 12:57 PM
twizy's Avatar
97blackackcl: its definitely not the wire order since i was driving it on the highway fine when the CEL came on. instead it could be that the wires are faulty or something.
supraman, if you have some free time would it be ok if i took a look at your h22? i wouldn't mind driving out to wherever you are. i really have to be sure its worth it before i spend 5 gs on a swap.
Old 01-31-2007, 01:14 PM
where is....
AznX TL's Avatar
complete?
Old 01-31-2007, 01:15 PM
(Mid-Atlantic)
Check to make sure all your wires are tight and snapped onto the plugs all the way
Old 01-31-2007, 02:48 PM
732xghost's Avatar
Originally Posted by AznX TL
complete?
well as of now, but my job (Honda) might need it so, im gonna sell them the head if they definitly need it.
so if i can sell the head for like $100 to them, then it will be easier to sell the rest of the swap on honda-tech.com because no one wants the complete swap, only the block and tranny.
Old 01-31-2007, 05:16 PM
ghost_masterCL's Avatar
sounds like a fuel delivery issue.
Old 01-31-2007, 05:58 PM
One custom CL
SupraManAG's Avatar
Its not 5G. More like 2.5-3G. PM me where u comin from n Ill let u know.
Old 01-31-2007, 06:12 PM
twizy's Avatar
i think the breakdown goes like this (please let me know if this doesn't sound right):
2.5 for complete engine/tranny
1.5 for labor
1 for miscellaneous (timing belt, clutch, hoses etc)
Old 01-31-2007, 06:14 PM
One custom CL
SupraManAG's Avatar
no
2nchange for engine plus tranny. I think you can do better then 2.5.
a lil over 500 for labor
n maybe 300 for the misc
Old 01-31-2007, 06:18 PM
twizy's Avatar
wow if i could get everything done right for 3g, i would do it IMMEDIATELY. i just don't know a place i can trust to do it right for that price. where'd u get yours done?
Old 01-31-2007, 08:01 PM
One custom CL
SupraManAG's Avatar
pm me n we talk about it
where u comin from
Old 02-09-2007, 07:50 PM
twizy's Avatar
Well, got the cap and rotor replaced today and car is still having the same problem. I'm starting to run out of ideas here, only thing left is fuel filter or fuel pump. Can lack of fuel delivery cause the cylinders to misfire?
Old 02-24-2007, 02:06 PM
twizy's Avatar
Well, I've ran out of ideas. I've replaced wires, plugs, rotor, cap, coil, fuel filter and the car is still misfiring. Does anyone know what code P1399 is? It wasn't on the list of codes in the FAQ. I'm hoping it is the reason behind it all.
EE4Life
04-01-2024 09:42 AM
notfast
1/2G MDX (2001-2013)
03-28-2023 08:10 AM
k6biv
09-10-2015 06:37 PM
BC01191980
09-07-2015 08:14 PM
HOWELLiNC
09-05-2015 03:09 AM
Quick Reply: Cylinder misfires all around - help needed
