creaking sound from front wheels..
how handsome I am
Well, as I make slow turns or U-turns, I can hear a slow creaking sound coming from my front wheels... any idea what this could be?
-Alex
-Alex
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Alex, do you hear the creaking when you go over bumps too, or just turns?
I'm a llama :(
It happens when you slowly accelerate while turning? Yeah, same here. There's a service bulletin about it. Although I think mine went away after I lowered my car.
nippon_wa 2.0
i hear some sound too.. i thought it was because of my springs and stock shocks.. so i changed to TEIN SS. but i still hear sound... maybe more worse..
and i went to shop to ask.. and all they said were "because u droppd ur car"
i hear it when i go over bump or turns.. only front wheels tho.. especially front left..
It was happenin to me and had it fixed yesterday, it was my bushings. I had them all replaced for free. The shop manager found a way to put the bushings under a warranty.
C/V joints, happened to me on my accord, not too expensive to fix if u go to autozone and get a rebuilt one, then they give u most of ur money back when you take your old one back to them.
how handsome I am
I bought the car used... it only has 60,6xx. think i can get a warranty change straight from a dealer down here or am I buying some new pieces?
-Alex
-Alex
nippon_wa 2.0
xxx only bushing? i asked my shop and they said it would be lke $200 plus parts-_-;
and.. what's the parts number for bushing? is there anything i should change together?
roomate has a CL too
yeah might be CV happens to mine... my passenger side front suspension is all fucked up not to mention stupid ass pot holes bent a rim and have been riding on the spare for a month.
DOOKS of hazard!!!!
upper ball joints....everything is suspect when you lower the car...but for me it was definetly the upper ball joints. cv boots mighta blown and sand and grit coulda gotten into your cv axles....that might be the noise....jack up the car and look at all your bushings etc....take a pic and post and we'll tell ya what it is
nippon_wa 2.0
i think mine is because of bushing.. if so, what's the part numbers? and what's for the upper ball joints if it's cuz of that? yeah ur right, since my car is lowered, don't know which it is..
2.2 auto and coping
about the creaking sound...does it sound like a scraping sound....duh.....
check to see if there is any wear or marks...
push down on the car to see if it makes the noise...try to pinpoint the noise with a friend
just some Q's to help...
u still gonna sell the trunk setup? oh yea i got 3rd in a sound bass off 2 weeks ago. not too bad huh.. ne ways hit me up..
oh yea back to the subject, mine started bout a week after i dropped my car. it was the strut. but it only did it going over bumps. actually it still does it cause i havent replaced them yet. really sucks to be po pimpin.
DOOKS of hazard!!!!
thats awsome will. im still over here in rome....and ya, im savin the trunk for ya. hat subs and amp are you rockin to be gettin 3rd in some show!?? later`
RODDYS
Is it popping or creaking. If it popping then its your control arms. If its creaking it could be control arm bushings, leaking or bad shock/strut, or if you have a camber kit I hear that that make noise.
nippon_wa 2.0
so, when u hear creaking sounds, it's either control arm bushings or upper ball joints? what are they? where are they? and how much are they? and where can i get them
dang.. i really hate hearing creaking sound every time i drive.. it drives me crazy!!
actually, i hear more after i changed my suspension from neuspeed to tein ss..
nippon_wa 2.0
okay.. where is it?
http://www.acuraautomotiveparts.org/...A4AT&catcgry5=
what's the bushing and upper ball joints?
a jawful a somethin awful
check this page
http://www.acuraautomotiveparts.org/...prddisplay.jsp
nippon_wa 2.0
Originally Posted by sumdumguy
check this page
ok smart ass....go to select component, and select front lower arm. when you select that
all info including bushings will apear.
I didn't know that site wouldn't give a direct link to that page
I'm a llama :(
Service Bulletins
TSB Number Issue Date TSB Title 04-004 FEB 04 Computers/Controls - HIM Module Updating
01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
03-006 MAR 03 Engine Controls - Idle Speed Inspection
03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
99-001 APR 02 Body - Power Window is Inoperative
01-037 APR 02 Engine - Coolant Leak From Engine Block
02-005 FEB 02 Emissions - EVAP System Testing and Diagnostics
00-037 AUG 01 Brake Disc - Refinishing Guidelines
00-039 DEC 00 Electrical - Wiring Terminal Replacement Instructions
87-015 JUL 00 Audio System - Warranty Non Warranty Exchange/Repair
00-008 MAR 00 Torque Converter Oil Seal Installation Tool
99-050 DEC 99 Cruise Control - Input Test Revision
98-011 NOV 99 Computers/Controls - Aftermarket OBD II Tester/Software
86-014 JUN 99 Brakes - Brake Disc Refinishing Guidelines
99-022 MAY 99 Front Balancer Shaft Oil Seal Installation Tool
90-007 MAY 99 Steering Wheel Off-Center Adjustment At TQI
99-011 MAR 99 Remote Audio Switches - Improper Operation
92-009 FEB 99 Drivetrain - Creaking Noise While Turning
99-005 JAN 99 Paint - Codes/Cross References
98-004 APR 98 Audio Unit Anti-Theft Labels
98-005 APR 98 CV Joint Boots - New Band & Tool
90-009 DEC 97 A/T - Warranty Exchange Program
87-015 NOV 97 Audio Unit In-Warranty Exchange/Out-of Warranty Repair.
90-010 OCT 97 Audio Unit Error Codes
86-014 MAY 97 Brake Disc Refinishing.
97-013 MAY 97 New Halogen Leak Detector
97-010 MAR 97 New Fuel Pressure Gauge and Replacement Parts
97-009 MAR 97 A/T Oil Pressure Testing Tools Update
97-001 FEB 97 SRS - Do it Yourself (Owner) 10 Year Inspection
96-039 SEP 96 Power Steering Pressure Gauge
nippon_wa 2.0
didn't wanna make a thread again..so...
well.. i was gonna buy those things from that website..
but.. what i'm wondering is that...
i have a TEIN SS setup which is coilovers w/ shocks..
then, do those things(stock bushings) still fit w/ tein ss setup??
or should i order bushings from tein?
in the werks
nippon_wa 2.0
Originally Posted by bravo97cl
mine was making the same sound, my mechanic said it was the bushing i think that he just flipped it over and it stopped. not exactly sure if thats what he did but it might be worth a try.
so.. changing STOCK bushing is kinda different than mine.. (cuz i have aftermarket shocks..tein ss)
i wanted to know if stock bushings would also fit in tein ss setup..
Originally Posted by DivineCL
C/V Joints
A-CL Member
I was having squeaks from the front end. I heard it was everything from bushings to CV joints to ball joints. Turns out my Koni's blew prematurely. Got me a new set, and noise went away. 3 weeks later, a new sound starts - it's the wear sensors in the front brakes. I shouldn't complain, my oem pads lasted 80,000 miles.
