Notices
couple things to help your car run better
Old 08-26-2006, 01:30 PM
Registered Member
mixxxwell's Avatar
heres a couple things u guys can do to help your car run a little better.
honda/acura recommends a valve adjust every3-4 oil changes
change your oil every 2500-3000 miles
change your transmission fluid atleast once year
if you have vtec i recommend using chevron with techron and pumpin 89 or 91 octane. it has been proven that techron has additives that will clean the corrosion on your valves.
also a good fuel system flush (seamfoam) is recmonded atleast once a year
a coolant flush is recomended every 2 years.
do these couple things and your car will run fine
mixxxwell is offline
Old 08-26-2006, 02:22 PM
seafoam was awsome !!! Aside from destroying the Ozone layer, Killing indigenous wild life its works fucking great !!!
FULLRACE is offline
Old 08-26-2006, 02:27 PM
...is now Carbon Fiber'd
hybridnrg's Avatar
lol. yeah i need to do this.
hybridnrg is offline
Old 08-26-2006, 02:28 PM
hybridnrg's Avatar
i am soo anal about the trans that i change the trans oil every other time i change the motor oil.
asianspec's Avatar
asianspec is offline
asianspec's Avatar
i need to change my tranny oil soon too. like next week
Old 08-26-2006, 02:32 PM
Ciao Pho Eva eva
Palayah8ta's Avatar
is there a valve ajustment DIY?
Palayah8ta is offline
Old 08-26-2006, 04:23 PM
One custom CL
SupraManAG's Avatar
i just bought 3 cans of sea foam
based on the instruction they seem to work miracles
i used some to clean out my plugs and shiiiiiit
it works fucking great
SupraManAG is offline
Old 08-26-2006, 06:26 PM
Who the F*** is Chucky?
bostonroads's Avatar
sea foam sounds pretty good...
i was reading the instructions of where to add it tho...2 questions:
1. The oilcrank is just where you put oil into the engine correct?
2. Does anyone know exactly whree to put it into the carburator because they listed the vacuum line and one or two other areas...i have no idea
gas tank is easy enough haha
bostonroads is offline
Old 08-26-2006, 06:54 PM
Fast Foward>Rewind>Play
Orlando3.0's Avatar
i just my tranny rebuilt. this coming up weekend, this is my to do list:
Oil Change
Transmission Cooler
Sea Foam
Fuel Filter Replacement
Custom Cold Air Intake.
Orlando3.0 is offline
Old 08-26-2006, 08:35 PM
Registered Member
ingsoc747's Avatar
I would rather get it done at Honda, but here is a DIY
https://acurazine.com/forums/showthr...lve+adjustment
(search function is a wonderful thing... )
ingsoc747 is offline
Old 08-27-2006, 12:14 AM
look on your intake manifold........find a vacume line ( theres a couple ) pull it off a line oposite the Intake manifold ( the big silver thingy your CAI or airbox is attached to ) and pour the seafoam into the cap/small cup...then stick the little hose into the cup and watch it suck it down. You can pull any of the vacume lines...doesnt matter as long as its attached to the IM in some way.
FULLRACE is offline
Old 08-27-2006, 01:42 AM
Registered Member
zoltar's Avatar
how much do acura dealers charge for a valve adjustment
zoltar is offline
Old 08-27-2006, 05:12 AM
Registered Member
mixxxwell's Avatar
anywhere from 100-200 i can have it done for $40
Old 08-27-2006, 07:20 AM
asianspec's Avatar
but the car has to be cooled down before performing it.
Old 04-22-2019, 12:08 PM
Registered Member
Ok so whats the clearance on the valves anyone know, I have only been able to find the 2nd n 3rd gen specs, I have a first gen CL but i dont know
Dario Galvan is offline
kuzdu
Fifth Generation TLX (2015+)
09-10-2015 08:42 PM
jfman55
Third Generation TL (2004-2008)
27
09-05-2015 02:55 PM
fallacy
Second Generation TSX Discussion (2009-2014)
09-04-2015 10:15 AM
NSolace
09-03-2015 08:02 PM
ptbarnett
Third Generation RLX (2013+)
08-30-2015 12:39 PM
Quick Reply: couple things to help your car run better
