couple things to help your car run better
heres a couple things u guys can do to help your car run a little better.
honda/acura recommends a valve adjust every3-4 oil changes change your oil every 2500-3000 miles change your transmission fluid atleast once year if you have vtec i recommend using chevron with techron and pumpin 89 or 91 octane. it has been proven that techron has additives that will clean the corrosion on your valves. also a good fuel system flush (seamfoam) is recmonded atleast once a year a coolant flush is recomended every 2 years. do these couple things and your car will run fine |
seafoam was awsome !!! Aside from destroying the Ozone layer, Killing indigenous wild life its works fucking great !!! :thumbsup:
lol. yeah i need to do this. |
i am soo anal about the trans that i change the trans oil every other time i change the motor oil.
:werd:
i need to change my tranny oil soon too. like next week
is there a valve ajustment DIY?
i just bought 3 cans of sea foam
based on the instruction they seem to work miracles i used some to clean out my plugs and shiiiiiit it works fucking great |
sea foam sounds pretty good...
i was reading the instructions of where to add it tho...2 questions: 1. The oilcrank is just where you put oil into the engine correct? 2. Does anyone know exactly whree to put it into the carburator because they listed the vacuum line and one or two other areas...i have no idea gas tank is easy enough haha |
i just my tranny rebuilt. this coming up weekend, this is my to do list:
Oil Change Transmission Cooler Sea Foam Fuel Filter Replacement Custom Cold Air Intake. :thumbsup: |
https://acurazine.com/forums/showthr...lve+adjustment (search function is a wonderful thing... :tomato: ) |
anywhere from 100-200 i can have it done for $40 :thumbsup:
Ok so whats the clearance on the valves anyone know, I have only been able to find the 2nd n 3rd gen specs, I have a first gen CL but i dont know
