check engine
Old 03-25-2007, 08:56 AM
lbrasi293's Avatar
check engine
Hey Guys/Gals
Last night I was driving and all of a sudden my "check engine" light came on. So this morning I did the paper clip trick and it came back with error code 12. Can only confirm this as
P1491
EGR Valve Lift Insufficient Detected
P1498
EGR Valve Lift Sensor High Voltage
I am not sure if that is right, how much would this cost to fix.
lbrasi293 is offline
Old 03-25-2007, 09:07 AM
where is....
AznX TL's Avatar
what yr is your cl?
97's have a 14yr, 150,000 emissions warranty for the egr thing.
im not sure what it is for the 98-99 though.
AznX TL is offline
Old 03-25-2007, 09:09 AM
lbrasi293's Avatar
Its a 98' with about 125K miles. Maybe I should look into it.
Old 03-25-2007, 09:52 AM
lbrasi293's Avatar
If my car does not fall under extended warranty, any idea on how much this would cost to fix?
Old 03-25-2007, 10:28 AM
Turtle Charged, Biotcch!!
Sleep_DEPRIVED_Sleeper's Avatar
pm TexasHonda, he oughta know how much it costs...
also, there's a DIY EGR valve cleaning somewhere, search for EGR valve and you should see it...
Sleep_DEPRIVED_Sleeper is offline
Old 03-25-2007, 11:03 AM
Bagel Bomber
Mach30SiR's Avatar
http://www.acura-cl.com/forums/showthread.php?t=174570
Read that thread carefully. Its around 250 - 300 for the dealer to fix, but its a real easy fix if you follow the service bulletin that is posted in that thread. PM me if you need more help.
Mach30SiR is offline
Old 03-25-2007, 11:21 AM
lbrasi293's Avatar
I am a complete n00b, this looks like a job I will have to take in for service.
Old 03-26-2007, 09:42 PM
lbrasi293's Avatar
I was able to get my buddy to clean out the EGR valve. The check engine light it off for now
We will see how long it stays off for
Yikes
05-03-2021 04:29 PM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
Billu99tl
09-13-2015 11:30 AM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
Quick Reply: check engine
