car just shuts off
CL-OWniN
car just shuts off
First of all my check engine light is on and i dont know what the problem is. Sometimes when i drive my car my car just shuts off. When i try to turn the the car back on, i have to hold the key down in the ignition switch for a little bit. It seems like when i barley the touch the key in the ignition it turns off. Can it it be that I need a new ignition or is there something wrong in the engine such as a clogged fuel filter, or do i need a new fuel pump? what can it be? Can anyone please help me?
ENGAGE MY VTEC BABY!!!!!!
take it to acura there is an ignition recall
do it cause it can cause the car to lock up while driving and cause a possible accident since the car wont start
Former Sponsor
How many miles are on you CL? The ignition tumbler and interlock are on recall and need to be replaced. Hence the car shutting off. But the check engine light won't come on for that fault. The most common Check Engine pop is from the EGR recall. If you're under 80,000 mile that's covered under warranty also. Please register you car at OWNERLINK. You'll find it on Acura's website. Once you've registered you CL with Acura it will show you what recalls are on your ride. And if they've been fixed or not.
Have your rear brake calipers checked as well. Acura knows this problem to strike before that EGR code gets ya. Any probs with your tranny?
CL-OWniN
Originally Posted by Motohip
Tehre's an ignition recall
Former Sponsor
Check your code.
There is a self-diagnostic plug behind your glovebox. It's taped to the round metal brace. It's blue and has two wires. Jump the two wires together with the ignition off. Then turn the ignition to RUN without starting it. Your check engine light will flash the code. I think it flashes long flashes first and short next. Add up the long flashes for your first digit and short for your second digit. This two digit number is your fault code. If you miss it. It will continue flashing the code or codes until you shut the ignition off.
http://www.troublecodes.net/acura/30cl.shtml
Click on the link to reference your code. Use the column labeled MIL.
CL-OWniN
Originally Posted by uncald4
Check your code.
Former Sponsor
Originally Posted by CL4u2NV
would it be better jump it with a paper clip or a wire?
CL-OWniN
I've seen people damage the pins using a paper clip. So be careful if you are using one. I keep a wire terminal fork connector in my glovebox. Use whatever you have man. Just be careful. Did you find the plug?
