Car Inverters-97 CL 3.0
Old 05-14-2015, 12:50 PM
progman2's Avatar
hi Ziners,
I need to get an inverter for powering electronics, etc.
didn't realize there were so many specs to consider, as far as wattage, amperage, etc..
I also learned that apparently even if I get a top line, high wattage inverter, designed to work off 12V cigarette lighter, I'm still limited to the amps the cigarette lighter can handle, which in turn is limited by whether or not the fuse is dedicated to only the lighter, or also handles other draws (radio, internal lights, etc.).
Please advise the fuse's amps (10, 15, 20?) and if is a dedicated fuse or not, and any suggestions for inverter purchase. Thanks much
Old 05-18-2015, 01:26 AM
musiclevelz5's Avatar
If you want to run something more than the cigarette lighter can handle you need to get an inverter that hooks directly up to the battery.
Old 05-18-2015, 01:01 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
The fuse is a 15 I believe, and it's the radio fuse as well
peti1212
ILX
22
01-05-2022 05:14 PM
02-25-2020 09:57 AM
kuzdu
09-10-2015 08:42 PM
jordanboi
09-05-2015 01:33 AM
Mikehxbx
08-31-2015 10:17 PM
Quick Reply: Car Inverters-97 CL 3.0
