can upper ball joint be replaced seperately?
Old 03-15-2009, 08:21 AM
YL Al's Avatar
i have heard two points of view about this ,
one being that on the 1st gen CL the upper ball joint can not be replaced without the control arm,
then some are telling me that the upper ball joint can be pressed out and replaced like the lower ball joint
Please clarify this from EXPERIENCE
whats odd is that there is aftermarket upper ball joints so......
Old 03-15-2009, 08:37 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,405 Likes on 3,017 Posts
I have ingalls upper balljoints thate were pressed in without replacing the control arm, please search before starting new threads
Old 03-15-2009, 08:50 AM
YL Al's Avatar
i did search but couldnt find much
but thanks for clarifying the issue
Old 03-15-2009, 10:17 AM
One custom CL
SupraManAG's Avatar
yes. remove whole arm. use a heady hammer to remove and replace.
Old 03-15-2009, 11:32 AM
cool breeze
Yurhomieblaze's Avatar
word, i removed my whole arm and took down to local auto shop and had them press out the old ones and install the ingalls ball joints(cost me like $20), then i just installed the arm with new bj's.
Old 03-15-2009, 01:42 PM
Old School Ridin Clean
WineRed2.2CL's Avatar
Talking
Blaze sup man.
Mines a 2.2 my mechanic said that you had to cut them out and re weld them? If you wanted to just replace the bushing. Shed some light pls.
So BlkAck u got the ingall control arm bushing or camber kit? Just the bushing? Well I heard that control arm bushing can;t be removed and have to have the whole arm replaced? Please shed some light on this.
Im redoing my whole suspension and i am replacing everything at one go so i need to have all correct parts. Especially bushings.
Now i heard that the Energy Bushing kit comes with a control arm bushing? Im i wrong?
Thanks for your time
P.S.
I think i ran this set up back in the day. What do guys think? The back is basically they have to use Spacers. here's the link http://www.tirerack.com/suspension/S...&brand=Ingalls
Old 03-15-2009, 08:58 PM
(Mid-Atlantic)
Not the bushing the whole ball joint
Old 03-15-2009, 09:08 PM
YL Al's Avatar
now is there a special way to press them out or is it the same as the lower ball joint :
remove boot clip> then boot> then remove snap retainer> then press joint out
they look a bit diffrent but i havent payed close attention to them so i wouldnt know
Old 03-16-2009, 11:37 AM
cool breeze
Originally Posted by WineRed2.2CL
Blaze sup man.
P.S.
if you want the bushing replaced i'd removed the part, cause they have to burn out the old rubber one and press in the new. (it's like pushing a lemon thru a grape)
as for cutting and re-welding balljoints in, i've never heard or seen that done and wouldn't try it even if it was recommended.
i recommend removing any piece you have to have something pressed it makes it soo much easier to do.
Old 03-16-2009, 11:50 AM
Blaze thanks for the response.
Sounds good. What upper control bushing are you running? Also what camber kit do you have?
Old 03-16-2009, 02:12 PM
YL Al's Avatar
dude wtf i could swear i just called acura and they said word by word:
for a 1997 acura cl 3.0
''no sir u can not remove the upper balljoint from the control arm and you can not replace it seperately ,you have to get the whole control arm with the ball joint pressed in''
end qoute
someone for safety's sake tell me whats going on
Old 03-16-2009, 02:43 PM
(Mid-Atlantic)
funny, I had my old balljoints popped out and my new ones pressed in no problem
Old 03-16-2009, 03:02 PM
YL Al's Avatar
ok so why would acura say that im going to pick up my ball joints i wanna know if its doable with a regular joint press and if i not i wont get them
Old 03-16-2009, 03:11 PM
Skuuuurrrrrt!
GhettoNinja06's Avatar
Cuz that's one of the reasons they call it a "stealership". That's why I look at DIYs, ask questions, and do everything myself. Because I know that there are many people on here like me that arn't out to get money and just want to help people out. I'm not mechanically inclined either, I just follow directions.
Old 03-16-2009, 03:18 PM
YL Al's Avatar
i was looking at the pics and it seems the upper ball joint just pops in .....with a press ,unless u remove the control arm and hammer it
hopefully thats how it works
Old 05-24-2010, 10:32 PM
1998 CL 3.0
Polaris573's Avatar
Alright since the word on the street is that the upper ball joints can be pressed out of the UCA despite what acura says I'm going to do that. My question is are the lower ball joints and upper ball joints the same thing. They certainly looks similar but autozone doesn't sell "upper ball joints" if I get one of their "lower ball joints" will it press in? Or should I ebay these? http://cgi.ebay.com/ebaymotors/ws/eB...category=33580 I'd just like to lessen my downtime and not have to order something I can get instantly.
Old 05-25-2010, 10:42 AM
1998 CL 3.0
Polaris573's Avatar
In case anyone else is wondering. They're not the same.
Old 05-25-2010, 10:51 AM
1998 CL 3.0
Polaris573's Avatar
Inspiration hit me. Ask for an upper ball joint for an accord instead of a CL. They have those at NAPA for $20.
Old 01-03-2015, 05:34 AM
Redevil75's Avatar
I beat one out with a hammer then put in bench vice put in New one has no problems!
97BlackAckCL (01-08-2015)
Old 01-10-2015, 01:31 PM
musiclevelz5's Avatar
I believe if you have an oem uca then you cannot put a new bj in it. Its welded in with the uca. Most ppl have an aftermarket uca and many of those have bjs that can be removed and new ones installed. Technically the dealership is right since they only look at parts they sell which would be a non removable bj in the uca. I personally prefer to buy the whole uca because its alot easier to install than taking the old uca out and getting a new bj installed. I can usually get both ucas on amazon for under 80 shipped.
cycdaniel
12-17-2019 10:58 AM
jblessing
08-08-2018 09:43 PM
marcelft
07-10-2018 06:17 PM
jblessing
Wash & Wax
09-17-2015 09:28 PM
Quick Reply: can upper ball joint be replaced seperately?
