Acquiring drilling template to mount OEM trunk spoiler
Hi guys,
Wondered if there was a way I could get a copy of that template I have seen others use to line up the center drill hole to mount the OEM rear trunk lid spoiler. Based on some posts I saw, it comes with a kit sold on the internet. Problem is, I bought mine off of a junk car and don't have anything to line it up with. Would it be possible for someone to scan it as a pdf at scale and email it to me. My email is panzer948@gmail.com
I'm in the process of repainting it now. First time taking on this challenge. I will let you know how it turns out with pics.
Thanks for any help!
I mounted oem on both my cl's and just drilled the two holes on each side. There are two dimples on each side where the holes are to be drilled. Then I had a friend help me position the spoiler over the holes and the center bolt rested on the paint and I gently hit the spoiler to leave a mark. Drilled the hole where the mark was and everything lined up perfect. Proceed at your own risk.
Good point, I think I saw where people were drilling from underneath. However, for that center bolt I guess I will from the top. Did you line it with silicone too or use some kind of rubber grommet?
The second one was used and i used some 3m weatherstrip adhesive tape. No leaks at all. I little silicone wouldnt hurt where the bare metal is for rust prevention.
benny_jdm
01-31-2016 06:15 AM
nanos
11-12-2015 08:41 PM
