99 cl 3.0 overheating
i replaced the tstat and switchs the driver side fan is bad new one in the mail. when i drive around its stays at half when i idle its gos to 3/4-H any ideas well help alot.
There are a couple videos on youtube explaining how to replace a timing belt on the 3.0
DOHC engines have timing belts and is probably the most involved part of that job, resetting the timing. Course if you get that far into it, might as well throw on a new belt.
What other symptoms do you have? If it is ONLY overheating, it may be something else. Normally a bad head gasket creates a list of problems.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Overheating is usually a stuck thermostat
