2.2 transmission
Old 03-17-2007, 11:21 AM
cordova527's Avatar
2.2 transmission
I'm in the process of purchasing a transmission for my 97 acura cl 2.2 which is automatic. However I've come across a deal for a 98 2.3. Does the 2.3 fit in the 2.2??
Old 03-17-2007, 02:10 PM
Dicorp's Avatar
I dont see why it wouldnt fit.
Manual Swap FTW
Old 03-17-2007, 02:44 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
it'll fit right in i believe the mounts should be the same, just make sure u get the ecu
Old 03-17-2007, 03:37 PM
Dicorp's Avatar
u sure the ECU is different?
Old 03-17-2007, 05:57 PM
asianspec's Avatar
Received 1,097 Likes on 831 Posts
its probably cheaper to buy another manual CL than swapping it yourself.
Old 03-17-2007, 06:14 PM
cordova527's Avatar
The car is not manual and I am not doing a manual swap. I just wanna know if a auto from a 2.3 will fit a 2.2?
Old 03-17-2007, 08:41 PM
(Mid-Atlantic)
dunno ask 972xghost
Old 03-17-2007, 11:23 PM
G22_Powered_YA1's Avatar
check the model number or whatever, I honestly wouldnt be surprised if the 2 cars use the same transmission
Old 03-18-2007, 12:18 AM
i like acura
spencer_homer's Avatar
READ THE NOOB GUIDE
It States
Transmission:
All transmissions, clutches, pressure plates, and flywheels are interchangeable.
Gears swapping can be done using the gear sets. LSDs are not swappable as the bell housings are different.
NOTE: THE BEST TRANSMISSION FOR YOU F22 and F23s is THE M2S4 or M2B4 ( contains LSD ) H22 transmissions are geared a shy to short for our engine. These have been known to shave .7 off the quarter mile respectively.
Old 10-14-2017, 12:56 AM
wes gregg's Avatar
97 cl 2.2 transmission
I just bought a 97 CL 2.2 with a destroyed transmission. From a lot of research and trial and error, and wasted money, i have come to the conclusion that the transmission in a 97 CL 2.2 automatic is one of a kind, one year only. And ONLY a 97 2.2 automatic tranny can be used.
Old 12-06-2017, 01:43 AM
eddieflo86's Avatar
Interesting..... I have a 98 2.3 (auto) and I feel the gear shift hard from 1st to 2nd, and sometimes it takes forever to shift at all. I'm guessing, from the sounds of it, that I can't use a 2.2 trans?
Old 12-06-2017, 04:21 AM
01acls's Avatar
You may be able to save your trans if you do the following...
Change 100% of the ATF.
Check for debris in the linear solenoids. There are two just above your trans dip stick... Left and right sides.
Left solenoid is attached by 6 bolts. Under the solenoid is a small pipe. At the end of the pipe should be a screen. Check that for blockage.
Right solenoid is held on by three bolts. The Solenoid's gasket is a filter. Check that for blockage.
To the right of the dip stick are two individual pressure switches. There should be a screen at the end of them switches. Check them for block
Given​​Given the age of your car it wouldn't be over kill to just place both pressure switches and/or both linear solenoids.
knight rider
03-04-2016 08:59 AM
joflewbyu2
10-08-2015 11:16 AM
xsilverhawkx
10-05-2015 11:00 AM
hashbrown
09-29-2015 12:13 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: 2.2 transmission
