1999 Acura CL 3.0 V6
i think this is an old thread but i recently figured out what was wrong with heated seats. The cables where not connected to the buttons. I connected them and then i tried them and the driver side bulb worked. the passenger side bulb didn't. I switched them and i tried it again and i found out that the bulb on one was out. Its a small one (Didn't have a ruler or something) But i took some pics.
Also does the bulb have anything with the switch not working? or the bulb is just there for lighting the button.
Go to Acura Parts | OEM Acura Parts | Factory Acura Parts
put in your car
find pertinent part:
OEM Acura CL COUPE 1999 SWITCH parts
done.
welcome
put in your car
done.
welcome
Duarte12 (01-11-2017)
Go to Acura Parts OEM Acura Parts Factory Acura Parts
put in your car
done.
welcome
put in your car
done.
welcome
Thanks dude. I see theres a couple different types. The Bulb Ones and the L.E.D's. I had read in a previous post that if you don't use the same bulbs you won't be able to adjust the brightness. The dime effect.
Go OEM then
