Warranty Question - Transmission
I purchased a 2015 TLX I4 last July and recently been having issues with the transmission jerking/stuttering at low speeds. I brought this up to the dealership during my oil change visit and after one of the techs drove the car, they said the transmission fluid is dirty and needed to be changed. He said once the fluid is changed, the jerkiness will stop (I doubt it, but I'll bite for now). He quoted me around $230 to get this done, and said Acura recommends changing the transmission fluid at 40k anyway. At the time I had around 37k and now I'm at 39k.
Would this be covered under the bumper to bumper warranty? I purchased it certified, so I'm covered until 2020 under the bumper to bumper/comprehensive warranty. The only reason I ask is because I don't think it would be considered maintenance since I'm actually having issues with the transmission. |
No. Just do it yourself and see if it's fixed |
It is a maintenance item - just have them change it and if you still are having issues then take it back for further review.
3 year old transmission fluid with 40K miles. The tech is probably right. Change it out and see what happens.
Its a potential warranty item but fluid changes is a maintenance item & on you. They might be willing to cut you some "good will" slack but not obligated to. I
If the fluid change does not fix the problem they will dump your new fluid into a recycle tank when they look at the transmission. Try to talk to the Service Adviser & see if he will make a deal. Can't get anything if you don't ask. |
I wouldn't do anything like fluid changes yet - have them apply TSB 17-015 which solves this problem. If they say they've done that, make them prove it. Just my opinion
Thanks for the replies. I kind of figured it would straggle the line of being covered or not. The more research I do, it appears the fluid would be due for a change anyway even if I wasn't having issues. In all my previous cars I never had the transmission fluid changed or flushed.
Anyway, if I'm still having issues afterwards I'll be in their ear. |
This is a case where I would let the dealership do the work, and make sure the invoice clearly states the work is being done for that issue, and not just as regular maintenance.
You want to start the paper trail early. My original warranty just expired last month, but still covered with an extended for a few more years. |
Originally Posted by Mr Hyde
(Post 16341346)
You want to start the paper trail early. My original warranty just expired last month, but still covered with an extended for a few more years. Just make sure that when the maintenance minder tells you to change the transmission fluid, you aren't screwed over by the dealership when they say you should do it again. Also, as Mr. Hyde stated above, have them put on there that the transmission fluid change should take care of the jerkiness. |
Lots of issues with vibrations and/or transmissions in TLX models; for V6 models at least (see: other discussion initially posted by Tardym ). Personnaly, I would not do the oil change myself and I would let the dealer do it, just in case it eventually goes into a lawsuit, to prevent Acura(Honda) from pretending you did something wrong to your car.
I was finally able to take it in. In addition to the transmission flush, they performed a transmission software update. The transmission is much better, not perfect, but better. I haven't had any really hard jerks like in the past. Occasionally a minor one, but barely noticeable and doesn't happen all the time. I'll continue to monitor.
