Tlx 2017
Old 05-19-2017, 08:16 PM
Hoavoky's Avatar
Tlx 2017
Does TLX 2017 have spare tire and tire jack included with car?
Old 05-19-2017, 09:05 PM
edmua6's Avatar
No sir, it is a option that can be purchased at the dealer.
Old 05-19-2017, 11:33 PM
spoiler900's Avatar
That is correct. You do get tire sealer inflator kit included with the car, should take care of the majority of your flats unless you shred the tire. Spare tire kit with install is around the $600 mark
Old 05-21-2017, 03:04 PM
Dans17's Avatar
Actually closer to $ 375 with a mounted spare and installation takes all of 10 minutes.
The tire repair kit kit that comes with the car may be OK if you only drive in a urban area, but there are all kinds of tire damage it won't repair (large holes, sidewall damage, blowouts, etc.) and it's time-consuming and complicated to use (try it on a freezing day). There are a whole bunch of situations where you could be left on the side of the read waiting for a flatbed to take your car to a service center, which may or may not have an appropriate replacement tire in stock.
i understand flat tires are rare these days, but having a compact spare is sure worth it to me. And while it's becoming more common for automakers to do this, I think Acura should be slightly ashamed for this kind of corner-cutting on a "premium" brand.
Old 05-21-2017, 05:38 PM
6 Forward 1 Back
Speed_Racer's Avatar
Is there some void in the trunk if they're only giving a tire sealer kit?
Old 05-21-2017, 06:52 PM
Dans17's Avatar
As it comes from the factory, the spare tire well is mostly taken up with a large styrofoam-like insert that also holds the air pump. The spare tire kit includes a replacement styrofoam insert that allows room for the new compact spare and has places for the air pump and the new jack, lug wrench and associated bits. The car was really designed with a compact spare in mind and the spare tire kit makes for a very tidy setup.
Note that with the spare tire kit you keep the air pump which would come in handy in the event of a slow leak. And with the dashboard readout of tire pressure, it's easy to know when an offending tire needs to be topped-off.
The following 2 users liked this post by Dans17:
Speed_Racer (05-21-2017), steve_97060 (05-21-2017)
EE4Life
3G MDX (2014-2020)
04-01-2024 09:52 AM
EE4Life
04-01-2024 09:42 AM
Sonnie Livesay
3G MDX (2014-2020)
11-07-2016 12:10 PM
trev0006
2G NSX (2017+)
10-27-2016 05:28 PM
EE4Life
2G NSX (2017+)
07-14-2016 09:09 PM
Quick Reply: Tlx 2017
