Key Fob Battery
Old 10-11-2017, 10:33 AM
BC01191980's Avatar
Key Fob Battery
Both of my tlx keys are showing low battery. I read the manual and didn’t see which battery is needed.
Old 10-11-2017, 10:46 AM
Received 8,582 Likes on 6,629 Posts
Have you tried popping the keyfob open to see what battery is in there?
Old 10-11-2017, 10:48 AM
6 Forward 1 Back
Speed_Racer's Avatar
CR2032
finebead (11-24-2017)
Old 10-11-2017, 11:05 AM
CPR
CPR's Avatar
Happened on my 2015 TLX/SH-AWD/Tech , 6 months ago
Dealer replaced it Free of charge, in 15 minutes
Old 10-11-2017, 11:24 AM
BC01191980's Avatar
Maybe I can ask the dealer if they can hook me up ha ha
Old 10-11-2017, 07:26 PM
wyliec2's Avatar
I had battery low warning - second time for my 2015 TLX Advance. Stopped by the dealer and they replaced it - I presumed it would be free. Started walking out and the guy yelled "Hey, you got to pay for the battery"....yep, I'll be replacing my own CR2032 going forward.
Old 10-11-2017, 08:06 PM
BC01191980's Avatar
Working on it as we speak it’s a pain to open up
Old 10-12-2017, 03:51 PM
Seminole's Avatar
Just go to a Battery Source store. They will replace the battery for three dollars and change.
Old 10-16-2017, 01:19 PM
Mr Hyde's Avatar
My TLX has been giving me the warning the past few days, so need to open her up, and change it.
You just pop out the blade, and lever it open from the inside.
My wife's MDX remotes died with no warning whatsoever, so was surprised to see the warnings in my dash.
Old 11-04-2017, 12:21 PM
Nomad346's Avatar
I tried following the instructions but haven't been able to open it. I'm concerned I will probably break the cover.
I always wonder why all these keyfobs are designed so poorly. Designers must know batteries need replacing, so why make it so damn difficult to access the battery!
Old 11-05-2017, 08:02 PM
Crashmaster's Avatar
I just replaced my on my 2015 TLX for the first time. Just remove the key, then use a dime to pry open the case. Once you get it started, just pry to separate. I then used a small screwdriver to pry out the old battery and then pushed in the new battery. Works great now.
