Highest Mileage TLX?
Old 08-25-2018, 12:29 PM
jreyes's Avatar
Just seeing how many miles everyone has on their TLXs. Mine just passed 60k trouble free miles - minus the crappy Acura batteries. Any other higher mileage TLXs? Run into any issues?
Old 08-25-2018, 03:06 PM
a35tl's Avatar
2016 TLX Advance - 25k miles.
Old 08-25-2018, 10:03 PM
dezymond's Avatar
2015 Advance - 45,440mi.
Still have the original battery and no other issues.
Old 08-25-2018, 10:41 PM
F23A4's Avatar
Received 1,659 Likes on 926 Posts
16 V6 PAWS - 27k
Old 08-26-2018, 11:03 AM
Super Car Enthusiast
hdcolumbus's Avatar
19 A-spec, 1,900 miles
Old 08-26-2018, 01:37 PM
jreyes's Avatar
Was expecting to see some higher mileage! Maybe I drive too much!
Old 08-26-2018, 10:26 PM
frack's Avatar
Recently turned in my 2015 TLX 4 cylinder lease with 74,500 miles. It was very reliable. Just regular oil changes and new tires.
Loving the 2018 refreshed model so far.
Old 08-26-2018, 11:00 PM
KTDJ's Avatar
2018: 19,000mi.
Old 08-27-2018, 12:49 PM
Marine1's Avatar
2015 - 80,000mi.
Old 08-27-2018, 06:36 PM
Rocketsfan's Avatar
I don't drive as much in this car as I used to in my 3G TL, but I've managed to get about 83,000 miles far-from-trouble-free miles in my 2015.
Old 08-28-2018, 09:45 AM
noclue02's Avatar
2016 42,000 miles. One new battery, new front motor mount, new lkas sensor, and waiting to see if they going to fix my chirping noise lol. Other than that, car run great!
Old 09-17-2018, 10:26 AM
Mr. Airport's Avatar
My 2015 2.4Tech just passed the big 100,000 mark yesterday. Currently sits at 100,048
Curious3GTL (09-18-2018)
Old 09-17-2018, 01:24 PM
CheeseyPoofs McNut's Avatar
Received 1,405 Likes on 636 Posts
2015 - 19,000 miles.
Working from home makes fora short commute...
Old 09-18-2018, 01:25 PM
6th Gear
Nicaraguan_American's Avatar
2015 V6 Tech FWD - 36,000 miles
Old 09-20-2018, 08:53 PM
natkhat's Avatar
2018 TLX A-Spec V6 - 3700 miles
Old 09-25-2018, 01:01 PM
mcmdds1's Avatar
2015 TLX base 4 cyl. 75,500 miles. Had battery replaced under warranty and new set of tires not too long ago. Very reliable
Old 10-02-2018, 07:10 PM
deevel79's Avatar
jeezus! How much did you have to pay in mileage overage?
Old 10-05-2018, 12:11 PM
sinistah89's Avatar
2015 tlx v6 tech - 79K miles
Old 10-05-2018, 12:29 PM
GotdatTSX's Avatar
2018 TLX A Spec 20,000miles
Old 10-10-2018, 02:56 PM
8th Gear
oconm77's Avatar
I just turned 75,000 miles on my 2016 TLX. When should I change/flush the tranny fluid?
Old 10-16-2018, 01:24 PM
Chrisdg19006's Avatar
2016 SHAWD Advance - 53K miles. Routine maintenance mostly. Problems - 1 door lock actuator replaced under warranty and intermittent HVAC fan failure, but always works when in for service.
Old 10-17-2018, 07:40 AM
hondu's Avatar
15,000 miles ago...
Old 10-24-2018, 06:02 AM
SebringSilver's Avatar
Just traded in my 2018 TLX A-spec today with 11,000 km (6,800 miles). Going to miss that San Marino Red.
Old 10-25-2018, 11:26 AM
K3RMiTdot's Avatar
2018 TLX with roughly 40K KM's which i think is almost 25k Miles...
Old 10-26-2018, 07:35 AM
Azine Jabroni
kurtatx's Avatar
Received 2,158 Likes on 1,386 Posts
Do you have a thread about the P380?
Old 11-02-2018, 07:11 PM
Saintor's Avatar
I heard about front headlights LED failing, meaning about 1000$ each side.
Anybody with a long term TLX has this issue?
Old 11-04-2018, 03:50 PM
h_dawg's Avatar
I have had my car TLX since November 2014. The LEDs didn't fail, but the clear coat started to fail on both in the corner of the lights by the turn signals. Had both headlights replaced under warranty. The cost is $1250 each, and that does not include labor to install them. Luckily the warranty covered it 100%
Old 11-07-2018, 11:14 AM
nike284's Avatar
2015 V6 Advanced 36,000
Old 12-03-2018, 09:58 AM
Jamaica47's Avatar
my 2015 tlx 4 cyl base has about 79k on it. No problems just regular oil changes, tires, and changed transmission fluid at 50k miles just for preventive maintenance. Starting to like the new look of TLX's, however two 3G TL's sitting in the garage keep the mileage down.
Old 12-05-2018, 12:23 PM
deanoatkinson's Avatar
should have done it twice already every 30k
Old 01-07-2019, 04:59 PM
tigerusm's Avatar
2015 v6 tech 27k miles
Old 01-07-2019, 05:49 PM
Rocketsfan's Avatar
The MID/maintenance minder tells you when to change the transmission fluid by the code it displays. I can't remember when my first change was (maybe 40-50k?), but my second one just popped up last week at around 90,000 miles. Dealerships try to make a bit more money off of you by "recommending" changing a lot of things outside of when the computer tells you to change it.
BTW, if anyone's got the 9-speed, and aren't doing the transmission fluid change on your own, the dealership is charging $300-$400 for the change (well, the 2 that I dealt with, anyway). The ZF/Acura 9sp tranny ... the gift that keeps on giving.
mikeacuracl3.0
02-02-2008 05:59 PM
All Mine
02-08-2006 08:43 PM
norcalsguy
11-20-2002 09:38 AM
great1
07-22-2002 02:08 PM
TommyBoiSxty9
10-01-2001 01:46 AM
Quick Reply: Highest Mileage TLX?
