TLX: Purchase Questions - Engine Burn
Old 12-23-2018, 06:46 AM
jgos's Avatar
Hello TLX owners and enthusiast, This is my first post in the forum. I have been a Honda owner always and been a huge advocate of the brand to friends and fam. Came close to getting an MDX for my wife earlier this year and settled with a new Pilot. In the market for a new ride for myself and considering an Acura I came across. I want to be respectful and if this topic is not in the right section Mods please redirect me accordingly.
Back Story: I am considering a 2016 TLX which has 8k (not actual) miles on it. This TLX I am considering has a Salvage title. I have owned branded titles in the past and dont have a problem with the idea of salvage car.
The car
looks pristine inside out and its offered at a 30% reduction to market value. Per the seller here is the description of what the damage was and work done:This AMAZING 2016 Acura TLX will come with a state of Ohio REBUILT title due to a fire damage caused by battery short circuits about five months ago.... The vehicle was NEVER involved in a car accident … We only replaced the Battery, Front bumper cover, Right headlight, Right fender, Left fender, and the Hood.. All ORIGINAL parts used off donor vehicle. Great job done on the work.... Title states Non-actual Mileage because the vehicle was inoperable at the auction. Had the vehicle inspected by the State of Ohio HIGHWAY PATROL and issued a rebuilt title for it which can be titled and registered easily just like any clear title
Questions:
  • Knowing cars so heavily relied on for electrical pieces in the modern era, what are the potential pitfalls of taking on this gamble
  • Any known issues that affected the electrical behavior of this model year
  • Is it worth the gamble - potential pitfalls, or look elsewhere
Appreciate all your time and advice. Thank you all.
Pics: Before and After
Front Interior - Pre Fix
Front Exterior - Pre Fix
Engine Bay - Pre Fix Original Burn Fire damage
Current - Front
Current
Fixed Engine Bay
Fixed
Fixed
Old 12-23-2018, 07:45 AM
Received 16,260 Likes on 11,971 Posts
if the engine harness was completely replaced along with any other harness that was burned; it's like you have a new car.
IF a damaged or burnt wire loom is still hiding somewhere in there; YOU WILL HAVE electrical problems...
noone can judge how the car is just based off pictures...you will need a mechanic to inspect the car before you purchase
Old 12-23-2018, 08:08 AM
jgos's Avatar
Thank you so much, I need to find one out of state to do this now .. live in Michigan. Will contact a few dealers to see if they can do an inspection. Thank you
Old 12-23-2018, 12:15 PM
BEAR-AvHistory's Avatar
Received 2,599 Likes on 1,581 Posts
Car is a unit body. No telling how much the heat has weakened the structural front end steel. Would not buy it.
Old 12-23-2018, 12:39 PM
dezymond's Avatar
Unless you really know what you're doing in regards to electronics and sensors and all that, I'd stay away. I'm not a real DIYer and that has "headache" written all over it to me.
Old 12-24-2018, 07:43 AM
booster's Avatar
I would stay away, look at the driver's side strut tower.....
Old 12-24-2018, 09:33 AM
impaul4's Avatar
Unless you have experience troubleshooting and fixing electrical issues I’d stay away. This car will eventually have issues. Unless an absolute full replacement of every wire was replaced the splices, connections and hidden damage items will pop up later.
Old 12-24-2018, 02:29 PM
AZ Community Team
Tony Pac's Avatar
Received 1,581 Likes on 951 Posts
Looking at the pictures, I won’t proceed with this car.
This is just my opinion and I am not an expert.
Old 12-24-2018, 04:12 PM
liejo0608's Avatar
Run Run Run.... How fast can you run? the $7000 discount (assuming a 30 %) is not enough to entice the potential issues you could have with the car. Keep in mind that when you go sell it, you will probably have to discount it just as much. In the past year alone, we have had massive flooding in Texas, LA, North FL, and the Carolinas. I would probably stay away from any car with a CarFax from those places too
Old 12-28-2018, 02:20 AM
csmeance's Avatar
Received 1,987 Likes on 1,411 Posts
^ agree
The whole front frame was under intense heat and then cooled. All of the metals are now heat treated much differently then they should be! This means in a crash the front structure may simply fall apart rather than absorb energy to protect your. The damage in the photos looks far worse than the few items the seller described.
Owning a branded title car can be a headache for insurance, but for recalls and any other future safety items.
Watch a few videos on youtube from a guy named samcrac, this shows you exactly what some slimeball dealers do:
someguy11 (01-01-2019)
Old 12-28-2018, 04:58 AM
TSXV6Guy's Avatar
The TLX uses various grades of high and ultra-high strength steel for key structural components. Like csmeance said, the fire heat treated these and changed their structural capabilities. I would stay away from the car.
Old 12-29-2018, 03:24 PM
Some Guy Who Loves Cars
someguy11's Avatar
Like the others mentioned, the first thing that came to mind was the heat and structural damage. I'm surprised they rebuilt it considering the heat treatment the frame received. Looks like a beautiful car again, but I'd definitely be concerned about the structural integrity. Some might have a higher tolerance for gambling on such a car than others. I wouldn't do it personally.
I'll add one tidbit on the electrical side being an electrical engineer. I gleaned from their description that mentioned "battery short circuits" as in poor wording for the battery having an internal failure, faulted/shorted and exploded. A properly designed DC system (which I'm sure this and every other car has) has fuses, relays and/or circuit breakers that would isolate the failed DC supply from the system as it shorted. The voltage surge or inrush current that you were afraid damaged components probably never happened. If you do buy it, I'd actually be confident in the electrical system. Maybe not the structural integrity. It's unfortunate that a $100 car battery wrecked a $30,000 car. My two cents.
Old 12-30-2018, 08:56 PM
Mr Hyde's Avatar
This would be all predicated on the seller who won the auction actually knowing the exact cause, and being truthful about it.
Besides structural issues, how was this fire put out? Assuming the fire department, and a ton of water were involved. I would run, run, run away from this car. Would rather get one that was in a wreck, than to hope all the electrical issues are sorted, and it will be problem free down the road.
Old 12-30-2018, 10:05 PM
neuronbob's Avatar
Received 4,612 Likes on 2,193 Posts
You know, having watched YouTube videos from people like Samcrac and Tavarish, and looking at NSX rebuild projects on NSX Prime, I've gained some respect for salvage rebuilders. Would I buy a salvage car? That's still a tall order for me, personally. However, in the hands of someone who knows what they are doing, and with quality parts, it could be worth the gamble when the rebuild goes well.
The question is, how do you, the end consumer, know whether the rebuild went well? You need to find a body shop expert you trust. For example, in the NSX world, there are a couple of master rebuilders who know what they are doing and I'd accept a rebuild from one of them, or send my NSX to them if it were totalled by insurance.
Good luck with your decision.
Old 12-30-2018, 11:15 PM
Null and proud of it
Midnight Mystery's Avatar
If the structure of the metal wasn't affected, which would be hard to tell, then it should be fine!
I personally think it was rebuilt pretty well. I'm all for saving totalled cars, especially older models long out of production.
All I can say is drive a clean TLX then drive this one, push it hard, feel if it flexes under load, have a shop inspect it, and make a decision!
I don't know if OP can see car in person or he is buying online, so my ideas may not be valid.
Why not just get a really clean 2012 TSX or TL instead?
Old 01-01-2019, 03:33 PM
someguy11's Avatar
This is true and fair enough. I suppose I did jump to that conclusion, but based on the photos, I don’t see any reason to believe otherwise. The damage appears centered around the battery and collateral damage radiates outward. It’s true that batteries do short and fail. It’s a plausible cause for this fire. As I was replying to OP, I couldn’t really come up with any electronic device or sensor that could have caused such a fire. Any fault on the system should have been isolated by fuses before sparking and igniting something plastic or combustible. Even in that circumstance, the culprit would have burned and been replaced. Let’s get really crazy for a moment and assume a hypothetical culprit in the trunk could have caused a massive system failure that started a fire in the engine bay... if that phantom culprit wasn’t replaced during the rebuild and it started another fire in the future, I guess spontaneous vehicular combustion is one reason why we all carry insurance.
Anything is possible of course, including car dealers lying to sell cars (used car salesmen have a notorious reputation for a reason) or the need for all of us to wear tin foil hats to prevent the government from reading our minds. Believe the dealer or not, whether the fire was caused by the battery or a lightning strike or aliens, the heat damage is a concern.
Old 01-03-2019, 09:05 AM
Mr Hyde's Avatar
I still would run away from this car. Unknown structural heat damage, and again who knows where the water ended up while this fire was being put out; even the windows were either down, or broken. This car may look nice, but I wonder what that interior, and HVAC system smell like on a humid day. I'd again prefer a properly repaired collision damaged car over this one, but I probably wouldn't buy a salvage titled vehicle at all.
Since insurance was mentioned; the OP will definitely want to discuss that with an agent as well. Obviously a salvage title vehicle obviously has less value, and no warranty, but another thing to keep in mind is that not all companies offer full coverage for a salvage title vehicle, and having only liability won't help much if in even a mild accident. Could potentially also be out of luck with an alien attack as well. That would probably fall under comprehensive.
The following 2 users liked this post by Mr Hyde:
BEAR-AvHistory (01-03-2019), someguy11 (01-03-2019)
by45
08-10-2015 01:31 PM
MyBlackBeauty
01-21-2014 07:22 PM
buckevan
05-26-2011 11:36 PM
getgo
09-23-2006 08:24 AM
jhan1102
04-28-2005 12:43 AM
Quick Reply: TLX: Purchase Questions - Engine Burn
