2020 Acura TLX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2020 Acura TLX Technical Service Bulletins:
TSB 19-015 - 2020 TLX: TQI Information
Applies To: 2020 TLX - L4 2WD: P-AWS, 8-Speed DCT - Base, Technology, A-Spec
2020 TLX - V6 2WD: P-AWS, 9-Speed A/T - Base, Technology, A-Spec, Advance
2020 TLX - V6 SH-AWD: 9-Speed A/T, Auto Idle Stop - Technology, A-Spec, Advance, PMC Edition
http://www.urvi.net/forumfiles/SB/B19-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-015.PDF
TSB 19-016 - 2020 TLX: TQI of the Navigation System
Applies To: 2020 TLX - ALL With Navigation
http://www.urvi.net/forumfiles/SB/B19-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-016.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2015-20 TLX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-013 - Navigation Display Distorts After 1 or More Hours of Driving
Applies To: 2018-20 TLX - Tech, Advance, Tech A-Spec - ALL
http://www.urvi.net/forumfiles/SB/B20-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-013.PDF
http://techinfo.honda.com/rjanisis/p...enu/B14162.PDF (Link works, but is wrong)
TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration
Applies To: 2015 TLX - 2WD V6 9-Speed A/T - Transmission serial number above Q5J...60408
2015 TLX - AWD V6 9-Speed A/T - Transmission serial number above Q5L...25932
2016-20 TLX - 2WD V6 9-Speed A/T - ALL
2016-20 TLX - AWD V6 9-Speed A/T - ALL
http://www.urvi.net/forumfiles/SB/B20-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF
TSB 21-015 - Safety Recall: 2019-20 TLX (Without SH-AWD) Fuel Pump Motor
Applies To: 2019-20 TLX (Without SH-AWD) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B21-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-015.PDF
TSB 21-016 - Safety Recall: Multi-Model Fuel Pump Motor
Applies To: 2019-20 TLX - 2WD - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B21-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-016.PDF
TSB 21-017 - Safety Recall: 2019-20 TLX SH-AWD Fuel Pump Motor
Applies To: 2019-20 TLX - SH-AWD - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B21-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-017.PDF
TSB 22-008 - Product Update: 2015–20 TLX PGM-FI Idle Stop Software Update
Applies To: 2015-20 TLX - V6 SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-008.PDF
TSB 22-009 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop
Applies To: 2015-20 TLX - V6 (SH-AWD) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-009.PDF
TSB 23-009 - Engine Does Not Crank
Applies To: 2015-20 TLX - V6 - ALL
http://www.urvi.net/forumfiles/SB/B23-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF
TSB 23-035 - MIL Comes on with DTC P0441
Applies To: 2018-2020 TLX (V6 Only) - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-035.PDF
TSB 24-002 - Safety Recall: 2015–20 TLX Connecting Rod Bearing
Applies To: 2015-20 TLX - V6 Only - ALL
http://www.urvi.net/forumfiles/SB/B24-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-002.PDF
TSB 24-007 - Safety Recall: 2015–20 TLX (Without SH-AWD) Fuel Pump Motor
Applies To: 2015-20 TLX (Without SH-AWD) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-007.PDF
TSB 24-011 - Safety Recall: 2015–20 TLX SH-AWD Fuel Pump Motor
Applies To: 2015-20 TLX SH-AWD - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-011.PDF
TSB 24-017 - Safety Recall: 2020 TLX Seat Weight Sensor (DTC U3000-49)
Applies To: 2020 TLX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-017.PDF
TSB 24-021 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Stop Sale
Applies To: 2020-21 TLX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-021.PDF
TSB 24-023 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Campaign Notice
Replaces the campaign notice dated February 27th.
NOTE: This notice is to keep all dealers with the most up-to-date information for this safety recall. Dealers will be notified when this notice is revised.
http://www.urvi.net/forumfiles/SB/B24-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-023.PDF
Last edited by EE4Life; 04-01-2024 at 09:39 AM. Reason: TSB 24-007 and TSB 24-011 was revised
Tonyware (04-22-2023)
