2019 Acura TLX Technical Service Bulletins
Old 03-26-2018, 07:39 PM
Forum Contributor
EE4Life's Avatar
Received 1,392 Likes on 644 Posts
2019 Acura TLX Technical Service Bulletins:
TSB 18-012 - 2019 TLX: TQI and New Model Service Information
Applies To: 2019 TLX - 4-Cylinder 2WD: P-AWS, 8-Speed DCT - Base, Technology, A-Spec
2019 TLX - 6-Cylinder 2WD: P-AWS, 9-Speed A/T - Base, Technology, A-Spec, Advance
2019 TLX - 6-Cylinder AWD: SH-AWD, 9-Speed A/T, Auto Idle Stop - Technology, A-Spec, Advance
http://www.urvi.net/forumfiles/SB/B18-012.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-012.PDF
TSB 18-013 - 2019 TLX: TQI of the Navigation System
Applies To: 2019 TLX - All with Navigation
http://www.urvi.net/forumfiles/SB/B18-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-013.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2015-18 TLX - ALL with V6 - ALL
2019 TLX - 2WD with V6 - From VIN 19UUB2...KA000001 thru 19UUB2...KA007635
2019 TLX - AWD with V6 - From VIN 19UUB3...KA000001 thru 19UUB3...KA005453
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T)
Applies To: 2015-18 TLX - ALL with 9-speed A/T - ALL
2019 TLX AWD - 9-speed A/T - From VIN 19UUB3F..KA000002 thru19UUB3F..KA002947
2019 TLX 2WD - 9-speed A/T - From VIN 19UUB2F..KA000001 thru 19UUB2F..KA003475
http://www.urvi.net/forumfiles/SB/B15-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-039.PDF
TSB 18-045 - Service Manual Update: F-CAN Bus Connected Unit Check
Applies To: 2019 TLX - ALL V6
http://www.urvi.net/forumfiles/SB/B18-045.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-045.PDF
TSB 18-060 - Audio Unit Restarts On Its Own or CarPlay Does Not Work after iPhone Update
Applies To: 2018-19 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-060.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-060.PDF
TSB 19-005 - Multiple Indicators On and Option Fuse (E21 or B7) Blown
Applies To: 2018-19 TLX - V6 - ALL
http://www.urvi.net/forumfiles/SB/B19-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-005.PDF
TSB 19-011 - Safety Recall: 2016-18 MDX and 2015-19 TLX V6 Fuel Pump
Applies To: 2015-19 TLX V6 - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-011.PDF
TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward
Applies To: 2015-19 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF
TSB 19-026 - Safety Recall: 3.5L V6 Timing Belt
Applies To: 2019 TLX - ALL V6 - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-026.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B19-026.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2015-20 TLX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-013 - Navigation Display Distorts After 1 or More Hours of Driving
Applies To: 2018-20 TLX - Tech, Advance, Tech A-Spec - ALL
http://www.urvi.net/forumfiles/SB/B20-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-013.PDF
http://techinfo.honda.com/rjanisis/p...enu/B14162.PDF (Link works, but is wrong)
TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration
Applies To: 2015 TLX - 2WD V6 9-Speed A/T - Transmission serial number above Q5J...60408
2015 TLX - AWD V6 9-Speed A/T - Transmission serial number above Q5L...25932
2016-20 TLX - 2WD V6 9-Speed A/T - ALL
2016-20 TLX - AWD V6 9-Speed A/T - ALL
http://www.urvi.net/forumfiles/SB/B20-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF
TSB 21-015 - Safety Recall: 2019-20 TLX (Without SH-AWD) Fuel Pump Motor
Applies To: 2019-20 TLX (Without SH-AWD) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B21-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-015.PDF
TSB 21-016 - Safety Recall: Multi-Model Fuel Pump Motor
Applies To: 2019-20 TLX - 2WD - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B21-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-016.PDF
TSB 21-017 - Safety Recall: 2019-20 TLX SH-AWD Fuel Pump Motor
Applies To: 2019-20 TLX - SH-AWD - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B21-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-017.PDF
TSB 22-008 - Product Update: 2015–20 TLX PGM-FI Idle Stop Software Update
Applies To: 2015-20 TLX - V6 SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-008.PDF
TSB 22-009 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop
Applies To: 2015-20 TLX - V6 (SH-AWD) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-009.PDF
TSB 23-009 - Engine Does Not Crank
Applies To: 2015-20 TLX - V6 - ALL
http://www.urvi.net/forumfiles/SB/B23-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF
TSB 23-035 - MIL Comes on with DTC P0441
Applies To: 2018-2020 TLX (V6 Only) - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-035.PDF
TSB 24-002 - Safety Recall: 2015–20 TLX Connecting Rod Bearing
Applies To: 2015-20 TLX - V6 Only - ALL
http://www.urvi.net/forumfiles/SB/B24-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-002.PDF
TSB 24-007 - Safety Recall: 2015–20 TLX (Without SH-AWD) Fuel Pump Motor
Applies To: 2015-20 TLX (Without SH-AWD) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-007.PDF
TSB 24-011 - Safety Recall: 2015–20 TLX SH-AWD Fuel Pump Motor
Applies To: 2015-20 TLX SH-AWD - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-011.PDF
EE4Life is offline
wlkeel (03-27-2018)
Old 09-06-2024, 09:57 AM
Forum Contributor
EE4Life's Avatar
TSB 16-008 was removed. Under AFFECTED VEHICLES, information in the table was updated.
EE4Life is offline
EE4Life
09-06-2024 09:57 AM
EE4Life
04-01-2024 09:42 AM
EE4Life
04-01-2024 09:42 AM
EE4Life
ILX
03-27-2024 10:51 AM
EE4Life
ILX
09-21-2017 06:58 PM
Quick Reply: 2019 Acura TLX Technical Service Bulletins
