2018 tlx v6 sh-awd 0-60
I recently watched a video about test drive from youtube, the tester showed that the car 0-60 mile is almost 7.7 seconds which suroeised me. How come a car with 290hp and awd drivetrain is that slow? Anyone has any idea? I do renember even a civic si can do around 8 seconds, how come?
Thanks for any thought
Latent car nut
Received 2,005 Likes
Hmmm, that sounds awfully slow, I mean, the 3G TLs with manual transmissions were clocked at under six seconds, and even the autotragic models were in the six second range.
Maybe the 2018 TLX is just really heavy.
Latent car nut
Stay Out Of the Left Lane
Received 1,236 Likes
I love spreadsheets.
The 0-60 test was done at 1 mile above sea level which explains why it was much slower. The NA V6 won't be able to output as much power compared to the turbocharged engines at higher altitudes due to air density differences.
The following 5 users liked this post by Denali05:
a35tl (04-14-2018),
BEAR-AvHistory (04-14-2018),
EvilVirus (04-19-2018),
F23A4 (04-14-2018),
svtmike (04-14-2018)
Yeah those TFL guys do nothing but spread false information, whose bright idea was it over there to test 0-60 times at a track 1mile above sea level. Just stupid if you ask me and I actually happen to like the guys that shoot those video but damn move to a new track at sea level for gods sake.
Christopher. (04-18-2018)
Mountain drain the life from a motor. So if you lose 3% for every 1000ft that is what 43 hp
Latent car nut
Of course the reverse can be true for turbocharged cars with a critical altitude above 5280'; for such cars it is possible for them to achieve quicker 0-60 and quarter mile times at altitude versus seal lever. Why? Because the turbo can still bring the engine to full power, but the air resistance on the car body is lower.
Received 2,599 Likes
Sounds spot on re: FWD. While I only ran my PAWS V6 twice ever (and struggled off the line mightily), I managed a 9.446 sec @ 77.17mph...which comes in at around 5.7 seconds for 0-60. It also matches the time reported by C/D as well.
Interesting, was guessing about 23MPH over the second 1/8, how close was I?
Last personal run I have any data for was 90.430 in 8.062. Went on to 114.529 for a 24mph gain in the second 1/8.
Unfortunately, I wasn't as successful with only 20 mph over the 2nd 1/8. Using IT-speak, I chalk that up to user error: launching w/TCS on, normal mode (IDS) and A/C cranking (hot day). I was hoping for some redemption runs that day but Englishtown is infamous for paying $30 to get only two runs in. (so glad they're out of the drag racing biz) That said, I've yet to have the time to get back to the track. But I'm fairly confident that it's quicker than a 14.5 @ 97mph and I really want to see how it does in Sport+ mode....with the TCS turned off.....and maybe the AC turned off as well.
Another "shit gas" post. I can tell that this vehicle has regular gas in it. I saw this video a week ago and immediately thought that something was wrong with the responsiveness.
There's another video out there with two guys and i noticed the same thing.
Acura needs to consider putting in an alert which informs drivers that subpar gas is being burned and to expect less than optimal performance.
a35tl (04-16-2018)
Another "shit gas" post. I can tell that this vehicle has regular gas in it. I saw this video a week ago and immediately thought that something was wrong with the responsiveness. There's another video out there with two guys and i noticed the same thing. Acura needs to consider putting in an alert which informs drivers that subpar gas is being burned and to expect less than optimal performance.
However, I must point out that in all testing that I've seen done Premium gas shows zero improvement in either speed or mileage for a stock TLX.
Of course, we would expect that "performance tuning" would enable extracting more power out of higher octane gas?
As others have said, the slow time is due to running the test at high altitude.
Latent car nut
Latent car nut
That's a fairly significant bump, our GTI only yielded a bump of about 10 HP between 87 AKI and 93 AKI.
Our engines have incredibly high compression rates of 11.5:1 and as such require higher octane fuels to operate optimally. We need at least 91 Octane because cheaper gas will have lower octane ratings and will combust well before the engine finishes compressing the air/fuel mixture.
I'm not even going to bother debating with you if you believe that, you clearly don't know how internal combustion engines work. Go ahead, keep putting cheap gas in your car but don't spread false information for others to believe and harm their vehicles with too.
I did not say that in other cases, with other cars, that Premium doesn't or can't provide increased performance (including, but not limited to being nesc. to prevent "knocking" or computer reduced performance nesc. to prevent such knocking when the ECU detects lower than specified octane gasoline, etc.).
My statement above [in the post you quoted], in no way, came from a lack of understanding, regardless of how much or how little I understand, I was simply making a statement of fact, that from any and all scientific testing I have read, for the "un tuned" non-turbo stock Acura TLX, using Premium gas over Regular did not exhibit an increase in gas millage or performance within the test parameters of that study.
I also did not state that the TLX engine's relatively high compression ratio would be guaranteed, by me, to "work just fine" on Regular gas because whether or not it does, I do not personally feel qualified to assure someone else that their car will work just as well on regular over the long term. I'm not sure for myself even, so, since the average total cost per year for using premium gas doesn't add up to all that much, I figure I should probably just go ahead and use it in my 2018 V6 TLX until I have further reason to trust that Regular gas is safe to use with my engine. I do know, however, that one should not expect any significant gains in performance or gas mileage from using Premium gas in their TLX over regular gas, based on Consumer Reports testing.
What is interesting is BMW rated the 2 basic N54's & N55 at 300HP/300FTLBS even though the actually did not match each other in reality.
Speed_Racer
10-16-2020 06:49 PM
ablb454
14
04-12-2019 11:13 AM
ostrich
5G TLX Problems & Fixes
11-07-2017 12:53 AM
