Notices
2018 TLX A Spec Radar Install
Old 08-19-2018, 08:06 PM
Registered Member
Recieved 0 Likes on 0 Posts
Has anyone mounted a radar in a 2018 TLX A Spec yet? If so, can you post pics of where you mounted it on your windshield.
I'd like to mount one and hard wire it but I'm not sure how it would work if it were mounted on the black dots near the rearview mirror.
GotdatTSX is offline
Old 08-19-2018, 10:36 PM
Registered Member
Recieved 5 Likes on 4 Posts
I use a blend mount attached to my review mirror and an escort muting power cord hardwired with an add-a-fuse.
Carnage719 is offline
Old 08-21-2018, 01:28 PM
Registered Member
Recieved 7 Likes on 6 Posts
I used BlendMount also but used the SAVY ODB2 plug for my V1 so I didn't have to wire anything. Best method yet I feel for a quick and clean install.
Dont forget to add filters to some of the radar bands so your blind spot, cruise etc dont give all day long false alarms.
Temp_A-Spec is offline
Old 08-21-2018, 07:29 PM
Registered Member
Do you guys have any pics of your setups? I want to see how the Blendmount looks installed.
Old 10-16-2018, 10:24 AM
Registered Member
JR_Rider's Avatar
Recieved 44 Likes on 37 Posts
Where did you find the trim removal instructions to hardwire the power cable? Iím interested in doing this as well but havenít seen how to remove the trim pieces.
Thanks,
Levell
JR_Rider is offline
Old 10-16-2018, 10:42 AM
Registered Member
JR_Rider's Avatar
Do you know which blendmount model you used for the TLX ASPEC mirror? Their customer service is telling me they donít have one that would fit.
JR_Rider is offline
Old 01-13-2019, 08:31 PM
Registered Member
Blendmounts don't fit. I just returned one they said worked for us.
Old 01-13-2019, 08:35 PM
Registered Member
my blenmount fits just fine on my 18 ASpEC TLX with V1
Old 01-13-2019, 08:45 PM
Registered Member
JR_Rider's Avatar
I mounted mine at the top of the windshield on the driver's side. I used a modified Blendmount mirror tap cord.
JR_Rider is offline
Old 01-13-2019, 11:10 PM
Registered Member
Thanks,
Levell
Sorry, I'm not on that often and I didn't see your questions. From your recent setup, it looks like you have everything you need. However, to answer the question, my radar detector is powered with an add-a-fuse in the fuse box, not with the Blendmount mirror tap. Therefore, I didn't need to remove any trim pieces around the mirror.
I purchased a Blendmount model BBE-2031 radar mount with an Escort brand clip mount.
Old 01-15-2019, 03:40 PM
Registered Member
That's weird.......when I mounted mines it wouldn't stay secure. I called them and they stated that it won't fit since our rearview mirror is the same design as the MDX. Temp_A-Spec.....can you post pics of your setup?
Old 01-15-2019, 03:41 PM
Registered Member
[QUOTE=Carnage719;16364726]Sorry, I'm not on that often and I didn't see your questions. From your recent setup, it looks like you have everything you need. However, to answer the question, my radar detector is powered with an add-a-fuse in the fuse box, not with the Blendmount mirror tap. Therefore, I didn't need to remove any trim pieces around the mirror.
Carnage719.....which fuse did you tap into?
Old 01-15-2019, 05:13 PM
Registered Member
It's a tight fit on the rear view mirror neck because of the plastic shroud, but it does fit. Maybe you recieved a defective one.
I have to look, but, as you know, you have to contort yourself in the driver's footwell to get to the fuse box, so I can look this weekend when I have the time. I have written down on a note fuse locations 5, 12, 26, and 37, all 7.5A. All are only powered when the car is in accessory mode or on.
Also, I currently don't post pictures because I'm not signed up with an image hosting site. It was a long time ago when I used to post regularly on a motorcycle forum, so if there's a way to post pictures without using an image hosting site, let me know.
ablb454
14
04-12-2019 11:13 AM
princeo5
Fifth Generation TLX (2015+)
02-02-2019 07:50 PM
Katira
34
06-20-2018 08:25 PM
Sloppy305
05-15-2017 06:20 PM
rocket_pup
04-16-2017 01:46 PM
Quick Reply: 2018 TLX A Spec Radar Install
