2016 Acura TLX Technical Service Bulletins
2016 Acura TLX Technical Service Bulletins:
TSB 15-044 - 2016 TLX: TQI Information Applies To: 2016 TLX - 4-Cylinder 2WD: P-AWS, 8-Speed DCT - Base, Technology 2016 TLX - 6-Cylinder 2WD: P-AWS, 9-Speed A/T - Base, Technology, Advance 2016 TLX - 6-Cylinder AWD: SH-AWD, 9-Speed A/T, Auto Idle Stop - Technology, Advance http://www.urvi.net/forumfiles/SB/B15-044.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-044.PDF TSB 15-045 - 2016 TLX: TQI of the Navigation System Applies To: 2016 TLX - All with Navigation http://www.urvi.net/forumfiles/SB/B15-045.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-045.PDF TSB 14-025 - Timing Belt Chirps Applies To: 2015-18 TLX - ALL with V6 - ALL 2019 TLX - 2WD with V6 - From VIN 19UUB2...KA000001 thru 19UUB2...KA007635 2019 TLX - AWD with V6 - From VIN 19UUB3...KA000001 thru 19UUB3...KA005453 http://www.urvi.net/forumfiles/SB/B14-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF TSB 15-027 - LKAS Does Not Keep Vehicle in Detected Lane Applies To: 2015-16 TLX - Technology, Advance Package - ALL http://www.urvi.net/forumfiles/SB/B15-027.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-027.PDF TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T) Applies To: 2015-18 TLX - ALL with 9-speed A/T - ALL 2019 TLX AWD - 9-speed A/T - From VIN 19UUB3F..KA000002 thru19UUB3F..KA002947 2019 TLX 2WD - 9-speed A/T - From VIN 19UUB2F..KA000001 thru 19UUB2F..KA003475 http://www.urvi.net/forumfiles/SB/B15-039.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-039.PDF TSB 16-008 - High Pressure Fuel Pump Chirps Applies To: 2015-18 TLX - ALL with V6 - ALL http://www.urvi.net/forumfiles/SB/B16-008.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF TSB 16-011 - Product Update: Monroney Label (Hawaii) Applies To: 2015-16 TLX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-011.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-011.PDF TSB 16-012 - Transmission Function Improvements: Sensation of Surge While Braking, Slow Downshift Response at Low Engine Speeds, DTC P2638 and Other Listed Symptoms Applies To: 2015-16 TLX - V6 2WD with 9-speed A/T - From VIN 19UUB2...FA021489 and later 2015-16 TLX - V6 AWD with 9-speed A/T - From VIN 19UUB3...FA007728 and later http://www.urvi.net/forumfiles/SB/B16-012.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-012.PDF TSB 16-039 - Buttons Sticking on Audio-Navigation Unit (Day/Night, Settings, Navi or Audio) Applies To: 2015-16 TLX - ALL - ALL 2017 TLX - All except base - ALL http://www.urvi.net/forumfiles/SB/B16-039.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-039.PDF TSB 16-057 - Vibration Felt In Front Seats and Floor at Highway Speeds Applies To: 2015-16 TLX - ALL V6 - ALL http://www.urvi.net/forumfiles/SB/B16-057.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-057.PDF TSB 16-058 - Rubbing, Popping or Clicking From Front Door When Opening Applies To: 2015-16 TLX - ALL - ALL 2017 TLX - L4 2WD - From VIN 19UUB1...HA000001 thru 19UUB1...HA001763 2017 TLX - V6 2WD - From VIN 19UUB2...HA000001 thru 19UUB2...HA000874 2017 TLX - V6 AWD - From VIN 19UUB3...HA000001 thru 19UUB3...HA000600 http://www.urvi.net/forumfiles/SB/B16-058.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-058.PDF TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power Applies To: 2015 TLX - Tech/Adv - ALL 2016 TLX - L4 2WD Tech - From VIN 19UUB1...GA000001 thru 19UUB1...GA009841 2016 TLX - V6 2WD Tech/Adv - From VIN 19UUB2...GA000001 thru 19UUB2...GA009123 2016 TLX - SH-AWD Tech/Adv - From VIN 19UUB3...GA000001 thru 19UUB3...GA002269 http://www.urvi.net/forumfiles/SB/B17-003.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF TSB 17-011 - Product Update: TLX 9-Speed Transmission Warmer Applies To: 2015-16 TLX - All with 9-speed A/T - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B17-011.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-011.PDF TSB 17-012 - Product Update: TLX 9-Speed Transmission Warmer (Transmission Previously Replaced for Transmission Warmer Leaking) Applies To: 2015-16 TLX - All with 9-speed A/T - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B17-012.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-012.PDF TSB 17-015 - 8-Speed Transmission (DCT) Has a Bump or Hard Shift When Coming to a Stop Applies To: 2015–17 TLX - ALL L4 8-Speed Dual Clutch Transmission (DCT) - ALL http://www.urvi.net/forumfiles/SB/B17-015.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-015.PDF TSB 17-027 - Warranty Extension: TLX Transmission Chirps During 3-4 Shift, Poor Shift Quality, or Engine Overheats Because of Defective ATF Warmer Applies To: 2015-16 TLX - All with 9-speed A/T - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B17-027.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-027.PDF TSB 17-030 - Water Pump Seizes or the Drive Belt Is Shredded Applies To: 2015-16 TLX 2.4L - ALL - ALL http://www.urvi.net/forumfiles/SB/B17-030.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-030.PDF TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2]) Applies To: 2015-17 TLX - V6 Only - ALL 2018 TLX - 2WD (V6 Only) - From VIN 19UUB2...JA000001 - 19UUB2...JA003458 2018 TLX - SH-AWD - From VIN 19UUB3...JA000001 - 19UUB3...JA001898 http://www.urvi.net/forumfiles/SB/B17-034.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment Applies To: 2015-18 TLX - ALL with 10-way driver's power seat; ALL with 8-way passenger's power seat - ALL http://www.urvi.net/forumfiles/SB/B18-014.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-014.PDF TSB 19-003 - MIL Comes On with DTC P0716 Applies To: 2015 TLX - V6 2WD with 9-Speed A/T - From VIN 19UUB2...FA021489 and later 2015 TLX - V6 AWD with 9-Speed A/T - From VIN 19UUB3...FA007728 and later 2016-17 TLX - V6 with 9-Speed A/T - ALL 2018 TLX - V6 2WD with 9-Speed A/T - From VIN 19UUB2...JA000001 thru 19UUB2...JA011767 2018 TLX - V6 AWD with 9-Speed A/T - From VIN 19UUB3...JA000001 thru 19UUB3...JA005470 http://www.urvi.net/forumfiles/SB/B19-003.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-003.PDF TSB 19-011 - Safety Recall: 2016-18 MDX and 2015-19 TLX V6 Fuel Pump Applies To: 2015-19 TLX V6 - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-011.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-011.PDF TSB 19-012 - Knocking or Clicking From Engine During Cold Startup Applies To: 2015-18 TLX - L4 - ALL http://www.urvi.net/forumfiles/SB/B19-012.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-012.PDF TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward Applies To: 2015-19 TLX - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-017.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF TSB 19-049 - MIL Comes On with DTC P0420 Applies To: 2015-17 TLX - ALL with V6 - ALL http://www.urvi.net/forumfiles/SB/B19-049.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-049.PDF TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram Applies To: 2015-20 TLX http://www.urvi.net/forumfiles/SB/B19-059.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration Applies To: 2015 TLX - 2WD V6 9-Speed A/T - Transmission serial number above Q5J...60408 2015 TLX - AWD V6 9-Speed A/T - Transmission serial number above Q5L...25932 2016-20 TLX - 2WD V6 9-Speed A/T - ALL 2016-20 TLX - AWD V6 9-Speed A/T - ALL http://www.urvi.net/forumfiles/SB/B20-015.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF TSB 22-008 - Product Update: 2015–20 TLX PGM-FI Idle Stop Software Update Applies To: 2015-20 TLX - V6 SH-AWD - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B22-008.PDF http://techinfo.honda.com/rjanisis/p...nu/B22-008.PDF TSB 22-009 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop Applies To: 2015-20 TLX - V6 (SH-AWD) - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B22-009.PDF http://techinfo.honda.com/rjanisis/p...nu/B22-009.PDF TSB 23-009 - Engine Does Not Crank Applies To: 2015-20 TLX - V6 - ALL http://www.urvi.net/forumfiles/SB/B23-009.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF TSB 24-002 - Safety Recall: 2015–20 TLX Connecting Rod Bearing Applies To: 2015-20 TLX - V6 Only - ALL http://www.urvi.net/forumfiles/SB/B24-002.PDF http://techinfo.honda.com/rjanisis/p...nu/B24-002.PDF TSB 24-007 - Safety Recall: 2015–20 TLX (Without SH-AWD) Fuel Pump Motor Applies To: 2015-20 TLX (Without SH-AWD) - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B24-007.PDF http://techinfo.honda.com/rjanisis/p...nu/B24-007.PDF TSB 24-011 - Safety Recall: 2015–20 TLX SH-AWD Fuel Pump Motor Applies To: 2015-20 TLX SH-AWD - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B24-011.PDF http://techinfo.honda.com/rjanisis/p...nu/B24-011.PDF |
Originally Posted by EE4Life
(Post 15550479)
TSB 15-044 - 2016 TLX: TQI Information TSB 15-045 - 2016 TLX: TQI of the Navigation System |
^I'm not too sure if I can post here but does these TSBs apply to Canada as well?
Originally Posted by edmua6
(Post 15682702)
^Judging on a response in the 2015 Acura TLX TSBs thread, these TSBs do not apply here in Canada. Are you having issues with your TLX youngTL? So far I do not have any issues on my 16. *knocks on wood*
(Post 15683744)
FFS my 2015 does all of those things but its VIN is before the range listed. Ugh I hate this transmission (and Acura for not making it right).
(Post 16219748)
Added new TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment.
Hi,
Video had died, or just marked as private |
(Post 16503049)
Added new TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram.
Added new TSBs:
TSB 24-007 - Safety Recall: 2015–20 TLX (Without SH-AWD) Fuel Pump Motor TSB 24-011 - Safety Recall: 2015–20 TLX SH-AWD Fuel Pump Motor |
