2015 Acura TLX Technical Service Bulletins
#161
Forum Contributor
Received 1,391 Likes
#163
See the video on page 2 of this previous similar TSB 08-031 to hear the chirp noise/sound.
TSB 08-031 - Chirp From the Timing Belt Area
http://www.urvi.net/forumfiles/SB/B08-031.PDF
LinkDeny
LinkDeny
#164
Forum Contributor
Adding new TSB. Mods will need to merge it with the original post.
TSB 16-012 - Transmission Function Improvements: Sensation of Surge While Braking, Slow Downshift Response at Low Engine Speeds, and Other Listed Symptoms
#165
This TSB tells me that there is a hardware difference from the early builds based on the fact that the VIN range starts with a later production run.
#166
blah blah blah
#167
Summer is Coming
My VIN is 24993 and is an Aug 15 build. I don't have the hard shifting but I do have the 'feels like is stays in gear too long' issue. So I'm guessing that the 2015 transmission update happened in ~Jun 2015 production. Then they must have made a 2nd hardware update for 2016 cars. I think Sep 15 was the first month of 2016's.
#169
2015 TLX SH-AWD Elite BWP
Or Canada never gets them.. When I shown the TSB 15-040 to the dealer , they said it's American and not Canadian and doesn't apply. The Canadian ones are numbered as Kxx . Not sure where we can find them... and if the new one about transmission will have a Canadian version.
#170
Registered TL Owner
Rocket_man (02-28-2016)
#171
Forum Contributor
TSB 16-011 - Product Update: Monroney Label (Hawaii)
#172
Forum Contributor
TSB 16-008 - High Pressure Fuel Pump Chirps
#173
Forum Contributor
TSB 15-006 was revised. VIN ranges were updated. Mods to revise the original post with the information below.
TSXV6Guy (05-19-2016)
#175
I just heard about a new TSB that was posted about a software issue for the 2015 TLX and MDX. The following article was posted today...
https://www.cars.com/articles/2015-a...1420684642520/
#176
I was really hoping they had another update. I still think the software is glitchy and slow.
#177
Forum Contributor
TSB 15-040 - Firm 2nd to 3rd Gear Upshifts Under Certain Driving Conditions
#178
...yet my car's VIN is out of that range still and I still have the firm shift from 2-3. What if I photoshop the VIN range so it reaches my car? lol..
#179
The dealer was unable to install the update to my car due to a bug in acura's system. Acura was aware of the bug but it won't be corrected for 15 days or so. So I had to make another appointment. I kind of hope the update doesn't help and I can get an updated transmission. How many of you had good luck with the update correcting the 2-3 hard shift?
#180
#181
I don't know if you're following along in the Problems & Fixes sub-forum, but there's a thread about this there (with a ton of posts). Most of the people that have applied one of the first 4 versions of this fix have had mixed results. I don't know of anyone whose shifting issues were solved completely by it. Some claim it made the shifting worse. My shifting was horrible initially after the fix, but got better. It didn't fix the harsh shift, however. Again, this is with the first 4 revisions of this fix. This is the 5th revision. Who knows... maybe there's a miracle in this attempt, but from what I've seen, the only thing that has solved this "normal" behavior has been a transmission replacement, and not all of us have been granted the privilege of that by the Acura hierarchy.
#183
Dropped off my car yesterday with a different dealer to have them take a look at my tranny complaint, then this sb comes out right after. Already notified my rep this am about the sb update... fingers crossed
#184
Hallelujah!
#185
I'm in the same boat. Seems like a pretty narrow range of VINs relative to the amount of cars having the issue. Hopefully others have an easier time getting their transmissions replaced with this updated TSB.
#187
Indeed they did. From the 16-012 TSB:
2015–16 TLX V6 2WD with 9-speed A/T 19UUB2…FA021489 and later
2015–16 TLX V6 AWD with 9-speed A/T 19UUB3…FA007728 and later
So 15-040 should be the same vins, but "earlier" rather than "later"
Fortunately(?) my TLX fits either way
#188
Funny thing... i also compared the vins with 16-012 to see if the fix is for the vins not included under 16-012. This should make the tranny replacement case stronger... i hope.
#189
#191
#192
Yup same here. Looks like anything built in 2014 (I got mine in Nov 14).
#193
Forum Contributor
TSB 15-040 was revised. The VIN ranges were updated. The original post was revised with the information below.
Applies To: 2015 TLX - V6 2WD - From VIN 19UUB2...FA000001 to 19UUB2...FA021489
2015 TLX - V6 SH-AWD - From VIN 19UUB3...FA000001 to 19UUB3...FA007728
Added new TSB to the original post.
TSB 16-039 - Buttons Sticking on Audio-Navigation Unit (Day/Night, Settings, Navi or Audio)
TSXV6Guy (08-21-2016)
#197
RE: TSB 16-012 (http://www.urvi.net/forumfiles/SB/B16-012.PDF)
Just had the dealer do this update and the car finally feels as responsive as expected.
#198
Ha. I already know what this one is. It's been doing it on my car for a while and I spotted what was happening. I never took it into the dealership to get it fixed simply because I'm sick of taking this thing to the dealership. lol. I guess I'll give them some stuff to work on now... assuming I haven't worn the the rubber piece down with the constant clicking when opening and closing the door. Can't say I've noticed it in a while. Either I've gotten used to it or it wore or tore off.
#199
Unfortunately, I have a strong feeling it's more a matter of when, not if.
