my best 1/8 run so far...
THE J35A2...
I'm car #8741
me and some friends will be heading to Fontana this saturday. hope i can do the same or better, this timeslip...
THE J35A2...
Originally Posted by Accord_V6_400m
Damn your posting this everywhere aren't you :p
4drs just wanna have fun!
Originally Posted by SIRSIG
so are you going with us tomorrow? PMed you...
In any case I wish you guys the best of luck and hope that everyone remains safe, intact and secondly that nothing on your cars break.
THE J35A2...
Early with you guys nah, was going to go later and watch but my bro is going to be seeing someone for their suspension so i'll be riding shotgun with them. I'll let you guys know if plans change and I can drop by, although in this case drop by is almost an hour away
very nice run....those are the numbers I was hoping for. I've only taken it to the track once and couldn't break 9.0 on a hot and humid Fl. night. Now that it is cooling down I am hoping to get into the 8's. Anyways....good job. Clinton
THE J35A2...
Thanks....we'll see here in the next couple of weeks. I know my biggest problem is that I'm not tuned. Closest shop that I can find that will tune E-Managment is a hour North of ATL. Thats around 6hrs away.
I am glad to see that you made 8.5 as I truely believe with our set up that it would be possible to reach that goal (especially with a 6 speed) with hardly any problem.
Just a side question for you. Have you given any thought to adding methanol to the set up?
THE J35A2...
hope you didn't go cause we all left early as in 11AM early my car didn't run right. it felt like there was no vtec. i checked the oil, it was low. only got 1 run and both Dave and Sean (well, you might already know by the time you read this...) broke their axles
Heard about the axles, really sucks glad I didn't buy any.
As for methonal injection you can tap the intake elbow for it, also do you remember the one guy that rac his A/C feet line to the Comptech SC icebox?
THE J35A2...
Yeah you got to watch out for the oil consumption, the PCV system just spews it back into the intake like no other, thats why you should get a catch tank to collect all the oil and clean up the intake charge a little for better tuning, power etc.
THE J35A2...
Now you got me wondering....
THE J35A2...
Originally Posted by JBlueCLS6
Maybe my car was a freak but I ran a 8.85 @ 85.95 using less boost.
Are you taking it up to redline?
I miss hearing that SC'er whine...
SC whine is very addictive... another way to get high
Just courious (maybe its a manual thing) but why were you redlining 3rd gear? As an auto I was either getting across the 1/8 mile line in second or just shifting into 3rd when I crossed. Of course i see that you ran at 86mph and I was only averaging 81mph.
Also what do you guys think. When I ran the 1/8 mile I simply just put the car into Sport Shift and didn't shift till I red lined 2nd. Would I be better gate shifting (using the 1,2 at the bottom? Would I get a better time possibly shifting into 3rd before I red line 2nd?
Sorry to get alittle off topic.....Clinton
my car felt weird during my run at Fontana, no power at top end. would you help me hook up one?
glad i didn't jump on that too... i have let other guys have 'em try first and see if it works for them or not.
i guess i can, but isn't hooking up the A/C line better and the same concept than the meth and doesn't cost much?
AC line doesn't even compare to methanol injection the temp difference is pretty big.
Clean you air filter too Did you ever change out that fuel filter housing? It helped me out
THE J35A2...
I'll help you out if you want just bring that damn spare fuel pump
yeah, but can it be controlled? i heard a spurt of that cold air can give you richness...
air filter's clean . no, but that's next..
THE J35A2...
If you need a meth kit. I'm selling my Snow Kit.
Originally Posted by Joe5.0
Nice run, thats a 13.3 in the 1/4
13.3 will be fine for me
i''ll bring it next monday to you or if you can drop by my place we can do it there...
More air as a result of it being colder and denser would usually make it go leaner unless whatever compensation method you had over does it, usually factory controls aren't good enough to do so, like opening up your exhaust usually leans it out, without the ECU really doing much about it. Although who knows, there are so many variables. Not sure to what extent meth acts as fuel to enrichen the AF ratio.
THE J35A2...
with the sc, redline comes quicker and once you shift to redline, the rpm drops back at where the vtec (or near the vtec) is, so your power stay linear.
With the wheelhop, spinning of tires, etc you're getting on a fwd car, you tend to let go off the gas a bit to gain traction again, so you can't afford dropping your rpm lower than your powerband to get traction back or you would get bad time.
i would suggest you experiment on your runs. try SS, normal auto shifting, etc... and stick to the one that gives you the best time...
I would prefer not to do the drive since I don't have a job now to afford spending that much gas, especially if I get I stuck in traffic.
i got my explanation in reverse then
all i need is something to cool my sc so i'll try that A/C upgrade for now...
It's about gears between auto and manual (drivetrain power loss on auto) with an upgraded auto tranny, your time can be better than a manual.
alright, i'll drop by your place if i have a chance. find a job at Honda dealer so we can get discounts
THE J35A2...
Originally Posted by typeR
from that mph id say 13.0...my best is an 8.5 i think 8.558 however that was @ 81.5 mph went on to a 13.306 @ 105.83 ...the gearing will make a diff , but that could end up a 12 second run
but, seriously my run wasn't close enough compare to yours
on Auto maybe, but on a 6spd with over 330whp it's pretty hard to achieved it. i guess i gotta get more practice before i see 12's... I mean i only started racing my car last Jan. We don't have a decent 1/4 mile out here, the only decent track we have only opens up every first Sat of the month sometimes doesn't. and it has 400-500 cars...
THE J35A2...
your run was exactly on par with mine except for 5 MsPh faster which is huge
yeah but yours is NA
i've trapped 91.02mph and had a couple of 89mph at the same 1/8 track before, probably my average overthere is 86mph.
SinCityTLX
10-07-2015 01:24 PM
