Yumcha Buys Car, Arrives After World Ends, Abuse of Vehicle Ensues
#521
Not sure if it's veneer. But, any car from the last couple of years will have something like it if there is a mini-digital display to output what the cabin temperature is, the setting for the vents, and etc.
#522
Yeah, this would be similar: https://www.amazon.ca/dp/B00068KU1K/...v_ov_lig_dp_it
Apparently, it works on clear, plastic trim which I believe is the surface of the display between the temp. knobs. Your Audi would have that same mini-screen too, Mike. You know which one I'm referring to, right? It's not an LCD surface as far as I can tell.
Yumcha (04-16-2019)
#524
Don't touch the fucking screen Yummy.
You can turn a minor annoyance to something much worse.
Okay, it's probably not rocket science and you can just do some hand polishing with something very mild.
I'm sure those plastic polishes are fine.
I don't know, I would want to do it for you...not let you go nuts on your own.
Yumcha (04-16-2019)
#526
Try putting brake fluid on it.
I've heard it gets rid of minor scratches with minimal effort
#527
The following 2 users liked this post by Yumcha:
rockstar143 (04-16-2019),
ttribe (04-17-2019)
#528
Null and proud of it
#530
thanks man...just speaking from my own experience but guiding a buddy to try a bunch of different untested chemicals on the interior of his new
expensive car over the internet...if he came back to us saying something I personally told him to try fucked it up. I would feel badly.
Plus, I've fucked things up worse so many times.
Yum is taking the right approach. It's a car...a little wear and tear here and there won't cause you to stare. if you dare.
Yumcha (04-17-2019)
#533
The only reason I looked them up was because my stealership told me to try that place as their R8 customers go there to clean their vehicles.
Yeah, my S5 was out of place.
#535
Not this shit again..
Toothpaste and petro jelly is a shitty solution
You're essentially using the toothpaste as an abrasive to grind the surface and petro jelly to fill in.. total shit idea.
Fundamentally sound, but shit execution
I'd use a magic eraser with water and gently remove the smudge, light strokes until it's gone
If it's a real scratch, you're fucked, you need a filler that hardens and buff it out
I think film is overkill for that little screen.
Magic eraser is melamine foam.
I wouldn't even compare it to those sandpaper foam pads.
Sandpaper is dense and rigid, melamine foam is porous and flexible.
It's abrasive, but the sensitivity of it isn't comparable to sandpaper.
H, If you have doubts, rub your dick with it..or some shitdick's screen at work.
Just make sure you're only applying it over the xfer mark with water.
Light and even until gone with moisture.
Again, it's not to be used to remove scratches.
What H is describing is a transfer mark / smudge.
He's using the magic eraser to remove the material on the screen, not sanding down the screen.
Yumcha (04-17-2019)
#536
You're definitely not going to make it worse.. you're just gently rubbing the screen with a moist magic eraser pad to remove the transfer mark.
Yumcha (04-17-2019)
#537
I can't even..
The fact that Yumcha seriously responded to this should be flattering to you MM.
Yumcha, you lose all points. May the gods be in your favor.
She soaks it all up
Yumcha (04-17-2019)
#538
Cheesus crust.. I had to catch up on all the drama..
That's what you get Yumcha.. never let a van cut in.. never let anyone cut in.
You have an Audi, you're supposed to be an asshole.
Reposting here..
Reposting here..
Yumcha (04-17-2019)
#539
Thanks, dude.
So, in short, Maj doesn't think using the Magic Eraser will be detrimental so long as I am super gentle in the application and with water.
Bah, I should just fly the guy out here so he can hold my hand/crotch/nipple while I applying the bar to the mini-scuff.
#540
It already bugs the fucking shit out of you
If you fuck it up, use a filler and buff..
or plastidip.. done.
#541
Or you could just take it in to service for some bullshit
claim the shit happened in their possession
and they'll address it.. probably buff it out
#542
I'm sure if you were nice
They'd take into consideration that you paid sticker
and take care of it for you to make sure you buy the next ride with them sticker
I don't know these things.. too cheap and generally don't give a shit
Ask J about my curb stops
rockstar143 (04-18-2019)
#543
H... I showed a sweet Durango SRT in a graphite (bruiser grey) with red interior to the misses..
She was like hell nah red interior.. bro...
#547
Red interior FTW... You know it is legit when Acura and Camry all start putting red interior in their cars.
You know what the problem was... you showed her a Dodge.... with red interior... show her a BMW with red interior, she will be 100% guaranteed to have a different opinion.
#550
#552
Why do you think I need a Durango dummy
Maybe I should just move onto your family
#554
you know the awkward silence when there are too many bad jokes...... Good thing this is AZ, i can just close the browser and go see what is on CNN
#555
That's the joke!
#556
Received 7,772 Likes
Oh boy. This thread about to get moved to OT.
#557
If ain't awkward, it ain't shit posting
#558
Bring saintor back!
Make Acurazine Great Again
#559
