Yukon needed a full tank of gas...
#82
The V wouldn't have left the parking lot lol. But that's not what it's for.
I know right? I'll have GoPro footage soon. Just need to pull it and edit.
#84
Just bought the upgrade kit to go to HID. The piss poor headlights on the Jeep need to go especially because most of my driving is in the dark thanks to the stupidity that is DST.
RPhilMan1 (12-01-2016)
#85
https://www.theretrofitsource.com/je...to-xb-led.html
for fogs
and see if any of these fit: https://www.theretrofitsource.com/co...-housings.html
for fogs
#86
^ None of that fits the Cherokee, most of it is for the Wrangler. The only parts that will fit across platforms are the fog lights as they are the same for the Cherokee and Wrangler. I bought a Cherokee specific set that has a PWM module with Philips bulbs so I'm excited to get it installed.
#87
I realized that I haven't done an update in almost two years so here goes...
1.) Cherokee is now the wife's car, I swapped to a Golf R (most of you know this already)
2.) After having this thing for three years, I would not recommend buying a Cherokee, we are now actually looking to get something else.
3.) The first two years 24k miles were largely trouble free, the past year 12k miles were definitely NOT trouble free.
4.) So far, we've had the following issues since new.
- CEL caused by loose coolant temp sensor, not a huge deal but annoying
- Multiple recalls for random things, again not a huge deal but annoying
- Both front struts replaced due to rattle sounds
- Rear diff and control module replaced
- Both rear CV axles replaced
- Transmission valve body replaced
- Numerous transmission software flashes to resolve rough shifting (finally good now but still sometimes quirky)
- Rattling door speaker replaced
- The newest issue for today is that it does not detect the key fob and won't start with either key. Now I need to go have it towed to the dealership.
That said, the off road capability is out of this world for a compact crossover. You can tackle some serious shit with this thing.
#88
So, is the JK replacing the Cherokee? Or is the wife getting something else & the JK will be your toy?
#90
Wife wants an Outback or CR-V or something along those lines. Will probably lease it as it's likely our family may change in number in the next 3 years.
#91
The Third Ball
Received 4,829 Likes
Before you go towing to the dealer for the FOB...pull the fuse and reset it. I had it happen one time in the Durango, problem solved.
#92
Alltrack? Haven't driven either of the above, just biased against CVTs. Tough to beat an Outback & should work well in Minnesnowta.
#93
True, the Alltrack would be a disappointment by comparison to the R.
Maybe a V60XC, or Regal TourX as comparison shopping to the OB.
#95
It's entirely up to her this time. I think she's set on something super reliable this time so my guess is we'll end up in a Subaru, Honda, or Toyota...the Volvo is likely out and, because she grew up in a really rural area, the Buick is definitely still seen as an old person car. It's ok, she does enough for my car habit so I'm staying completely out of this one.
#96
Makes sense, lots of options out there. It's a good time to be in the market.
#98
The Third Ball
Which fuse did you pull? Or rather what was the fuse for?
She wants an AWD and the Outback is actually quite large. My mom has one and I know of quite a few others that do too. The Subaru CVT is actually not bad, it's similar to Honda's. The only one I'd avoid is the Nissan CVT which is a steaming pile of garbage. The Alltrack is basically a slow Golf so not really looking to have two of the same cars.
#99
Maybe get an older Jeep for cheap to go 4-wheeling on the weekends.
#100
Yikes, not a good year at all for reliability it seems. No wonder FCA products still stay near the bottom tier in rankings/reports.....sorry about all those issues (sounds like a nightmare 12k miles). But the off-roading is sure fun though!
#102
I'm just gonna follow your lead. You do much more math than me...so I can trust you.
Some of the ones that pop up that I like are the YJ, the X and there's another one I can't think of
https://miami.craigslist.org/pbc/cto...646696325.html
#103
Honestly, if I was gonna get a 4-wheeler and beat it on the trails...I'd go for bit older and cheaper...I hink even 2012+ might still be fairly up there in terms of not much depreciation. I've been hearing that Wranglers are notorious for holding their value.....
Aman (08-09-2018)
#107
Did this issue present later in life or early on? Was it something that if it's not there, it'll never be there sort of thing? Good to know and I'll keep an eye out, thanks!
#108
That YJ looks like it has been beat to hell and back. The XJ is a Cherokee and does not come with removable roof and doors, that part is key.
#109
The Third Ball
So did you try the fuse?
#110
The Third Ball
Thats the other thing they say. Get both fobs away from the vehicle for 7-10minutes so the computer resets.
When mine happened I think it was combination of things happened to quickly and I "over burdened" the computer. I dont remember what I had done but I did remote start, then I think I accidentally hit the unlock button WHILE my hand was opening the door, which activates the keyless entry...etc. I tried walking away to reset the computer but I didnt have time to wait, so I did a quick search, found the fuse, and reset it and bob was uncle.
I was initially scared shitless because I remember the first couple years of challengers had some FOB issues with bad modules and Im well out of warranty. Thankfully, this was simple.
#113
The Third Ball
#114
The Third Ball
You know who drives G wagons? Dudes with too much money who think they are gangstas and blondes with yippy dogs on their laps who run stop signs.
#115
J M U ... DUUUKEESSSS
Not sure what build date ranges of the 2012s were known to have the ticking cylinder head, but it impacted a good amount. And I think it threw the code within the first 10-15k miles and Jeep fixed it under warranty. Worth asking if that was replaced if you're shopping around for a 2012.
If you like a few more interior improvements, go with a 2013+. The 2013s had new seats, dimming rear view mirror, dual windshield washer nozzles and a couple other minor improvements. I had a 2013 JKU, no issues with the cylinder head and no issues during my 5 years of ownership.
Here's a long thread on the ticking cylinder head for the 2012s - https://www.jkowners.com/forum/stock...pentastar.html
As for the JLs, some dealers are offering 5-6.5% off invoice... 5% seems to be the norm, but Wranglers are getting really expensive.
#116
So as of tomorrow, we say good riddance to this POS. Picking up a new car for the wife tomorrow. Well we already bought it, just going to get it tomorrow after all the PDI is done.
#117
Wow I didn't realize you had so many issues. I was like, good riddance?
I noticed you didn't mention what vehicle is replacing it, so we'll be expecting pictures first thing.
#120
Pics tonight or tomorrow (whenever we have access to some fucking daylight) but it's a 2019 Subaru Outback 3.6L.
The fun part is that we initially wanted an Ascent, Pilot, Highlander, etc that can tow a lot and have a ton of space on the inside. After doing more research, the Ascent is on its first model year so no thanks, the Pilot's higher trim levels come with the ZF9 so no thanks, the Highlander is more expensive and doesn't come with LED/HID so no thanks. What we got from doing the math is that we could buy a high end Outback to daily AND and old Yukon (or similar) to haul shit around for less money, insurance, and registration than any of the bigger crossovers. So...looks like I'm back in the market to get another Yukon Denali! It's the only vehicle I legitimately regret selling so I'm looking forward to getting another one. The others I miss but don't regret.
