why are g35c and g35s both called the g35?
It doesn't seem like they really have much in common, so why are they both called the G35? They look completely different, and have different engines, transmissions, exhaust, frames, all panels are different, wheels, suspension...
seems like the only things they share are stereo controls and steering wheels. and the emblems on the back.
acura cl and tl have a lot more in common, and they got different names.
They use the same motor. The exhaust is different, but the coupe is marketed for as a luxo-sports coupe. So it gets a more free-flowing exhaust, larger wheels and brakes, etc. They don't have to look the same to carry the same badge.
They have the same engine except for ecu tuning. The transmissions are identical with the older Q45 and 350Z. Suspension is the same they just use different shocks and springs. Exhaust is different but from the headers area they are the same. Essentially you could use almost all the same performance parts that are used on the 350Z. They purposely designed it so that it wouldn't share any similar panels because they wanted it to be a bit different in that aspect. Look at the BMW 3 series. They're all 3 series except for "i" and "Ci". People will know of the G35 as Coupe or Sedan. The interior is very closely similar too. Yes, the seats are different, the grab handle is different and there are some other bits and pieces but they are very similar in keeping costs low. If you didnt already know they have the same platform, the FM platform. This is the same platform used for the 350z and FX. The G's is stretched a couple more inches as the wheelbase is bigger. They both are of sporting nature yet they wanted a similar lookin body style, if you get my drift. The difference would be the I30, not intended to be sporting as much as the G's.
Originally posted by BEETROOT
isn't the coupe a 280 hp v6, sedan is 260 hp straight 6?
sedan has awd, coupe doesn't...
Hey, the Accord coupe and sedan look different too.
Re: why are g35c and g35s both called the g35?
OMG, You obviously have no clue about the car.
The cars are identical except for the sheet metal. Actually the 350Z is the same CAR! Same Engine, same transmissions, brakes, exhaust, suspension.
Beware of leakage
Originally posted by mantis23
3.5 liter engines.
follows in line with their naming schema
I20
J30
G35
M45
Q45
3.5 liter engines.
I20
J30
G35
M45
Q45
Mr. Beetroot sir, were you looking for something more like the way Yota did the Camry: Camry sedan, Camry Solara coupe/conv. ?:P
I always thought infiniti did a poor job naming the M45 and the G35c. i thought that they should have called the G35c the M because there was an M30 coupe convertable deal a while ago. and the M45 should have been the J45 because the J30 sport sedan thing they had a while back. this way there isnt the "G35" ambiguity. btw, the G has always been a sedan with the G20.
Re: Re: why are g35c and g35s both called the g35?
Transmission I wasn't sure about...but sedan has AWD coupe doesn't.
coupe has sequential multi-point fuel injection, sedan does not have this listed
standard brakes are not the same (small difference in size), and coupe has the brembo option sedan does not
wheels are different
exhaust is different in the back. it may not be functionally different, but coupe has dual in the back and sedan has both pipes on one side, so it has a completely different look.
plus they look completely different.
Re: Re: Re: why are g35c and g35s both called the g35?
Infiniti website gives different hp and tq ratings for the coupe vs. sedan, with no explanation. I assumed different engine.
1. Sedan are RWD and with AWD as an option.
Brembo is not an OPTION for coupes. they are just standard on 6spd and You can not buy brembo for automatic as an option
Sedan acutally has dual too.. except coupe has one on each side and sedan has both of them on the left.
Sedan dynos the same as the coupe. It has everything the Coupe has including the multi-point fuel injection.
Standard brakes are the same as the 350z and g35c standard brakes.
If you think they look completely different, go get a pair of new glasses. lol
And the jury's out on whether or not the "280hp" G35C is any more powerful than the "260hp" G35S, seeing as both seem to post the same performance numbers WITH identical trannys.
$.02
Re: Re: Re: Re: why are g35c and g35s both called the g35?
Originally posted by oonowindoo
________________________________
and I said I know the exhaust is functionally the same, but they ran it down one side in the sedan and split it on the coupe.
and they look nothing alike. all the lines are different.
and the reason I started this in the first place is a friend of mine who has the g35c just got a g35s as a loaner. he asked me why they are called the same. he said they drive like completely different cars and look like completely different cars. he said the interior is completely different and they have different stereos.
he doesn't know jack about cars...but his impression, as a g35 driver, was that the sedan is very different from the coupe.
Originally posted by tmk70
Jesus, Beetroot just asked a question, man...he didn't claim to be an expert on the car. Don't be a dick.
thank you kind sir.
I don't know shit about the g35 except what I read on the infiniti website
cls > g35
thank you kind sir.
cls > g35
thank you kind sir.
cls > g35
That said, G35 > CLS :P
Originally posted by Infamous425
man you're dumb! i cant believe u think nissan uses a straight 6
there musta been 345234525635 threads on both the g35 coupe and sedan on this forum thought u woulda read one of them
this from a guy who drives a CRV :ghey:
and no, I didnt read any of them.
Sedan dynos the same as the coupe. It has everything the Coupe has including the multi-point fuel injection.....
While there is no much difference in 6MT between both the 5AT show actual difference.
The 5AT sedans typically dyno stock around 209whp (due to restrictive ECU as well as exhaust) while 5AT coupe stock show around 220whp . Of course that can be changed (for sedan) with Technonsquare ECU reflash and say Stillen exhaust and you'll have nice 225-230whp but there is the difference between the coupe and sedan in 5AT stock form. But who cares? that what mods are for
Re: Re: Re: Re: Re: why are g35c and g35s both called the g35?
The exhaust is exactly the same on both cars except where it hits the muffler. The muffler is on one side of the sedan instead of 2 outlets on the coupe. Lines might be different, because of 2 door vs 4 doors, but it looks very alike. Interior IS EXACTLY THE SAME. Your friend needs glasses. Stereos are the same except speaker placement.
well AWD is not an option on the coupe, and you can't get brembos on the sedan.
Re: Re: Re: Re: Re: Re: why are g35c and g35s both called the g35?
Originally posted by Chief F1 Fan
How bout the 911? Technically a 996 but w/ 2wd, awd, turbo, non turbo (GT-3); targa, convertible
Originally posted by Tom3
someone must have a seriously small penis.
So does every other Nissan brand and model. Not to mention Honda, Toyota, GM, etc. You might want to pick a different technical term to draw the parallel for the cars than one which is so generic it is akin to Kleenex.
MPFI is used on all cars today. No one is using TBI, etc. Maybe the cars have similar ECU mappings and use the same size injectors, etc. But I suspect the Maxima and Altima are very similar too but are certainly different vehicles.
BTW, what is the next flavor of the week?
they have the same headlights and grill and u think they look nothing alike
i dont drive a CRV learn how to read
Do you have any clue at all?
Originally posted by scalbert
AND.....
AND.....
