Welded Axle Nut?!
Welded Axle Nut?!
I've been hearing clicking noises when I drive (lower speed) so I did my research and I've diagnosed it as a bad CV axle.
I tried to replace the driver side CV axle today on my 2001 Honda Accord EX (4 cylinder). I looked at a video and looked pretty straight forward. It looked like the hardest part was removing the axle nut and pulling the axle from the transmission.
When I got to axle nut, I saw a little crinkle on the nut which was also shown on the video, but I also saw that the about 20% of the nut was welded on purposely to the assembly! Now the welding wasn't part of the video. Is it normal for the axle nut to be welded to the assembly? I tried to chip it away, but I gave up because it was way too much. I shot the nut with 500 lb/ft torque and the thing wouldn't budge due to the weld.
How in the world do I get this thing loose? Maybe I need to take it to a shop and have them cut the bolt?
Well, I would but the nut has been partially mutilated by me chipping at it. One of the octagon sides fused to the axle shaft either by a weld or it simply melted and fused itself. If you worked on your axles before you'll know what I'm talking about.
My car has over 215k miles. I am pretty certain the two metals fused. Maybe they fused because the car is so old??
One more round of chiseling and I guess I have no choice but to take it in. I love this car even if it is beat up to death.
So I just checked the passenger side axles and the passenger side nut is not fused. I must've replaced the driver side CV axle about 100k miles ago when I blindly said OK to all dealer diagnosis. This was many years ago before I started working on my own cars.... This proves dealers can't be trusted (assuming that the dealer welded the nut)
Unofficial Goat
The first thing I did was to undent the little crinkle thingy. Well the impact wrench that I used was borrowed from a neighbor who is a bus mechanic and he said his impact wrench is a super impact wrench that loosens bus wheel bolts. It's suppose to be rated at 650 lbs/ft. Maybe it wasn't strong enough, but then again, the more i chiseled it the more I noticed it was welded. Probably welded on purpose from what you are telling if these things don't get fused over time.
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
