Tyler's Owdi B5 S4 Build & Update(s) Thread
Old 07-19-2017, 06:52 AM
  #1161
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
I wonder if your car makes as much power as my 2.0t?! (the t is for turbo on mine).
Old 07-20-2017, 12:22 PM
  #1162
svtmike's Avatar
Received 3,863 Likes on 2,030 Posts
In Park or Neutral, sure.
Old 07-20-2017, 12:31 PM
  #1163
Mike, you are very savage.
I can only surmise that you are extremely jealous of my Audi.
Old 07-20-2017, 05:27 PM
  #1164
svtmike's Avatar
Who isn't?
Old 07-20-2017, 05:51 PM
  #1165
Turd Polisher
TylerT's Avatar
Received 3,006 Likes on 1,514 Posts
Originally Posted by svtmike
Who isn't?
I don't think you're jealous of his Audi, I think you're jealous of his innie.
Aman (08-25-2017)
Old 07-26-2017, 03:22 PM
  #1166
Rawr.
Marcelechka's Avatar
Old 07-26-2017, 03:28 PM
  #1167
Turd Polisher
TylerT's Avatar
Marcelechka (07-26-2017)
Old 07-26-2017, 03:38 PM
  #1168
Rawr.
Love that movie!
Old 07-26-2017, 04:24 PM
  #1169
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
Wow, the car came together nicely!
Wait.. where are the tintz?
TylerT (07-26-2017)
Old 07-26-2017, 04:44 PM
  #1170
Turd Polisher
TylerT's Avatar
Thanks! It sure has gone through a transformation within the last year.
No tintS as of yet and don't really plan on getting them for awhile - I'm still saving for the remaining items for the build & preparatory items for the long process of pulling the motor & trans.
Old 07-26-2017, 04:55 PM
  #1171
Received 5,829 Likes on 3,850 Posts
Doing a routine oil change I see?
TylerT (07-26-2017)
Old 07-26-2017, 05:00 PM
  #1172
Turd Polisher
TylerT's Avatar
Partially true, oil will be changed when the motor is pulled
Need heavier oil for them larger turbskies
Old 07-26-2017, 07:03 PM
  #1173
oonowindoo's Avatar
I heard this is the size you are getting... what kinda oil are you gonna be using?
Old 07-27-2017, 05:47 AM
  #1174
Canola!
Old 07-27-2017, 12:28 PM
  #1175
oonowindoo's Avatar
Old 07-27-2017, 12:29 PM
  #1176
Received 8,582 Likes on 6,629 Posts
Peanut (nis) oil works way better
Old 07-27-2017, 12:32 PM
  #1177
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Don't be a dummy, thoiboi. There's no such thing as penis oil, regardless of what that guy in the back alley keeps telling you.
Ya, you know, when he keeps telling you that you need to lubricate the shaft with penis oil, but the only way to get the penis oil out is by stroking the shaft for a few minutes... it's not true.
ask me how I know. I've been using that technique with the ladies, at the bar, for a decade now.
Old 07-27-2017, 01:01 PM
  #1178
Rawr.
Old 07-31-2017, 10:38 AM
  #1179
Turd Polisher
TylerT's Avatar
0W40 is generally what is recommended for a K04 car.
Old 07-31-2017, 11:01 AM
  #1180
Turd Polisher
TylerT's Avatar
UPDATE:
ETH FO is down at the moment for maintenance and a new addition.
My car has been hesitating & shuddering under boost in 4th / 5th gear - ran codes EGT sensor faults came up .. so I stopped by a friends place on Saturday to pickup some used EGT sensors for $80 ($520 from ECSTuning.com ) .
Turns out he had a garage full of parts and I walked out with a little more than I had bargained for .
Dat license plate doh
Picked up:
- New o-ring for APR Bi-Pipe ( , I really needed 2, hopefully making a return trip today / tomorrow)
- Used OEM Dual Mass Flywheel - sending off for resurface so when the motor is pulled, it'll go right into the car rather than waiting on that turnaround time.
- Redesigned PCV Spider hose
- 2 x EGT Sensors
Walked out of there for $160 - not too bad
How the ETHFO sits now:
As of right now, OEM plastic bi-pipes are out of the car, new single solid piece will be installed once I get another o-ring.
Nice thing about having a solid metal Bi-Pipe is you do not need to worry about the failure prone throttle body boot anymore - bolts directly to the throttlebody.
Now, onto the EGTs:
Keep in mind, these sensor housings sit on the back of the engine and the shielded wiring goes down to each downpipe - the Passenger side EGT sensor is very easily replaced, roughly a 30 min job. On the other hand, the driverside requires cutting a 17mm wrench in half or removing the downpipe heatshield which is a total PITA. Expected to take between 1 hr - 1.5 hrs .
Spider hose assembly replacement should take anywhere between 1hr - 1.5hr as it's not plug & play - more hose clamps will be needed and I'll have to reuse some of the OEM spider hose fittings on the back of the intake manifold.
I should have a lot more time to work on it tonight, hopefully I can knock out it out.
Marcelechka (07-31-2017)
Old 07-31-2017, 11:19 AM
  #1181
Mr Hyde's Avatar
Car's looking great! Love following this build.
Your pic of the car above with the front bumper off is literally what my car looked like a few months ago when I changed out my HID bulbs; LOL
TylerT (08-02-2017)
Old 07-31-2017, 12:18 PM
  #1182
Rawr.
That plate tho!
Still on the hunt for something clever myself; 5 letters.
Old 08-01-2017, 11:54 AM
  #1183
oonowindoo's Avatar
Let's talk about your friend's wheels
TylerT (08-01-2017)
Old 08-01-2017, 01:06 PM
  #1184
Turd Polisher
TylerT's Avatar
Yeah ...
Funny thing about that - the other 2 wheels on the other side of his car are the original finish (silver) - he was trying out a new color and he ultimately wanted to take a different direction.
TBH - I think with spacers it would look much better.
oonowindoo (08-01-2017)
Old 08-01-2017, 01:13 PM
  #1185
oonowindoo's Avatar
or a different color The wheels are nice tho... Works?
Old 08-01-2017, 01:15 PM
  #1186
Turd Polisher
TylerT's Avatar
Driverside EGT sensor was a pain in the ass to remove but I finally got it after about 45 minutes - RIP 17MM wrench - so happy, I didn't need to remove the driverside downpipe heatshield after all, I managed to get at it from the bottom
Cutting the wrench in half & making it a line wrench made all the difference - there's very little space so a short stubby tool is all you need!
New EGTs are in the car and I plan on tackling the spider hose tonight. I have gaskets on the way, but I'm thinking of swinging by Lowes and maybe I'll get lucky .. we'll see.
Old 08-01-2017, 01:16 PM
  #1187
Turd Polisher
TylerT's Avatar
Honestly, I am really not sure. I've always loved the mesh look
Old 08-01-2017, 01:26 PM
  #1188
oonowindoo's Avatar
it looks like the same wheels as our In house VIP Authentic ILX guy.
is he running staggered setup?
Old 08-01-2017, 01:30 PM
  #1189
Turd Polisher
TylerT's Avatar
Same wheels yeah, but the owner is way less of a douchenozzle
Pretty sure he's on a square setup.
Old 08-01-2017, 01:37 PM
  #1190
oonowindoo's Avatar
I am pretty much he is much easier to talk to and have more financial sense
From the picture it looks the rear has bigger lip... or is it because his green color is blinding me...
Old 08-01-2017, 01:43 PM
  #1191
Turd Polisher
TylerT's Avatar
I looked at the picture and pretty much came to the same conclusion lol.
So ... when are you selling the BMW for something more troublesome?
Old 08-01-2017, 03:31 PM
  #1192
oonowindoo's Avatar
Well..... i asked to be less reliable twice already with BMW and so far it has failed and they have been proven to be too reliable for me.
i have 1 year left on my lease...after that, maybe i will be more financially responsible and buy something even less reliable than BMW....
Old 08-02-2017, 08:38 AM
  #1193
Received 5,293 Likes on 3,627 Posts
Giulia QF
Old 08-25-2017, 12:28 PM
  #1194
Turd Polisher
TylerT's Avatar
UPDATE:
More parts on order
Clutch kit is finally en route - I decided on going with a Clutchmasters FX400 6 puck. Based on the research I've done, it's a bit hit or miss. It will take any abuse I throw at it at the expense of it's longevity due to having ceramic material.
I also ordered 8 new flywheel bolts and also had the OEM dual mass flywheel resurfaced - new clutch setup for under $800 ain't bad
I also ordered new rear differential axle seals, new rear differential fluid, some o-rings to make my Walbro 450 snug & secure in the OEM Fuel pump basket. I am one lucky mofo - My soon to be wifey is ordering downpipes & mid-pipes for my birthday .. it will be a true 3" exhaust all the way from the turbo all the way to the exhaust tips
The biggest priority this year is making this car healthy enough to handle nearly double it's factory whp and I would say the results speak for themselves:
In this screenshot - The yellow & light blue lines show boost requested vs what's actually given. Closer they are together the better.
I feel like I'm really close now, just need the following before the motor pull happens:
AEM Wideband w/ some kind of mounting mechanism.
New Slave Cylinder
New Rear Main Seal
Motor pull supplies such as fluids, gaskets, etc.
I didn't hit my target for having the motor pulled before the wedding, but I think end of October / Mid November the car will have all the parts in and the tuning complete.
Stay tuned, this is what numbers I'm hoping for .. perhaps a little more conservative:
Stock block, F21 turbos, E85.
Old 08-25-2017, 12:37 PM
  #1195
Bird is the Word
Predatorbird's Avatar
That video Your car is going to be a beast when it's done.
Old 08-25-2017, 01:22 PM
  #1196
you warned me...
boost is addicting.
Old 08-25-2017, 02:18 PM
  #1197
Turd Polisher
TylerT's Avatar
Thanks Adam! And yes, that's the plan.
Lets say I absolutely love it when it's Stage III .. to the point where I plan on keeping it long term ..
I already have my second upgrade route planned out already in the event of a catastrophic failure.
Might go something like upgraded rods ... bigger turbos ....
you warned me...
boost is addicting.
It's satisfying ... almost TOO satisfying .
Old 08-25-2017, 04:17 PM
  #1198
no such thing!
Old 08-30-2017, 10:20 AM
  #1199
Turd Polisher
TylerT's Avatar
Look what arrived yesterday
Yes .. the Mike and Ikes were delicious - Thought it was hilarious how they put that in there...
Also, took the S4 offroading last weekend. Well, not really offroading .. but she did get quite dirty. There were a couple steep hills with washboarding all the way up ... car handled it like a champ.
Exciting year - I am getting married this weekend and we will get back from our honeymoon on 9/18 - more updates to come in October / November
What a babe:
Old 08-30-2017, 10:43 AM
  #1200
She's gorgeous.
You better put a ring on it. It'll help keep the blood in.
The following 2 users liked this post by rockstar143:
Predatorbird (08-30-2017), TylerT (08-30-2017)
Quick Reply: Tyler's Owdi B5 S4 Build & Update(s) Thread
