Tyler's Owdi B5 S4 Build & Update(s) Thread
#1801
GEEZER
#1802
Turd Polisher
I have a used OEM Bosch alternator on the way .. should be here this week.
#1803
Well I have no idea then. The N80 is definitely not a fuel line check valve though. The only explanation I have for your situation is that the valve was stuck closed and increasing the amount of time to build pressure and also not pumping fumes into the fuel rail at start up.
#1804
Received 3,656 Likes
#1806
Turd Polisher
Had some time on Saturday / Monday to work on the ETH FO and fixed my pestering voltage issue.
Sorry for the long winded post:
A word of advice from an idiot: Don't throw parts at an issue because you have a "hunch". Had I done a bit more troubleshooting & tried cheaper options, I would have fixed my voltage issue for $4 dollars in less than 10 minutes of work versus the 3 1/2 hours & $60 spent on swapping in a used / working OEM Alternator.
Long story short - ever since I pulled my motor back in October, my car's electrical system has been weak. With the car started and the alternator churning, you should be seeing between 13.5v-14v. Under battery power, 12v.
I would notice that when I first started the car, it would be at around 14v but as I started packing on the accessories like AC / headlights / heated seats, the voltage would drop just at about 12.5v, sometimes even lower under full throttle. It was not enough to trip the battery light and just enough to charge the battery.
Stumped, I cleaned both terminals / I cleaned & verified all of my grounds were tight (Main ground goes from the negative on the battery terminal to the body, other primary ground goes from the framerail to the bottom motormount bracket, and there are another 2 that connect on the secondary firewall / inside of the cabin)
My battery is less than 6 months old, so I figured my 135,000 mile alternator was the issue.
Wrong.
One of my factory grounds must have failed to the point where voltage was dissipating / escaping.
I went to Home Depot and picked up some 8 gauge wire. I ran it from the primary framerail ground connection to a bolt holding on the larger upper motormount bracket against the block and voila, voltage has stabilized.
So pissed ... yet so happy
I also washed her up and detailed the interior.
No updates as of new files / revisions ... hopefully soon.
Wrong.
#1807
shit yes, Tyler...
I love simple fixes...
sometimes I sit there, usually at night...for some reason with a fleshlight on my head (pzel or whatever) and some solitude...I can kinda think clearly and trace wires back and look and figure shit out.
#1808
Turd Polisher
In this case, all that thinking lead me to swapping the alternator when the grounding was in fact the issue all along.
Live and learn!
#1810
Turd Polisher
It's possible - funny you mention that because .. I noticed that the S4 was starting a lot more quickly / consistently now that the electrical system is basically on viagra now.
I noticed the Yukon had a little rust so ... corroded / weak grounds make for a weak electrical system. Fairly certain 13.5v-14v is the target voltage for most cars so, grab your multi-meter and measure what your voltage is at the positive terminal while the car is on.
#1811
Turd Polisher
I'm getting a new tune tonight ... one step closer to E85.
#1813
Turd Polisher
Good weekend on the S4.
These cars are never ending projects ... just once you have one thing fixed you discover something else that needs refreshing
I've been running on a busted CV boot for a few months but finally got it rebuilt with the help of a friend. What a messy job... my only goal was not tracking in any kind of axle grease into the house .. that's for sure
Disassembled:
Funny thing was, I didn't get any other pictures because my hands were so dirty ... lol.
Following that, I picked up my R8 ignition coil conversion .. huge upgrade as power levels start to increase. I noticed my AFR lean up a bit because all fuel coming from the injectors was being used
After the ignition system upgrade, I spent about 2 hours sending logs & receiving revisions. Car is definitely faster .. I would say I have around 3-4 more files until 91 octane is completed and we move to doing a whole other e85 tune.
Slowly but surely.
Disassembled:
Slowly but surely.
#1814
Turd Polisher
Here's a quick pull in 3rd & 4th gear.
Doesn't seem much faster than my last video but yeah, I can tell an immediate difference .. especially after 6000rpm.
The following 3 users liked this post by TylerT:
TylerT (06-04-2018)
#1816
Turd Polisher
Current mod list to date:
Tuned by ETSpec
85mm Intake w/ Hitachi MAF
Frankenturbo K04 hybrids
Wagner Intercoolers
APR Bi-Pipe w/ 3 BAR Map sensor
Walbro 450 w/ Racetronix harness upgrade
750CC EV14 injectors
R8 coil conversion upgrade w/ ICM deletes
NGK Iridium IX BKR7EIX @ .025
SSAC 3" Downpipes w/ 3" Miltek 2 muffler catback
FX400 6 puck clutch w/ new OEM Dual Mass Flywheel
AEM X series wideband w/ Glowgift mechanical boost gauge
Bilstein shocks w/ Eibach lowering springs
EBC Red stuff w/ StopTech Blank rotors
ECS Inline Fuel pressure gauge
STERN transmission mounts w/ RS4 engine mounts
SWEDIT headliner (Thanks Jin!)
Tuned by ETSpec
Wagner Intercoolers
TylerT (06-04-2018)
#1818
Turd Polisher
Good news is .. I got 4 different revisions on the car this weekend - but it took anywhere from a 1 hour response, to 12 hours to get a revised file once I submit my logs. Southern California isn't exactly known for having wide open freeways so I have a designated area to do a full 3rd / partial 4th gear pull.
First world problems but, I have a feeling it's going to take at least another week or two before E85 is really a possibility.
#1819
looking good...
How much have you spent on it already without labor of course... since you are free
TylerT (06-04-2018)
#1820
Turd Polisher
Let’s just say I just entered 5 digits recently ... that includes tools, all maintenance, and Stage 3.
#1821
You better keep that thing for a long time because you know you aint getting that $$ back if you sell it.
TylerT (06-05-2018)
#1822
Bird is the Word
A fully custom tune done remotely can be kind of frustrating ...
TylerT (06-05-2018)
#1823
In the Mid-South meow
Dude sooooooo glad to see things have finally fallen into place with your build! You're shooting for some massive numbers... and me likey. She's pulling hard in 3rd and 4th video.
TylerT (06-05-2018)
#1824
Pfff the car is super slow. My TL pulls the same in 1st gear, the way Tyler's Audi pulls in 4th gear. He needs a faster car
TylerT (06-05-2018)
#1826
Turd Polisher
That's a pretty quick turn around for revisions. When I was tuning the FoST, it would take approx a week to get a revision back from my tuner. I live in a good area where I can get some 3rd gear pulls in. 4th gear pulls are a little tough due to the speeds needed to reach redline.
At the end of the day, I'm happy the car is getting done
#1827
Turd Polisher
I COULD go to the freeway and do logs but the risk of getting a ticket is high ... plus, I got a ticket about 6 months ago so .. I'd like my insurance rates to stay the same right now .
Despite being about 20 minutes away, the road I am doing logs on is great. It's a 4 lane road, no side streets, 1 mile straight, and a median separating oncoming traffic.
#1829
Turd Polisher
Haven't had a ton of updates, but some subtle changes here and there.
Finally got myself an OEM RS4 grill ... sooo much better than my eBay one.
Random shot a month or so back:
Buffed and sealed my headlights & exterior door trim - they were beginning to look a bit oxidized.
4th of July morning cruise: (S4 badge added on RS4 grill)
So, after a few logs it revealed that my intake air temperatures were almost in the 65-70c range. If there's anything a turbocharged car DOESN'T like, it's hot air.
I had to improvise.
2 pieces of sheet metal & some gold reflective tape later, I cut my IATs down almost 20C at WOT after a few consecutive pulls.
Logs this morning indicated I am pulling 48c IATs at redline - this is roughly 7C hotter than the $500+ intake system 034 makes.
Could be better, but it'll do (for now).
Funny story about my ignition upgrade.
Once I reset my battery (which clears your fuel trims), the tune did not like the new ignition system ... at all. My AFRs leaned up quite a bit and we essentially needed to re-tune the car. I started that process this week ... slowly but surely
Fuel trims bang on:
Couple pictures from last weekend's detailing session.
Quick wash, detailing spray, cleaned the interior and used Plastic-X on all trim pieces ...
Thanks for reading!
I am going to hopefully finish up 91 octane this weekend .. I am literally a file or two away.
I had to improvise.
Fuel trims bang on:
Thanks for reading!
#1830
TylerT (07-25-2018)
TylerT (07-25-2018)
#1832
Turd Polisher
Turd Polisher
Well, the time has come. Been waiting for 7 months to get the car to this point!
I got my first E85 base tune a few days ago. I plan on flashing it tonight at the pump and going through the small bit of mixed 91 still left in there.
I’m expecting a solid whp & torque increase.
As promised, I’ll grab videos once the car is healthy enough to take a beating.
#1835
Turd Polisher
Hopefully the image & Video imbeds okay, posting from mobile.
Car is officially on E85 as of yesterday.
Tuner says the car shouldn’t be faster because we haven’t put any additional ignition timing, but I think I picked up power.
The real fun starts when the cars fuel trims get dialed in and we move onward to finishing the tune.
#1836
TylerT (07-27-2018)
#1837
My 20-40 is just as fast as your 40-60...
TylerT (07-27-2018)
#1838
My 20-40 is just as fast as his 0-100
TylerT (07-27-2018)
TylerT (07-27-2018)
#1840
Turd Polisher
Thanks guys, I’ve never been more excited to get through a tank of gas.
Even with a few gallons of 91 in the tank, AFR is bang on and fuel trims are pretty much right where they should be so I cant imagine the tune will take more than 2-3 files.
I want to go M3 hunting ... 2 x e92s didn’t want to play this morning
