Tyler's Owdi B5 S4 Build & Update(s) Thread
#1681
It's been 2 years?
I drove a Charger Scat Pack a couple months back at my local Ford dealer when my Explorer was in the shop. I fell in love with that thing. Everything about it. I wanted to buy it! But, as of right now I'm not in the position to do so. January 2019 I'll be in a better position.
#1683
Turd Polisher
Feels good to finally win one for a change.
On Friday, I got most of my parts in and I started working on the car on Saturday.
Installed my solid metal APR bipipe after getting all the necessary o-rings & hoses - one thing that's GREAT about the solid metal unit is you don't have to worry about a silicon boot popping off under boost, it's bolted directly to the throttle body and looks gangster AF:
Also, installed my 3 BAR MAP sensor. The OEM MAP sensor doesn't read accurately over 20psi - this one accurately reads up to 43psi.
I also replaced my N75 valve. This is essentially the OEM electronic boost controller that regulates boost pressure by opening / closing the wastegates.
I was having some really bad overboost issues once I crossed over 15 psi. I'm able to hold up to around 18 PSI until my ignition system (coil packs / spark plug / gapping) is the limitation. I have a plan of action .. just need to gap my plugs even closer and / or replace coil packs if it's a particular cylinder misfiring.
Old:
New (installed):
I also installed a 3" aluminum flared coupler to extend my driverside IC hose a bit. Worked like a charm .. haven't popped a hose off after quite a few 15+ psi pulls
Do you think I used enough t-clamps?
Car is running fan-fucking-tastic.
Once my ignition is sorted, I can finally start doing WOT pulls and log. SO CLOSE!
Old:
New (installed):
The following 6 users liked this post by TylerT:
00TL-P3.2 (03-20-2018),
1killercls (03-15-2018),
Aman (03-21-2018),
Predatorbird (03-13-2018),
rockstar143 (03-13-2018),
and 1 others liked this post.
#1684
Turd Polisher
Another thing ... I can't believe it's been 5 months since my car went under the knife.
#1686
Car looks sick. Love those wheels. Please either keep those or the OE B5 S4 wheels and nothing else.
Great and kudos for sticking with it, you're a better man than me for that.
TylerT (03-15-2018)
#1688
Turd Polisher
I see light at the end of the tunnel .. I'm hoping another 5-10 hours until the car is fully tuned for 91. Once that's good to go and assuming there are no other issues, I am ready to hit E85 which = moh powaaah.
Thank you!
#1689
TylerT (03-13-2018)
#1690
Turd Polisher
I ran out of time, but I did a quick 15 psi pull on the way home last night. If I go WOT, the car will want to do 24 psi and unfortunately, my ignition system cannot keep up with it and simply sputters / starts misfiring
Here's 2/3 throttle
Here's 2/3 throttle
#1691
When you see it
TylerT (03-13-2018)
#1692
Turd Polisher
LEAST OF MY PROBLEMS ... OKAY?
#1693
Seems like you can leave the motor intact for a bit now.
#1695
Turd Polisher
GEEZER
I'm shopping for a low miles used S5 ... Gotta stay under 28k.
TylerT (03-15-2018)
#1699
Year: 1999
Miles: 439
LMK if you're interested
Miles: 439
#1702
I'll take two!!!
#1703
Turd Polisher
Oh S5...
I read B5
fucking can't read
I read B5
fucking can't read
The following 2 users liked this post by thoiboi:
1killercls (03-16-2018),
Aman (03-21-2018)
#1706
Turd Polisher
After being through everything ... I'm kind of reluctant to recommend anybody buying a B5 unless they have the same goal in mind / willing to put in the work.
I couldn't imagine taking my car to a shop every time it had something wrong with it, let alone paying a shop to build it.
FYI - shops charge $2500 just to pull and reinstall the motor ... that's not even the man hours to install all the upgrades or tune it. Parts on top of that will be another $7500-$10000 if it's purchased brand new and done "right".
No thanks
#1707
No thanks
#1708
GEEZER
#1709
Turd Polisher
TylerT (03-16-2018)
Predatorbird (03-18-2018)
#1713
Turd Polisher
UPDATE:
For the first time in 5 months, the ETH FO is boosting and not misfiring ... finally .
I had a decent amount of time work on the car this weekend, mainly troubleshooting why my car's boost would spike to 25 psi uncontrollably. Normally in a situation like this, you would pressure test the intake side of your car to identify where you're leaking from ...
At the end of the day, I regret buying china turbo inlets because their fitment is total dog shit and it makes pressure testing the car impossible due to them being a bit leaky. They will hold some pressure, but not 20 psi
Last resort is smoke testing. A friend of mine bought a DIY built one for $150 and let me borrow it... coolest fucking thing in the world.
After a few minutes dumping smoke into my car's intake system, it revealed that one of my banjo bolts holding on one of the vacuum / reference lines to the compressor side of the driverside turbo had backed off. To the naked eye, the bolt looks snug ... but I could see smoke pouring out of it. Simple fix. I had to sacrifice a stubby 13mm wrench but hey, totally worth it
First drive was good, it was holding boost but misfiring on cylinder 6 ... changed out the coilpack and she's golden. Yesterday in the afternoon it was spiking 23 psi and tapering to 20, right where I'm supposed to be.
I took the car out last night to dinner and recorded a few WOT pulls, car is now boosting less ... so maybe the bolt is backing off again or maybe I am leaking from somewhere else. There's definitely a lot more turbo noise than there's supposed to be
Either way, progress is progress.
#1714
Soooo... is it even possible to have high boost on this thing for more than 5 miles, without any issues? Put Loctite on every single nut, bolt, washer, stud, grommet, whatever, you can find!!!
#1715
and I mean, if you ever get tired of chasing gremlins on the B5 platform, there's always this very bad decision you can make:
https://bringatrailer.com/listing/1995-audi-s6-14/
#1716
Turd Polisher
I've already sheared one when the motor was out of the car ... if I did the same thing with the motor in the car, I would need to pull it... a 4th time.
I'm going to smoke test it tomorrow and see if anything comes out of that location again. If not, on to the next leak
I want some old school 5cyl in my life ...
#1717
red threadlocker
shit ain't going nowhere
#1718
Turd Polisher
If it backs off again, I'll use some threadlocker on there.
The problem is .. it's so buried / tight that if the bolt comes off, putting it back in will be almost impossible. I'll see what I can do.
#1719
Funny how it's never the easily accessible shit that goes wrong
#1720
