Tyler's Owdi B5 S4 Build & Update(s) Thread
Old 12-12-2017, 04:56 PM
  #1481
Received 5,831 Likes on 3,852 Posts
Originally Posted by TylerT
From what I've seen, they usually have trace amounts of oil in the bottom of the ICs but aren't really "clogged" per say.
You got me thinking now - I may just run a crap ton of brake cleaner through them so it evaporates ... I don't want degreaser going into the IM.
I'd be extra careful with this and let it evaporate for days and blow low pressure air through if you can. Brake cleaner fumes are extremely explosive and cause pretty decent backfires that could mess some stuff up.
Old 12-12-2017, 05:41 PM
  #1482
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
Damn nice!
The roll racing will put your work to the test.
Old 12-13-2017, 02:16 PM
  #1483
Turd Polisher
TylerT's Avatar
Received 3,006 Likes on 1,514 Posts
Definitely.
Damn nice!
Indeed.
So, small update.
While it doesn't appear to be an issue with the clutch's operation / function, I am experiencing an interesting sound from the clutch during engagement. It's really only taking off in 1st & Reverse, otherwise, all other gears engage with no noise. The noise can be described as chatter, but more of a metallic rubbing sound.
I've ruled out that it's not a pilot / throwout bearing issue since it doesn't happen in neutral - it only happens as the clutch "slips" off of the flywheel as I'm moving forward (1st gear / Reverse)
I've been through around 3-4 tanks of gas .. so I'm at the end of my break-in period.
I contacted ClutchMasters and they seem to think as long as the clutch is operating normally (clutch engagement, gear engagement, etc) it should be fine.
I'm hoping it goes away as the materials become more acquainted - If this clutch holds over 450wtq on E85 and it doesn't slip .. I won't address the issue.
If it does, I'm in for a 3rd motor pull and possibly just switching clutch setups all together.
This weekend I plan on tackling the fuel pump and getting a few more revisions done on the tune - this will tell me if I have something wrong with the clutch disk or not.
Old 12-13-2017, 08:43 PM
  #1484
Bird is the Word
Predatorbird's Avatar
Don't some clutches have more chatter than others? Especially stronger clutches that can handle your TQ levels?
TylerT (12-14-2017)
Old 12-14-2017, 06:30 AM
  #1485
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
My ex clutch was super chatty. I don't miss her at all.
The following 2 users liked this post by rockstar143:
TacoBello (12-14-2017), TylerT (12-14-2017)
Old 12-14-2017, 09:12 AM
  #1486
Turd Polisher
TylerT's Avatar
Yeah, strong clutches typically have chatter more than others ... but from what I've seen, the type / weight of flywheel you choose is what determines how much chatter you'll have.
The sound I'm hearing is almost if the clutch / flywheel surfaces aren't properly mated.
Clutchmasters & my tuner said to just drive a bunch of stop & go and report back.
Love you, bruh.
The following 2 users liked this post by TylerT:
Predatorbird (12-14-2017), rockstar143 (12-14-2017)
Old 12-14-2017, 10:52 AM
  #1487
Bird is the Word
Lets hope the sound starts to go away after you put on more miles and you don't have to pull the motor again.
TylerT (12-14-2017)
Old 12-14-2017, 10:58 AM
  #1488
if he does...
LS swap time.
TylerT (12-14-2017)
Old 12-14-2017, 11:09 AM
  #1489
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Didn't even know you were thinking of selling the S2k. So I'm guessing Jaw-knee didn't buy it, or did he? (doubt it)
A friend of a friend has a fit and he loves it. He hauls is husky around town in it. He slightly modded it as well. I know we have an Azine member who has a modded fit down in SoCal.
Also, did anyone else catch that Tyler said the S2k doesn't fit his needs right now.
Sold the S2k and bought a "daily" Honda Fit.
Daily actually means to haul my newborn around in.
Congrats Tyler?
TylerT (12-14-2017)
Old 12-14-2017, 11:19 AM
  #1490
Turd Polisher
TylerT's Avatar
This x 1,000,000
if he does...
LS swap time.
LS Swap all a da tings!
Congrats Tyler?
No mini-me / mini-wifey on the way, we're still waiting for a bit ...
Truth be told, the Fit makes an amazing daily.
I drove the exhaustless S4 100 miles yesterday ... the clutch is brutal, the sound is deafening, the boost comes on strong, it's an animal ... sometimes it's nice just to turn up the stereo and relax on the way to work.
The contrast keeps a great balance.
Old 12-14-2017, 11:35 AM
  #1491
just FYI, no matter the sex it's still a "mini-me".
You'll see.
Old 12-14-2017, 12:24 PM
  #1492
Flipster23's Avatar
You'll see.
<------- Experience
Old 12-20-2017, 08:20 AM
  #1493
Received 8,584 Likes on 6,630 Posts
Congrats Tyler?
Old 12-20-2017, 08:29 PM
  #1494
he might have!
Old 12-20-2017, 10:26 PM
  #1495
jangkai's Avatar
Nice ride! I've been looking at B5 S4s for a few months. After looking through your entire thread, I'm not too sure if I can keep up with the maintenace. I don't think I'm mechanically inclined enough
From my search, it looks like clean examples with around 100k miles go for close to 10k and the not so clean ones with 150k+ miles go for around 5k. I will have to keep on searching for a nogaro blue or an imola yellow example.
TylerT (12-21-2017)
Old 12-21-2017, 08:02 AM
  #1496
there are a few of those here in Sofla for sale.
Old 12-21-2017, 09:24 AM
  #1497
Turd Polisher
TylerT's Avatar
Thanks much.
After owning the car for 2 years, I think reliability comes down to how far you want to take it.
Simple tune & bolt-ons, car will give you little issues assuming all maintenance is up to date ... it's when you want to throw another 200whp where things can go kaboom.
Or in my case, assembling it myself
2 hard lessons learned already.
jangkai (12-21-2017)
Old 12-21-2017, 09:26 AM
  #1498
Turd Polisher
TylerT's Avatar
Oh yeah ... Motor pull #3 is happening.
After further research, I believe I have diagnosed my issue being a bad pilot bearing
Old 12-21-2017, 09:40 AM
  #1499
Turd Polisher
TylerT's Avatar
Here's the sound I'm talking about:
On a brighter note, I did receive my intercoolers last week and damn .. they're huge. Carbon fiber shrouds are sex
Old 12-21-2017, 10:21 AM
  #1500
You's gonna be an expert at B5 engine pulls now
Old 12-21-2017, 11:23 AM
  #1501
He already is...
sadly.
Old 12-21-2017, 12:11 PM
  #1502
Turd Polisher
TylerT's Avatar
I thought by the 3rd motor pull I would have larger turbos, rods, and meth injection ...
Funny how your plans suddenly change.
Old 12-21-2017, 01:27 PM
  #1503
How much more would it cost to just knock all that shit out now?
You will have to go all the way to the edge before jumping off!
I can sense your enthusiasm starting to wane. Don't give up, man...hard not to be disappoint and at least you know if you can make it through this you can
survive any shitty relationship with any woman and end up staying married for a long long time.
"I'd divorce her but at least she's not a B5 Audi!!!!"
TylerT (12-21-2017)
Old 12-21-2017, 02:26 PM
  #1504
Damn dude, I wish I could come help with this and learn how to pull a motor as I've never done it before. I was just down in your hood Tuesday and Wednesday but it was a fast and furious trip that left no time for fun stuff.
TylerT (12-21-2017)
Old 12-21-2017, 02:29 PM
  #1505
I wouldn't want Sam around. He'd have the original turbos and suspension and wheels back on when you weren't looking. Fuck that.
The following 3 users liked this post by rockstar143:
00TL-P3.2 (12-28-2017), thoiboi (12-21-2017), TylerT (12-21-2017)
Old 12-21-2017, 02:30 PM
  #1506
Read the sig bro, read the sig. If I did that, Tyler would be wondering why his car was magically running just fine.
Also, we were all pushing him to put on the OE wheels...
The following 3 users liked this post by SamDoe1:
rockstar143 (12-21-2017), teh CL (12-22-2017), thoiboi (12-21-2017)
Old 12-21-2017, 02:47 PM
  #1507
Turd Polisher
TylerT's Avatar
If I went balls to the walls (built transmission w/ cryo-treated gear sets, RPM rods, fail safe meth kit, K24 turbos, etc) .. it would be at least another 4-6k. Not really an option at this point.
I am feeling pretty unmotivated to touch the car lately with a lot left to do; fuel pump + new wiring, install & wire wideband, install intercoolers (involves shaving core support), and do many other tuning revisions.
It's surprisingly not that difficult with 2 people ... last time we had the motor out in just under 4 hours.
Once the motor goes on the Fit ... I'm K-Swapping it. Maybe you can swing by for that motor pull
Old 12-21-2017, 03:21 PM
  #1508
oonowindoo's Avatar
So i am assuming this time, it will be 3 hours or less.... shit... i take nap longer than that
TylerT (12-21-2017)
Old 12-21-2017, 03:26 PM
  #1509
K-swapping the Fit?!
You best have a thread for that
Old 12-21-2017, 05:12 PM
  #1510
Turd Polisher
TylerT's Avatar
You best believe it.
Old 12-22-2017, 07:36 AM
  #1511
there's no way...
that would be a real chore...
not this Mickey Mouse easy 4 hour engine pull bullshit.
Old 12-22-2017, 08:00 AM
  #1512
teh CL's Avatar
3rd pull in like 2 months?
Old 12-22-2017, 08:32 AM
  #1513
Bird is the Word
This
Old 12-22-2017, 08:33 AM
  #1514
Less, technically.
Old 12-22-2017, 09:10 AM
  #1515
Turd Polisher
TylerT's Avatar
Yeah.
This is my first ever "build" - first clutch job, first turbo installation, first everything pretty much .. there's bound to be mistakes .. some by improper installation, some just plain bad luck.
I don't have a choice except for moving forward. The positive side of me says the car will be much more enjoyable to me when it's all said and done
Old 12-22-2017, 09:14 AM
  #1516
Can you apply for a VAG/ASE cer you can complete online?
You'll be master tech by the time it's all over.
  #1517
teh CL's Avatar
Learning curve is a BITCH.. ask me how I know
Old 12-22-2017, 09:17 AM
  #1518
how?
Old 12-22-2017, 09:23 AM
  #1519
Yeah.
You better be keeping this thing for the rest of time at this point.
Old 12-22-2017, 09:25 AM
  #1520
Turd Polisher
TylerT's Avatar
Far from a mastertech, I'd say familiar with the B5 platform and that's being generous
Indeed.
Depending on how the rest of this project goes .. next car will be fast from factory and I'll be done with it
Quick Reply: Tyler's Owdi B5 S4 Build & Update(s) Thread
