Tyler's Owdi B5 S4 Build & Update(s) Thread
#961
Turd Polisher
I've bounced around with a few ideas and I'm pretty sure I've made up my decision.
I wanted some Borgwarner K04s because they're a proven OEM turbo setup found in the european spec RS4 and can produce around 400whp on 91 (aka, cat piss), 450whp on E85.
A new set of OEM Borgwarner turbos goes close to $3,000 which really is a lot of cheese for just snails. I've debated on buying used, but I ultimately decided against it.
I plan on going a different route and getting some SRM K04+ hybrids which run around $1800 shipped. Since I don't plan on running over 450whp, these will fit the bill nicely. Based on what I've researched, a conservative tune should net 400whp on 91 and will have very similar spool to the stock turbos found in my car.
The following 2 users liked this post by TylerT:
00TL-P3.2 (01-26-2017),
SuperTrooper169 (01-27-2017)
#963
Baller
#964
Received 3,656 Likes
Badass More POWER!!!
On another note that blue RS4 is a beaut
#965
Turd Polisher
TylerT (01-26-2017)
#967
TylerT (01-26-2017)
#968
Turd Polisher
Mandatory:
550CC injectors
Walbro 255 Fuel Pump
Upgraded intercoolers - I'm thinking a used set of AWE (New = $$$$) or some SRM units. K04s will heatsoak the OEM SMICS easily.
RS4 Intake & new Hitachi MAF
ARP Bi-Pipes - Discontinued, will have to dig for these.
Stage 3 tuning, still undecided on which tune I will use.
SSAC hi-flow downpipes (damn CA smog)
RS4 pressure plate & clutch
New Stern transmission mounts
New Differential mounts
Optional:
JHM Short shift kit
Tougher Stern Motor mounts
Rebuilding the trans while it's out. 1st / 2nd gear synchros are notorious for failing. Once they break, you got to pull the engine & trans together ...
My goal for this build is having everything done awhile it's apart and not having to pull the engine a 2nd time.
As much as I want to pull the engine myself, I want the build done once and done right. The B5 Expert here in SoCal is going to charge me $1500 in labor for assembly and will take roughly 3 weekends to do.
When this is all said and done, the build & maintenance alone will be more than the car and some.
#969
$1,500 doesn't seem like a terrible deal for labor for that list.
TylerT (01-26-2017)
#970
Does the $1500 include the trans rebuild? If so, that's a bargain.
In other news, I might be back in your neck of the woods in the next month or so...
TylerT (01-26-2017)
#971
Turd Polisher
I should have made myself more clear, I'm not complaining about the pricing at all. Very reasonable and the quality of work is high
Guh I wish. The transmission rebuild is something I really don't want to shell out for but we'll see how it holds up this year. If it shifts consistently till the end of the year, I might hold off on the rebuild until it goes boom.
Bruhh, you have my digits. S4 is ready for ya
#972
In the Mid-South meow
I still have nightmares about the K04 in the MS6 I had, but completely different application and I know the K04s are nice reliable upgrades in the Audi/VW world. Good luck with your build. Blue sedans unite!!!
#973
Turd Polisher
These K04s should last me quite awhile and I won't be near their power limits. Reliability is my primary goal for this build
Yeee.
#975
I had oil blow by the seals so if I was sitting idling on any sort of incline or decline my car would smoke like a diesel truck. Huge plumes of black smoke would flow out of the tailpipes. The car ran fine but it just made it look like a POS when it did that. I think it may have been a MS6 specific problem with the way the oil lines ran to the K04. It was the main reason for trading the MS6 in for the Charger.
#976
Turd Polisher
Unfortunately, turbo purchase is on hold due to unforeseen house issues (no spending with the tax refund).
Although, I am slowly knocking out my list - just ordered 6 x Bosch EV14 550CC injectors & a Walbro 450 fuel pump. Fueling is now done.
After further research, the Walbro 255 can theoretically handle the flow of 550CC injectors, but I've seen a few fuel flow charts and it simply can't deliver enough as you start doing heavy 3rd & 4th gear pulls.
85MM Hitachi MAF w/ new intake & Bi-Pipes are next on the list.
#977
Turd Polisher
#978
TylerT (02-07-2017)
#979
Turd Polisher
Turd Polisher
Quick video I took the other day:
Funny .. I thought this car was pretty quick upon purchase. I want moar.
00TL-P3.2 (02-13-2017)
#982
Turd Polisher
GEEZER
#984
bruh, trip booked to your area. text inbound. keep dem CEL's away until then.
#985
Turd Polisher
Boooooooooooooossssssssstttttttt!!!
#989
Turd Polisher
1killercls (02-09-2017)
#990
What does Stage 1 consist of? Tune and intake?
#991
Turd Polisher
Pretty much, my car *technically* a weak Stage ll since I have a catback exhaust. From what I've seen, people usually push over 15 PSI and get aftermarket downpipes for a strong Stage II car.
Here's the different stages:
Stage 1 = ECU remap
Stage 2 = ECU Remap + Cat-back
Stage 2+ = ECU Remap, downpipes & cat-back
Stage 3- = K04 Turbos, No fuel upgrades
Stage 3 = K04's & Fuel, Intercoolers
Stage 3+ = K04's, Fuel, intercoolers, Meth, E85
I'm shooting for a solid Stage III car, no meth or E85 for me.
Stage 1 = ECU remap
#992
Turd Polisher
Update:
This came up as an unexpected purchase (as Craigslist finds typically do ), but I've had a little buyers remorse since purchasing my SSAC (XS Power) 2.25" catback exhaust. It's made by XS-Power - the sound is good, fitment isn't 100% and exhaust feels flimsy... so I decided to get something a little nicer with a little more girth
3" Milltek Sport Exhaust - welds are beautiful, added width is nice (no homo) for future turbo setup, and I couldn't argue the price of $150 (considering for it's time, it retailed for around $1200)
Installation happens tonight!
Lets just hope I like the sound so I don't end up like SuperTrooper
CLtotheTL32 (02-11-2017)
#993
Hey hey hey! I finally like my exhaust. Nice find. Hope you like it!
TylerT (02-10-2017)
#994
Turd Polisher
You got that for $150??
Dayum, I don't know if I want to know how you managed to pull that off...
TylerT (02-10-2017)
#996
GEEZER
Tyler..you still have cats on your car?
When I put my test pipe on it made my stage one really come alive. In Florida no smog check so it's doable...
TylerT (02-10-2017)
#997
Turd Polisher
Like most of you here, I'm always on Craigslist scoping for parts. I decided to type something totally generic in, like "Audi Parts" and the ad was pretty obscure & vague. It literally read off as "Audi sport exhaust" with a Miltek part #.
Curiosity got the best of me and I made the call - jackpot
You Floridians are lucky, 93 gas AND no smog. I would love to go catless but I simply don't want to take the risk of failing smog - high quality catted downpipes (new) go for $1000+
I'm just waiting for the right deal to come along on the classifieds for a used set.
What's your next upgrade on the A4?
#998
GEEZER
No upgrades planned for the moment. I have a big hit coming in 5 k more miles. Timing belt, water pump, and coolant flange and cooling hoses on the back of the motor. About a 1500.00 dollar hit. After that maybe a after market exhaust..then stage 2! I just want to be sure all the important stuff is handled before I start modding anymore. It's been such a great car.
TylerT (02-10-2017)
#999
GEEZER
Just remembered...I'm due for a carbon clean too...
