Tyler's Owdi B5 S4 Build & Update(s) Thread
Old 06-06-2016, 05:41 PM
Turd Polisher
TylerT's Avatar
Received 3,006 Likes on 1,514 Posts
I put a deposit down on a second daily / project car
2001.5 Nogaro Blue S4 w/ Cold Weather Package
Cliffs:
-114,000 miles
-Clean title
-2 owners
-6 speed
-Strong stock clutch (original)
-Mostly stock except for APR Stage I chip
-Stock K03 turbos (Original, no abnormal noises)
-Laundry list of of maintenance done such as coil packs, ICM, plugs, cam tensioner seals, upgraded diverter valves, wheel bearings, tie rods, control arms, new tires, etc
-BBK w/ ECS drilled & slotted rotors.
-VRM 18x8.5 wheels
-New tires
As B5 S4s go, their reputation serves as anything but reliable and it's certainly a car you buy with your heart and not your wallet. I've wanted one for as long as I can remember and this one was too clean to pass up. As of right now, I don't have big plans with it as of yet other than upkeep, but when those snails go out I'll be doing at least a Stage II build on it.
I test drove it for 45 minutes and it ran great with no codes, boosted to 17psi, no abnormal sounds coming from the turbos and the clutch didn't slip. I put a deposit down on it and should pick it up this week.
More pictures to come! It needs a good interior detail but the paint is pretty much mint with the exception of a few clear coat spots on the roof.
The following 10 users liked this post by TylerT:
00TL-P3.2 (06-07-2016), 2K2SilverTL-S (06-24-2016), Aman (06-07-2016), CLtotheTL32 (06-07-2016), JS + XES (06-08-2016), maharajamd (06-07-2016), Mr Hyde (01-13-2017), rockstar143 (06-07-2016), SuperTrooper169 (06-07-2016), TacoBello (06-07-2016) and 5 others liked this post. (Show less...)
Popular Reply
10-08-2020, 09:12 AM
TylerT
Turd Polisher
TylerT's Avatar
No big updates but, I have been enjoying the car quite a bit:
It was time ... I took my car down to an exhaust shop and have my mid-muffler removed so now, I am running 3" DPs, 3" mid-pipes, merged into a 3" catback with 1 x Miltek muffler at the back.
I know I know .. no sound clips, but I do plan on charging up my GoPro and getting a few recordings. It sounds perfect .. has some burbles up shifts, downshifts sound great, no drone.
I am one happy camper!
Additionally, I removed my stud conversion ... I swear - every wheel setup I've had with this has had some kind of vibrations / it was really hard to get it right.
I ordered some M14x1.5 37mm R13 ball seat lug bolts and removed the stud conversion all together ... no more vibrations and I know this makes @rockstar143 very happy! Nur Werksspezifikation!
What's next? Well ..I would like to get the following done before the end of the year:
- Remove black vinyl wrapping and get my roof repainted.
- Install Toureg big brake kit (I sound like a broken record).
- Install new ECS rear differential mount
- Get a new driveshaft - my center bearing is good, however the bushing around it is very tired and there's definitely slack in the driveline due to that. Differential mount should help immensely, but a new bushing around the center bearing will do wonders as well.
Thanks for reading.
Old 06-06-2016, 05:58 PM
teh CL's Avatar
6 speed FTW
Well done
TylerT (06-06-2016)
Old 06-06-2016, 06:00 PM
ggesq's Avatar
Received 2,181 Likes on 1,210 Posts
TylerT (06-06-2016)
Old 06-06-2016, 06:04 PM
Received 8,583 Likes on 6,630 Posts
Time to sell the S
TylerT (06-06-2016)
Old 06-06-2016, 06:21 PM
neuronbob's Avatar
Received 4,612 Likes on 2,193 Posts
Well played. Good idea to find one on which required (expensive) maintenance was already done.
TylerT (06-06-2016)
Old 06-06-2016, 06:31 PM
JJones91's Avatar
NVM not a 2.0T FSI lol just looked into the S4
TylerT (06-06-2016)
Old 06-06-2016, 06:44 PM
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
good pickup.
they are getting pretty rare nowadays.
TylerT (06-06-2016)
Old 06-06-2016, 06:53 PM
Turd Polisher
TylerT's Avatar
Time to sell the S
Hell no, I need some form of reliable transportation!
Old 06-06-2016, 06:56 PM
oonowindoo's Avatar
does the owner have the original wheels? i have thought those look very good. look bigger than they actually are.
Old 06-06-2016, 07:50 PM
crazyasiantl's Avatar
Old 06-06-2016, 08:00 PM
#garagequeen
Old 06-06-2016, 08:46 PM
Received 5,831 Likes on 3,852 Posts
This is the only car in the world where that's actually impressive.
Congrats man, enjoy it for as long as it'll run without throwing a code. And remember, step one of any procedure on this car is remove the front end.
BTW, I'm back in SD next week. I kinda want a ride. nomsayin?
Old 06-06-2016, 08:57 PM
Turd Polisher
TylerT's Avatar
He did, but they had full blown snow tires mounted.
I am in the hunt for them though, always been a fan of 17s but these wheels would look amazing with a drop (not like that'd ever happen anyways)
#garagequeen
So true.
And yes, I'm in Wisconsin the whole weekend but will be back in SD next week. Totally down to give you a ride!
Old 06-06-2016, 09:18 PM
oonowindoo's Avatar
So true.
where did you buy the car?
Old 06-06-2016, 10:11 PM
3.5 psi
gnuts's Avatar
Curious what you like in the b5 over the b6. I have a sweet spot for the b6 v8. The blue is
Old 06-06-2016, 11:17 PM
Turd Polisher
TylerT's Avatar
I should have clarified, I'm picking up the car in LA this weekend (it was originally from Ohio).
I'm heading to Wisconsin for a wedding this weekend
Having personally never driven the B6, I couldn't give you a direct comparison but I will tell you the torque of the B5 is pretty astounding (Builds peak torque @ 2500rpm).
APR's Stage I tune claims 307hp & 366 ft/lbs to the crank on 91.
I think the B5 chassis is the perfect size sedan and sits just under 3400 pounds; B6 sits at about 3600ish.
To each his own, but I think both cars are great.
Old 06-06-2016, 11:36 PM
brahs be jelly
MTEAZY's Avatar
B6 is nose-heavy, hard to make big power with, has timing chains of death (although the B5 isn't exactly a walk in the park)
TylerT (06-07-2016)
Old 06-06-2016, 11:55 PM
LA you say.......
Old 06-07-2016, 12:13 AM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Will this one make it in the driveway?
Looks good Tyler!!! Can't wait to see what you're going to do with it.
TylerT (06-07-2016)
Old 06-07-2016, 09:13 AM
Turd Polisher
TylerT's Avatar
LA you say.......
You'll definitely have to check it out one of these days, this week is pretty packed though.
Quattro bruh
On a serious note, this thing has pretty impressive ground clearance so I don't think it'll be a problem.
You guessed it, lowering it is out of the question
Old 06-07-2016, 09:20 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,651 Likes on 1,116 Posts
Oooooooooooo I LOVE the color.
TylerT (06-07-2016)
Old 06-07-2016, 09:32 AM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
But really, that thing looks gangster. I love older Audis... just too scared to ever own one
TylerT (06-07-2016)
Old 06-07-2016, 09:38 AM
Turd Polisher
TylerT's Avatar
Same
I'd say this is more of a project car than daily, but I have my trusty S to fall on so no harm no foul
On a separate note, the car currently has Ohio plates ... and since I have to get new plates I might as well get custom ones no?
Any suggestions AZ?
Old 06-07-2016, 09:40 AM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
Nice pickup man! That blue is awesome...
TylerT (06-07-2016)
Old 06-07-2016, 09:41 AM
TacoBello's Avatar
Any suggestions AZ?
"ETH FO"
thoiboi (06-07-2016)
Old 06-07-2016, 09:42 AM
In the Mid-South meow
SuperTrooper169's Avatar
Received 2,093 Likes on 1,086 Posts
Congrats dude! I've always loved that color and the timeless styling of the S4.
TylerT (06-07-2016)
Old 06-07-2016, 09:43 AM
Turd Polisher
TylerT's Avatar
Ohhhh, Audizine making a comeback?
Old 06-07-2016, 09:45 AM
maharajamd's Avatar
Yea man screw these Honda jokers let's go pickup some bishes.
Old 06-07-2016, 10:01 AM
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
The only bishes that get into Audis sit behind the wheel
Congratulations Tyler! That's a gorgeous color. I've always loved that body style
TylerT (06-07-2016)
Old 06-07-2016, 10:10 AM
maharajamd's Avatar
Old 06-07-2016, 10:27 AM
GEEZER
1killercls's Avatar
Received 2,214 Likes on 1,418 Posts
First things first...get a VAG-com reader.
It makes owning an Audi MUCH easier.
https://en.wikipedia.org/wiki/VAG-COM
TylerT (06-07-2016)
Old 06-07-2016, 10:32 AM
maharajamd's Avatar
Do they make anything that works with iPhones/pads/etc?
Old 06-07-2016, 10:52 AM
3.5 psi
gnuts's Avatar
ya I read about the chains and repair bills . I guess I just love the exhaust note on them.
oonowindoo's Avatar
LA you say.......
i know right?
Old 06-07-2016, 11:04 AM
GEEZER
1killercls's Avatar
I am sure they may...but If you want all the info and not just a code reader VAG COM is the way to go.
Old 06-07-2016, 11:06 AM
Old 06-07-2016, 12:04 PM
CCColtsicehockey's Avatar
Received 3,657 Likes on 2,491 Posts
One of the best blue colors ever on a production car in my opinion. Great find especially with all that work already done.
TylerT (06-07-2016)
Old 06-07-2016, 12:09 PM
foxriderar77's Avatar
Love the color, needs some airbags, those cars look so good slammed.
TylerT (06-07-2016)
Old 06-07-2016, 12:16 PM
TacoBello's Avatar
Also needs an engine/transmission swap from an s2000. You know, for reliability purposes.
Old 06-07-2016, 12:18 PM
or just sell it to a local for the "audi maintenance fund"
Quick Reply: Tyler's Owdi B5 S4 Build & Update(s) Thread
