Actually it has unseasonably cool, should never be under 90, has been down to mid-40s in the am.
But that is not why I came in.
Remember that 900.00 warranty? It expires 4/8 so After the dyno which was sort of near the AutoNation Toyota dealer I took it there (200 deductible @AN, 400 elsewhere) they diagnosed 2 things I was blissfully unaware of. Cam seal on one bank is seeping & upper & lower control arm bushings need to be replaced, 3400 @ dealer theft prices. WOOT!
You don’t. It helps to understand that AirTags don’t know their location or update their location. Your AirTag periodically sends a unique signal identifying itself. Nearby Apple devices (e.g. an iPhone) receive this signal, roughly guess the direction and distance to the AirTag (without notifying the owner of the iPhone). This device then informs Apple of the location of the AirTag, which updates its location in your iCloud account. You cannot configure the frequency of pings.
The location is updated both when the device has moved and it has contacted an Apple device that has internet access and location services enabled. if the AirTag is in a remote area it may not come in contact with another device for some time. If it is far from a location with internet access then the device will log the contact and location then update only when it has internet access.
The paperwork Toyota gave me is near impossible to read, here is what they have on the owner portal. When u/l control arms are replaced does a new alignment need to be done?
If they did it would it be notated?
RE SEALED LEFT SIDE CAM HOUSING
RE SEALED LEFT SIDE CAM HOUSING ~|~P/A LH CAM TOWER RESEAL ~|~ ~|~135759 RESEALED CAM HOUSING LEFT SIDE AS PER APPROVAL
Customer Pay
CONTROL ARM, UPPER - RIGHT FRONT
CONTROL ARM, UPPER - RIGHT FRONT ~|~CONTROL ARM, UPPER - REPLACE (LABOR ONLY) ~|~ ~|~135759 REPLACED RIGHT SIDE UPPER CONTROL ARM AS PER APPROVAL
Customer Pay
REPLACED RIGHT FRONT LOWER CONTROL ARM
REPLACED RIGHT FRONT LOWER CONTROL ARM ~|~CONTROL ARM (LOWER) (BOTH SIDE SIDE) - REPLACE ~|~ ~|~135759 REPLACED RIGHT SIDE LOWER CONTROL ARM AS PER APPROVAL
Typically any time they touch any part of the suspension, an alignment should be done.
That is what I felt. I'll ask them if they did it or get my 3rd lifetime from Firestone.
Also:
NSFW warning:
FUCK WALBRO!
Put it together, not fully sewn up because I have bene burned before. NADA, not even thinking about thinking about running. Thought maybe I swapped the lines, tried to swap them NO! the hardlines are different sizes (learned after wrestling them the fuck off)
Thought maybe I had the hoses in the basket swapped, NO! Gave it electricity, the Walbro isn't pushing shit, nada NOTHING.
Wired up the Deatchwerks, tried to start, tried to start, STARTED! RUNS & over 100 fucking PSI (Aerootive maxed out to get to 58ish with the Shitbro.
DIE Walbro, DIE!
Also, thans for the Tacoma instructions, they made me feel smart because I bought that transmission jack they are using all on my own.
This was when I was verifying blue is power & soldering the relay to it.
I've never really been impressed with Walbros. I went through 3 or 4 in the CL, and that wasn't even a boosted application.
How does it pull now?
It was amazing. For 20 minutes, apparently because the FPR was maxed it was at 105 for a few seconds and seems to have blown the 100lb hose so the tank is coming down again.
Pressure dropped to 20 after I filled the tank and pulled out of the station. Every other time I had it close to empty, this is going to be fun!
It's like the news, good news, bad news, rinse repeat.
Butond up, lost fuel sender GAAAAAAA. I know I connected it but apparently not tightly. Not pulling the tank again today, it is full, I'll fill it in 200 miles if I don't drop it again before.
Went to Napa for the golden hose, the truck is amazing!
It’s over 60lbs fuel pressure at all times, goes up in boost, went down to 8.7 (that I saw) afr & peak boost 9.4 It's not bogging, feels amazing and apparently I never really felt it the way it should be.
