teh CL.... lost his V card
#321
teh CL (11-29-2018)
Acura TL Builder (05-21-2019)
The following 2 users liked this post by rockstar143:
Acura TL Builder (05-21-2019),
teh CL (11-30-2018)
#324
CTSV,TL, Audi Q7 & A5SB
No doubt the AMG's especially the newer models with AWD are crazy.. However, over the years I've found that usually the guys in AMG63's, M5's, 911's RS5's etc, for the most part keep to themselves and don't antagonise you.. IME it's usually the guys (not everyone) in the modified Civics (lowered with fart cans), Altima's, Maximas and recently Accord Sports that think they are qualifying for the Indy 500.. I mean WTF...
teh CL (11-30-2018)
#326
But my favorite was a Maserati GT driver who clearly had no idea what a V was.. He found out the hard way when he decided to tailgate on a wide open highway. I was in the middle lane, other lanes open but the a-hole had to tailgate. So I put my foot down and he disappeared, then I backed off and got off two exits later and he's back and exits with me. Now at a light on the service road.. He takes off like a a maniac I reel him in and pass by him.. Next light same result..
Third light I already decided I'm done, let him do what he wants... He only pulls up to my quarter panel, light changes he drives away calm won't pass me even though I'm just cruising.. This continued for another 1/2 mile until I turned off, as soon as I turned I heard him floor it again. LOL... I will admit those cars sound really good...
The following 3 users liked this post by JT4:
#328
I think the older 2010ish 63's are beatable for sure. The new 63S' tho, I don't even make eye contact, I'll get off an exit early if anything..
It's definitely getting more interesting with some high performance cars dropping in value and getting picked up by the younger crowds. S4/S5's/AMG's are popping up everywhere around here.
teh CL (11-30-2018)
teh CL (11-30-2018)
teh CL (11-30-2018)
teh CL (11-30-2018)
#333
So far just an intake, all downhill after that..
I have a planned "stage 1" list of mods I'm hoping to have ready for the spring..
- 10" lower pulley
- LS9 cam
- 90mm TB
- Ported snout/port matched blower
- Injectors
- Reinforced brick
- Heat exchanger
- Meth
- Tune
Aiming for 14 psi & 600-650whp, meth will probably push that closer to 650..
I've always loved modding cars but having a platform that has serious aftermarket support & such a legit community is intoxicating to say the least. Also helps that there's an abundance of quality used parts which help take a load off the wallet, shit can get out of hand REAL fast...
- 10" lower pulley
- LS9 cam
- 90mm TB
- Injectors
- Reinforced brick
- Heat exchanger
- Meth
- Tune
#334
- 10" lower pulley
- LS9 cam
- 90mm TB
- Injectors
- Reinforced brick
- Heat exchanger
- Meth
- Tune
- 10" lower pulley
- LS9 cam
- 90mm TB
- Injectors
- Reinforced brick
- Heat exchanger
- Meth
- Tune
Now my only concern is tires/traction (what's the widest rears you can fit on a V? lol) and also longevity of trans/diff/axle....
teh CL (11-30-2018)
#335
The plan is to run 285's all around, want the car to handle. Knowing how to use the gas pedal is the key with this car lol.
As for tires, I really like the Pirelli Trofeo's. They're more of a track oriented tire but I had them on the RL & they were LEGIT. A big thing for me is finding a tire with a good balance of dry/wet performance, I drive my cars everywhere, rain or shine... or snow
Drivetrain wise, if anything is gonna go it would be the clutch. Still the original part & really isn't an issue till 650+hp. Otherwise, from what I've read, the drivetrain is pretty stout.
nist7 (11-30-2018)
#336
I had PSS and then Sumi and holy shit did those PSS hold traction well...
I would recommend them highly and they seemed to last a decent amount of mileage too.
You're nuts...650 wheel whore's power is what @CCColtsicehockey is making, roughly...
but he doesn't do burnouts so...
#337
Received 3,656 Likes
- 10" lower pulley
- LS9 cam
- 90mm TB
- Injectors
- Reinforced brick
- Heat exchanger
- Meth
- Tune
- 10" lower pulley
- LS9 cam
- 90mm TB
- Injectors
- Reinforced brick
- Heat exchanger
- Meth
- Tune
#339
#340
Those are similar numbers to what I am making. Any reason you don't want to go 9.1 lower with a 2.5 upper to get 15.5psi? I mean you already live where temps are colder and I wouldn't want to mess with meth if I didn't have too. There are plenty of ways to compensate for fuel without having to do that. If you are doing it for the cooling then do an overflow resovoir and get an upgrade pump. Also replace the hard line section to the heat exchanger. Doing that would would have 650 all the time instead of only when on meth.
Well that was the plan, till this weekend. Found a thread on ctsvowners about the Powerbond (Dayco) balancer with a 8.6 pulley for a crackhead price through Autozone. Called the Autozone just over the border in Niagara Falls to confirm the price & long story short, I now have a 8.6 lower for the crackhead price of $189.99...
Talk about a boost to the budget ..saved over $500 that I would of otherwise dished out for the ATI balancer. It's specifically built for the HSV GTS in Australia which shares the same LSA engine. So with that turn of events, I scrapped the 10" lower idea & aiming for a 2.45 upper to get to that 15.5 psi range.
As for the meth, I'm not 100% sold on it but there is some great info on it. I also have a buddy with a FBO 335i w/ only pre boost meth & he loves it. Simple setup that is boost dependent & is just consistent. I get the risks with meth but man is it tempting.. ..The other thing about the meth, it is cooler up here but the summers are brutal with the humidity so any aid in cooling is a plus, just not trying to push aggressive timing that's dependent of the meth..
#341
Even though the 2.5/9.1 & 2.4/8.6 are the tried and true setups for these cars, I like the idea of doing just a bigger lower once and not have to worry about an upper unless I really wanted to go all out. Another plus for lower only was that it would keep more of a sleeper engine bay with the stock upper.
I still suggest doing an icebox and larger pump. If you only do one though do the pump first with larger lines. As I am sure you have read heat is more an enemy to these engine than your average car. That is why I did every cooling mod possible.
#342
Definitely going with the griptech, if there's nothing used available at the time, I may grab this stage 1 kit which seems like a great price.. Stage 1
Cooling wise, ditching the hard lines and going 3/4" throughout. A ZL1 lid would be nice but really hoping to find a ZR1 pump, almost impossible but I'll jump on one as soon as it pops up.. ..Which pump are you using? Varimax?
#344
That is a right of passage though
#346
That's a good question..
If I can get to anywhere near 650whp I'm sure I'll be very happy & it will be plenty of car with the 6MT.
Loooonnngggg term, twins sounds like a blast..
#350
if you are just pushing everything in stockish locations (i.e. heat exchanger, lid, pump) then you can get away with a varimax and replace two of them before you hit the price of a ZR1 pump... if you added in an underhood tank with a lot more capacity i'd go ZR1 if you can find one, otherwise varimax works fine too... if you have a trunk tank i'd go EMP...
#351
Power is most definitely addicting. I'm also getting to the point where it doesn't seem as fast as when I first got it..
Chances of finding the pump used for a good price is slim to none & it is more of a wish list thing. Would never pay retail for one.. ..just gonna ride out the stock pump & upgrade if needed.
There's also no e85 up here, going 91 or 94 if anything.
#353
Well it's been an eventful few weeks roaming the CTS-V classifieds on FB. Wasn't planning on anything else for the car this year but some deals are too good to pass up.
This round of mods include:
- Milled ZL1 lid w/reinforced brick
- 1.8 Gal expansion tank
- Infamous ZR1 coolant pump
- Core short shifter w/ knob from Artem
Got around to installing the shifter last night & words can't describe how bad ass it is.
I thought the car was fun before, completely different animal now..
Merry Christmas guys..
#354
Your Friendly Canadian
Received 1,484 Likes
That shifter looks the tits.
teh CL (12-28-2018)
teh CL (12-28-2018)
teh CL (12-28-2018)
#357
Nice I like where this thread had turned. Lets see if your goals expand now. 750whp new goal
teh CL (12-28-2018)
teh CL (12-28-2018)
teh CL (12-28-2018)
#360
If I keep finding parts cheap enough who knows where I'll end up...
Been getting the itch to do more work on the car & still need to get fittings/hose for the coolant system so I decided to install the 90mm LS7 throttle body I've had for a while.
Was gonna wait to have it ported but I've been reading about the ZL1 guys bolting these up stock & picking up 10-15whp/wtq. Not sure if the power claims are legit but there have been more than a few dyno charts that confirm it.
Either way, bolted it up this morning & it literally took less than 15 minutes. Did the throttle relearn & initial impressions are that it definitely helped with throttle response, breaks loose a bit too easy now...
Here's some pics of the install..
Difference in size isn't much, 87 vs 90mm but the LS7 definitely has a bigger motor. Clearance is quite snug with the upper pulley..
Catch can is definitely a must...
All back together..
Quick pic, outside hiding at a family function...
nist7 (12-28-2018)
