teh CL.... lost his V card
#243
Been a while since the last update, just been thrashing the car to and from work.. ..Sucks that I have no exciting kill stories, there was a S3 that tried to dance but disappeared way to easy..
Managed to gather some parts over the last month or so & finally had some free time to get most installed this weekend. This round of mods consist of:
- 2nd set of V wheels so that I can run a squared (9.5") setup all around.
- 15mm bolt on spacers all around
- BC coilovers
- Mag ride delete kit
- 265/35/19 blizzaks x 4
The V community pretty much shuns anyone that even considers removing the mag ride setup & even worse if they mention BC coilovers, KW or bust it seems. I bit the bullet on the BC's since I've only heard good things about them & the icing on the cake was that my buddy has been riding slammed for over 5 years (winter/summer) without a single issue, plus it rode really well.
The second set of V wheels was just out of the blue, popped up locally for $300, hard to pass that up. One front wheel was bent so it was a perfect opportunity to run sedan rears all around. Sedan rears need spacers to clear the front spindle so I made the call to go 15mm all around. Most guys run 11mm front with 15mm on the rear but I think 15mm is the perfect touch.
Here's some pics of the goods..
The last pic is the mag ride delete kit that a member of the V community builds. A lot cheaper than the KW module & works flawlessly.
Got everything installed today except I couldn't squeeze in the rear coils.. ..Hopefully finish her off tomorrow.
Here's a sneak pic for now...
- BC coilovers
JT4 (10-29-2018)
#244
Don't forget to fuck with the spring cradles to set your camber pretty straight to save tires, especially rears.
I will say that after very few miles the bolt on spacers in the rear were super fucking hard to get off...like, almost stripped nuts taking them off. Sent them to Jason with that warning and low and behold he is having that issue now.
Something about the weight and burnouts maybe?...
teh CL (10-29-2018)
teh CL (10-29-2018)
teh CL (10-29-2018)
#248
Received 3,661 Likes
That thing looks awesome. Will be following to see how you like those coilovers. I had them for over 75k miles on my IS-F with no issues. For some reason though I can't convince myself to get rid of the magride.
Like J says I am having a terrible issue with my spacers. I didn't use any anti-seize when I put them on and after a thrashing at the dragon where my brakes were smoking I can't get them off now. Already stripped one nut. Probably going to have to get a torch involved to get them off now. Just be careful with them.
teh CL (10-29-2018)
#249
Wasn't planning to ditch the mag ride at first but my rears were semi toast when I bought the car & now they're just gone, pretty sure the fronts weren't far off either. The main reason for ditching it was the life expectancy of the struts, too many stories of premature failure once they've been replaced. Definitely didn't want that drama.
As for the spacers, I'm not planning to take them off till I need to do the brakes which shouldn't be for a bit.. :wish ..good to know though..
What did you guys torque the spacers to? I torqued the spacer to the car at 140 ft/lbs & the wheels to the spacer at 110 ft/lbs.
#250
105ftlbs on both for me and still had the issue
teh CL (10-29-2018)
#252
what brand spacers did you go with?
car looks amazing man, much more aggressive with the coils and spacers
teh CL (10-29-2018)
#253
Thanks man.
The brand is Customadeonly. There's more then a few companies I could have gone with but these are legit as it gets & they're made specifically for the V. Also helps that I sniped them for a great price..
teh CL (10-30-2018)
#255
H&R or Eibach are the Spacers I got from J.
I have run spacers on both my TSX and ISF for years and never had a single issue before these spacers. So it is possible it was just a bad batch or something but I have 5 different size bolt on for my TSX and ran 2 different kinds on the ISF for over 100k miles and never once did I have one I couldn't easily remove before this.
teh CL (10-30-2018)
#256
What dampening settings do you run on your BC's for your ISF? I know they're 2 different cars/setups, just trying to gauge a general idea.
Finished up the rears last night finally and they're set to 8 clicks from hard out of the box, definitely need to be softened.
#257
I am probably the odd man out. I will sacrafice comfort for handling. I ran mine 1/4 of the way from the hardest setting. I forget how many clicks total they are. I had 14k/12k spring rates on mine that I had custom ordered. What do the V ones come with?
teh CL (10-30-2018)
#258
The V comes with 10k/12k.
I'm the same with performance > comfort but the rears just seem a bit much. Could also be to much preload.
Thinking of dropping the rears to 15 clicks and leave the front at 22 clicks from soft.
teh CL (10-30-2018)
teh CL (10-31-2018)
teh CL (10-31-2018)
teh CL (10-31-2018)
#263
Here's some quick driveway pics, been wet for a few days so better pics will have to wait..
#264
Turd Polisher
It's insane how much of a difference the drop makes.
Stock wheels are
Beautiful car!
Stock wheels are
Beautiful car!
teh CL (10-31-2018)
#265
Literally fell in love with the car all over again, giggle just staring at it..
The wheels really stand out with the spacers. I loved my original silver wheels but the wheels I picked up are polished & they won me over real fast.. ...Was gonna paint them since they're mismatched but now I'm torn..
teh CL (11-01-2018)
#268
CTSV,TL, Audi Q7 & A5SB
How's the ride now compared to the mag ride??
I love the way the drop looks on your V.. I would like a slight drop but I just don't have the guts to do it with the roads around here..
#269
Roads around here are a consistent nightmare, that and construction is never ending..
With stiffness turned up, it definitely rough but handles ridiculously good but with it softened up it absorbs imperfections pretty well. Still playing around with the setting & need to dial in the ride height all around.
As for comparing to the mag ride, stock definitely absorbed better but was also rough at the same time, didn't help that my rears were on their last legs when I bought the car.
teh CL (11-01-2018)
teh CL (11-01-2018)
#272
A nice drop to a 1 finger gap all around really changes this car for the better. Adding the spacers made me realize just like you that new wheels are not a huge priority once they were flush.
teh CL (11-01-2018)
teh CL (11-01-2018)
#274
I'm surprised how well the LM-32's have gripped so far but I'm not complaining. I had great success a few years back with Blizzaks on my old 3.5 CL-S, torque/Blizzaks is a match made in heaven..
Except for a set of coupe 19x10 rears, I have no need for new wheels. These are just solid, factory forged FTW.
The current ride height is 0.5ish finger gap all around & it's perfect, no rubbing at all.
#275
Coupe Rears are aggressive...you won't be able to do fat rubber on those and from what I recall, the rear fenders are not exactly rollable...STRONG seam
Before your alignment, fuck with those cradles and dial your camber back, you'll thank me because in this car, the rears go FAST even perfectly aligned.
teh CL (11-01-2018)
#276
Yeah you are honestly better off having a set of front wheels widened from a sedan/wagon than going coupe rears. Pretty sure coupe rears are more aggressive than running a 15mm spacer in the rear like I have.
teh CL (11-01-2018)
teh CL (11-01-2018)
#278
They are 10in rears instead of 9.5 I believe.
teh CL (11-01-2018)
#279
Yea they are 10" vs 9.5" on the sedan.
There's mixed reviews from what I've seen but there's more than a few ppl that are running them with no issue, stock height tho...
With the 15mm spacers in the rear right now there's some clearance still for the wheel to be pushed out a bit for sure. Definitely wouldn't be able to run a 295 or 305 but I'm fine with that, a 285 would be a minimal stretch on a 10" & worse comes to worse I'd have to adjust the height. We'll see if I can snag even one cheap for testing purposes.
Love the look though, this V has coupe rears & I believe a 295 or even 305 which rubs when driven aggressively but......
The following 4 users liked this post by teh CL:
