resistors
Are you continuing on from this?
I believe in Darwinism, but... to be nice, I'd suggest getting a full kit or a professional install instead of picking resistors out of a parts bin. There's a lot to consider and you don't want to overheat and burn a resistor around gasoline.
Someday, an RS6 Avant+
The reason for a resistor is to drop voltage across it, so the other end has a lower voltage. If you are replacing one, be sure the colors are exactly the same. Do not get a higher ohm rated resistor, as you will have issues. Also, the last color, the tolerance is important. Don't say silver is like gold and that's OK. It's not. it's a percentage, and you don't want to screw that up.
So what exactly are you doing and what wire are you talking about?
Greengecko
09-16-2015 08:19 PM
enigmaos
11-07-2007 12:12 PM
DerrickM
02-05-2005 12:20 AM
