Preview: 2006 BMW M5... from msn autos
Yeehaw
Anyone read this? I didn't see anything about the 06 m5 on here.
http://autos.msn.com/advice/article....rc=LP%20luxury
This makes me drool.
Stand By for Take-Off . . .
Still, the marketers insist that's what the customer wants, choice, and the engineers have delivered—and then they've added that ultimate option, launch control, which goes like this: Select full, 507-horsepower grunt via the one-touch "M Drive" button on the wheel (which also optimizes the damper and stability settings and turns the effective and clear head-up instrument display into a rev-counter and gearshift indicator. Now disable the Dynamic Stability Control, select the most aggressive of the "S" shift programs, hold the gearshift lever forward and floor the throttle.
The engine builds to optimum launch revs and stays there until you let go of the lever. Then the car catapults forwards with a chirp of tires and a mighty howl of power while you keep the pedal buried in the luxurious carpet. When the revs peak, it slams into the next gear and rides out the wheelspin, and then the same again, and again, and again—with barely describable violence—until it hits the M5's voluntarily restricted 250 kph (155 mph) maximum, or in our case, an indicated 272 kph (170 mph), which the engineers put down to "tolerances."
This is a very impressive feature but also worryingly brutal, and you wonder what it's for, since it's also thoroughly anti-social. Besides, if you do it more than twice in succession you have to give the car time to recover and re-program the whole thing all over again.
i'm 6'3" and i fit into a new 545 just fine.
Pit Stop?
Originally Posted by Minch00
When I sat in one at the Auto show, I couldn't find a comfortable driving position, and I actually sat behind the B-pillar with the seat so far back, so I would scrape my back climbing out. Also, it rendered the seat behind the driver useless.
it's a good thing the HUD is replaced with a rev counter and gear indicator when you switch into that "M" mode, because well, God forbid you wouldn't know that in a automatic-trannied car....
Originally Posted by mrsteve
The EURO M3 had a system like that. After you did it 30 times though you had to replace the clutch
It was also on the US M3's. evidently there are 2 levels of launch, 2k rpm and 4k rpm. I was passenger for the 2k, and i must say it is violent and loud....and oh so fast.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
