PICTURE of my stock 335I automatic transmisson Fluid at 51K miles
Informative Video:
http://www.youtube.com/watch?v=b3MSaW-9BGk&
This weekend, I changed my automatic transmisson, power steering, brake, and coolant fluids. I wanted took a picture of my car's automatic transmission fluid because It had never been changed, and it had "lifetime fluid" written on it. Because of this dealerships, gave me so much BS, about never, ever changing it. So here it is(oh,and it smelled like burn't coke too
![](http://i667.photobucket.com/albums/vv37/Turkeybaster115/335IATF2.jpg?t=1256355565)
Please replace your fluids! The transmission now is silky smooth! My steering, braking, and engine temps are also an equal WOW! I got all my fully synthetic OEM fluids from: www.rmeuropean.com
![](http://i667.photobucket.com/albums/vv37/Turkeybaster115/335IATF1.jpg?t=1256356166)
wow. That is bad. It looks more like used motor oil than ATF
![what](https://acurazine.com/forums/images/smilies/what.gif)
registered pw
Saw your thread on E90post. Someone posted a DIY pictorial on one of the 5-series forums and said it takes about 3 hours and $400 in parts/fluid to do a change and that dealers charge $800. In fact, some dealers won't change the fluid before the 100K mile "lifetime" period is up, claiming that changing the fluid prematurely can actually result in transmission failure.
How much did it cost you to change it and how long did it take?
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
The thing is that honda/acura build their own transmissions, in house. BMW and other manufacturers buy them prebuilt from ZF, and all they do is transmissions.
All you need to do to change it is drain the fluid. Put the drain plug back (you need to be careful with the plastic pans to not tighten the plug to much). Remove the fill screw and fill the trans till the fluid comes out. Loosely put the screw back in and start the car. Turn on the headlights and then as quick as possible fill the trans again till fluid starts running out the fill hole. Reinstall the fill plug and your done. It shouldn't take more than 1 hour even doing it in your drive.
Esso sells a fluid that is pretty much the same thing as the new BMW lifetime fluid but costs a lot less. Even that stuff isn't cheap.
My buddy here at work, bought a used Jaguar S type R, and his is "lifetime fluid" too. He just flushed his. I am flushing my Audi A6 3.2 Quattro tranny this weekend. Guess what type of fluid is stickered on the trans? (*******e)
http://www01apps.zf.com/kst464/ZF_In...doID=1&id=2243
It's just a marketing gimmick for lazy people who'd rather buy a new car than have to be bothered with any maintenence issues.
The thing is that modern cars with modern lubrication can last way too long. If everyone maintained their car properly and ran them to 300k+ miles, that would be a problem for the automakers.
That's half the story. If you look at the ZF website, there are at least 2-3 companies in each state in the US, that specialize in rebuilding their transmissions. They intend to fool you into killing the trans early, and then simply swap them out for a rebuilt one, for your right arm.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
'10 Hyundai Genesis Coupe
You have to understand that most of the vehicles sold by these companies are aimed towards the layperson. Someone with little to none automotive know how, and they'll attempt to do anything to get them to purchase the cars.
Even if it means spreading myths about lifetime ATF. I will guarantee you that in a few years the 10K oil change interval will become 25K and then before we know it lifetime.
CLtotheTL32 (06-23-2013)
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
effing noobs.
![Zombie](https://acurazine.com/forums/images/smilies/zombieSmiley.gif)
אני עומד עם ישראל
Timely bump is timely.
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
2006, 335i, 4runner, a5, acurazine, bauer, bmw, change, diy, eddie, expedition, fluid, milkshake, strawberry, transmission, transmisson, zf
