One step closer to a complete garage
Received 3,655 Likes
To own an NSX has been a dream of mine for a long time. I had posters of one on my wall growing up. A friend of mine has owned this car for the last 8 years. I have told him for a good while if he was going to get rid of it to please let me know. He decided it was time to move on from it a couple months ago and so I decided to see if I could make it happen. This Friday I took delivery of it. From far the car looks absolutely perfect. There are some things that need some TLC and the car doesn't have a perfect history but that is what allowed me to be able to pick it up. That being said it drives amazingly, runs strong, and has perfect alignment. I wasn't looking for a collectors car as I am going to drive it as much as possible. I have already put 250 miles on it in the first weekend.
The following 25 users liked this post by CCColtsicehockey:
00TL-P3.2 (10-23-2018),
1killercls (10-22-2018),
Aman (10-22-2018),
BreezyTL (11-06-2018),
F23A4 (11-15-2018),
and 20 others liked this post.
Popular Reply
06-23-2020, 08:20 AM
Been a long time since an update. I also had basically stopped driving the car for almost 3 months earlier this year. It had developed an oil leak and even on short drives, the car would have smoke coming out the back of the engine bay. Obviously, this meant that somewhere oil was dripping on some part of the exhaust.
Car got awful dirty just sitting.
Removed the engine cover for easier access.
All open now.
Removed the rear diffuser to get better access below.
Borrowed a horoscope from a friend to try and get a better look in tight spots. I need to buy one of these eventually but hopefully these days someone makes one with a little higher resolution.
This is what I believe is where my rear valve cover leak is
The problem is I do not believe that is the only leak the car has. There is just too much oil in other places to all having been coming from there. The car had a very slight oil leak from the oil pan when I bought it. The leak was not near the exhaust and it was so minor at the time that I could just wipe the seepage off when I did an oil change and once in between changes and everything was fine. It wasn't worth the time to drop the front header. It might now be time to tackle that next. I believe this is coming down from the oil pan.
A third leak I believe is coming from the cam seals for the cam gears. Oil is leaking out fo the plastic timing belt cover and then down the oil cooler line.
I cleaned up everything as much as possible to try and help determine the other leaks.
Oil ended up leaking again from the cam seal/timing belt side.
So with that, it was time to at least replace the rear bank valve cover gasket and see if that fixed some things. I knew there was only a little space in the back but damn is the rear bank a pain to work on.
Cover off. It looks nice and clean.
The engine looks clean as well.
Timing belt looks good as well which was nice to be able to get a peek at since it was suggested by me from a reputable shop that with as low miles as the car has on it that I should go to 10 years instead of changing it right now.
New gasket with Honda bond prior to reinstall. Many choice words were spoke during the resinstall and it took me 8 tries to finally get the cover back on and in place.
So far so good and no leak on the cam plug side.
So once I put the car back together and drove it in small 5 mile drives I had smoke for about 15miles. After that, it was gone. I figured this was the residual oil that has built up in the heat shield of the rear manifold. Being overly cautious I then proceeded on three more 5 mile increment drives and stopping to check for smoke. Then increased to 10 miles, 15 miles, and 20 miles. After that, I figured for the time being at least I was good. Not sure if it is the valve cover completely or cause I cleaned up all the oil. I still have a leak from the oil pan and a little bit of oil again coming from the timing belt cover area. They seem to be slow and if I keep up with keeping them clean they should not cause me issues of smoking again hopefully. They do not seem to be leaking fast enough at all to cause an issue with my oil level either. This past Friday I took the car from Charlotte to Asheville and back with no issues. It was nice to do a day trip in it again.
Shot from before the car started smoking.
First longerish drive after the repair. Stopped at my dads place.
Asheville road trip from Friday.
All open now.
Wow! Congrats!
CCColtsicehockey (10-22-2018)
Thanks!
Took her to a ride the night I picked it up. We went to a local car meet with it. Then we took it Sunday morning to go out for breakfast. She likes it actually and was even ok with me getting it surprisingly since she knew I have wanted one since I was little.
The following 2 users liked this post by TLDude876:
I am sure you do. You will still have time. I definitely couldn't have done it if I had little ones around that is for sure.
Thanks bud. I will definitely have to bring it down at some point. Not sure if I will be able to make November though. Always in for a free detailing.
juniorbean (10-22-2018)
rockstar143 (11-01-2018)
Yeah I just went for a drive trying to find a good place for some pictures and happened on that spot. Never knew about it. Definitely cool little area.
The following 2 users liked this post by Flipster23:
CCColtsicehockey (10-22-2018),
Azine Jabroni
Honda used to be incredible. Maybe they'll get back there someday
Congrats!
Congrats!
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
No shit!? So awesome bro, congrats! NSX is one of my dream cars as well, crazy that you got one!
(Mid-Atlantic)
(Mid-Atlantic)
Dude texts me pics of his meat all weekend, fails to mention he bought a fucking supercar
The following 2 users liked this post by 97BlackAckCL:
teh CL (10-29-2018)
97BlackAckCL (10-22-2018)
Turd Polisher
Congrats Jason! What a beautiful machine
You Cccocksuck
er
er
The following 4 users liked this post by Majofo:
97BlackAckCL (10-22-2018),
CLtotheTL32 (11-09-2018),
If you don't get pussy in that, J will suck yo dick
You know this already
Turd Polisher
Any more details on the car? Mileage? 6MT?
Turd Polisher
#facts
AZ Community Team
Very nice! Congrats
Love the pics, very professional
CCColtsicehockey (10-23-2018)
No I still have the V. It has been kicked outside for the time being.
Yeah the old stuff is great.
Sorry bud I was too busy driving it all weekend when I wasn't cooking.
Thank you
Thank you
The following 5 users liked this post by CLpower:
juniorbean (10-22-2018),
neuronbob (10-29-2018),
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
Btw, adrienne has been begging me to add one of these to the stable. I'm hesitant since I can't fit the kids int he back of.
Congrats man, that thing looks awesome. Definitely jelly over here.
Turd Polisher
Received 7,772 Likes
I hate you CCColtsicehock
ey, in the nicest way possible. But seriously, congratu- I hate you.
The following 2 users liked this post by cu2wagon:
Nice Prelude
The following 3 users liked this post by thoiboi:
Needs more Lemon Pledge
Whoa congrats! She is a beauty!
Thank you
I like this generation in Black but honestly had this not fallen in my lap I prefer the flip up headlights one. This one was just too much done up the exact way I would have done it already so it saved me a bunch of money that way.
Yeah that is it. Crazy. My buddy bought it 8 years ago with 19k miles on it. He did long distance cross country trucking for a long time so he only got to drive it like 1 or 2 times a month.
Thank you
Thank you
Thank you
