One step closer to a complete garage
Old 10-21-2018, 09:23 PM
CCColtsicehockey's Avatar
Received 3,656 Likes on 2,490 Posts
To own an NSX has been a dream of mine for a long time. I had posters of one on my wall growing up. A friend of mine has owned this car for the last 8 years. I have told him for a good while if he was going to get rid of it to please let me know. He decided it was time to move on from it a couple months ago and so I decided to see if I could make it happen. This Friday I took delivery of it. From far the car looks absolutely perfect. There are some things that need some TLC and the car doesn't have a perfect history but that is what allowed me to be able to pick it up. That being said it drives amazingly, runs strong, and has perfect alignment. I wasn't looking for a collectors car as I am going to drive it as much as possible. I have already put 250 miles on it in the first weekend.
The following 25 users liked this post by CCColtsicehockey:
00TL-P3.2 (10-23-2018), 1killercls (10-22-2018), Aman (10-22-2018), BreezyTL (11-06-2018), F23A4 (11-15-2018), Hockeyman (10-22-2018), JT4 (10-22-2018), jupitersolo (10-22-2018), Ken1997TL (10-22-2018), kurtatx (10-22-2018), Legend2TL (10-22-2018), Majofo (10-22-2018), neuronbob (10-29-2018), nist7 (10-22-2018), rockstar143 (11-01-2018), RPhilMan1 (10-22-2018), SamDoe1 (10-22-2018), Sarlacc (10-22-2018), srika (12-28-2018), stogie1020 (10-22-2018), SykVSyx (10-22-2018), teh CL (10-29-2018), ttribe (10-22-2018), Undying Dreams (08-13-2019), Yumcha (10-22-2018) and 20 others liked this post. (Show less...)
Popular Reply
06-23-2020, 08:20 AM
CCColtsicehockey
Been a long time since an update. I also had basically stopped driving the car for almost 3 months earlier this year. It had developed an oil leak and even on short drives, the car would have smoke coming out the back of the engine bay. Obviously, this meant that somewhere oil was dripping on some part of the exhaust.
Car got awful dirty just sitting.
Removed the engine cover for easier access.
All open now.
Removed the rear diffuser to get better access below.
Borrowed a horoscope from a friend to try and get a better look in tight spots. I need to buy one of these eventually but hopefully these days someone makes one with a little higher resolution.
This is what I believe is where my rear valve cover leak is
The problem is I do not believe that is the only leak the car has. There is just too much oil in other places to all having been coming from there. The car had a very slight oil leak from the oil pan when I bought it. The leak was not near the exhaust and it was so minor at the time that I could just wipe the seepage off when I did an oil change and once in between changes and everything was fine. It wasn't worth the time to drop the front header. It might now be time to tackle that next. I believe this is coming down from the oil pan.
A third leak I believe is coming from the cam seals for the cam gears. Oil is leaking out fo the plastic timing belt cover and then down the oil cooler line.
I cleaned up everything as much as possible to try and help determine the other leaks.
Oil ended up leaking again from the cam seal/timing belt side.
So with that, it was time to at least replace the rear bank valve cover gasket and see if that fixed some things. I knew there was only a little space in the back but damn is the rear bank a pain to work on.
Cover off. It looks nice and clean.
The engine looks clean as well.
Timing belt looks good as well which was nice to be able to get a peek at since it was suggested by me from a reputable shop that with as low miles as the car has on it that I should go to 10 years instead of changing it right now.
New gasket with Honda bond prior to reinstall. Many choice words were spoke during the resinstall and it took me 8 tries to finally get the cover back on and in place.
So far so good and no leak on the cam plug side.
So once I put the car back together and drove it in small 5 mile drives I had smoke for about 15miles. After that, it was gone. I figured this was the residual oil that has built up in the heat shield of the rear manifold. Being overly cautious I then proceeded on three more 5 mile increment drives and stopping to check for smoke. Then increased to 10 miles, 15 miles, and 20 miles. After that, I figured for the time being at least I was good. Not sure if it is the valve cover completely or cause I cleaned up all the oil. I still have a leak from the oil pan and a little bit of oil again coming from the timing belt cover area. They seem to be slow and if I keep up with keeping them clean they should not cause me issues of smoking again hopefully. They do not seem to be leaking fast enough at all to cause an issue with my oil level either. This past Friday I took the car from Charlotte to Asheville and back with no issues. It was nice to do a day trip in it again.
Shot from before the car started smoking.
First longerish drive after the repair. Stopped at my dads place.
​​​​​​​Asheville road trip from Friday.
Old 10-21-2018, 11:00 PM
ttribe's Avatar
Received 5,880 Likes on 2,898 Posts
Wow! Congrats!
CCColtsicehockey (10-22-2018)
Old 10-22-2018, 05:05 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,651 Likes on 1,116 Posts
Wow man! That's awesome! Have you taken your girlfriend for a ride in it yet? Congrats bro!
Old 10-22-2018, 06:23 AM
Originally Posted by ttribe
Wow! Congrats!
Thanks!
Took her to a ride the night I picked it up. We went to a local car meet with it. Then we took it Sunday morning to go out for breakfast. She likes it actually and was even ok with me getting it surprisingly since she knew I have wanted one since I was little.
Old 10-22-2018, 07:24 AM
JT4
CTSV,TL, Audi Q7 & A5SB
JT4's Avatar
Congrats, it's beautiful!!
Old 10-22-2018, 07:33 AM
kevinh1919's Avatar
Gorgeous!
You should be easy to spot riding around town.
Old 10-22-2018, 08:28 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
That's awesome Jason! If I didn't have two freakin' leeches (that I love with all my heart), I would have gotten one a long time ago.
Old 10-22-2018, 08:35 AM
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
Congrats! Now I regret my decision of getting a pool instead of a NSX
The following 2 users liked this post by TLDude876:
00TL-P3.2 (10-23-2018), CCColtsicehockey (10-22-2018)
Old 10-22-2018, 09:05 AM
juniorbean's Avatar
Received 1,760 Likes on 1,046 Posts
Whoa! So awesome Jason! I've seen that car a bunch at C&C over the years... always loved it. Make sure you bring that to C&H in November! Let it get a little dirty and I'll have Croftgate take care of you!
Congrats! Can't wait to see it in person
Old 10-22-2018, 09:17 AM
I am sure you do. You will still have time. I definitely couldn't have done it if I had little ones around that is for sure.
NSX > Pool
Thanks bud. I will definitely have to bring it down at some point. Not sure if I will be able to make November though. Always in for a free detailing.
juniorbean (10-22-2018)
juniorbean's Avatar
PS - Great photo backdrop
Old 10-22-2018, 09:20 AM
Yeah I just went for a drive trying to find a good place for some pictures and happened on that spot. Never knew about it. Definitely cool little area.
Old 10-22-2018, 09:22 AM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Congrats.
Did you sell your V too like J did?
The following 2 users liked this post by Flipster23:
CCColtsicehockey (10-22-2018), rockstar143 (11-01-2018)
Old 10-22-2018, 09:24 AM
Azine Jabroni
kurtatx's Avatar
Received 2,158 Likes on 1,386 Posts
Honda used to be incredible. Maybe they'll get back there someday
Congrats!
Old 10-22-2018, 09:25 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
No shit!? So awesome bro, congrats! NSX is one of my dream cars as well, crazy that you got one!
Flipster23's Avatar
Congrats!
Certain Honda's are decent. As long as it doesn't have Acura anywhere on it.
Old 10-22-2018, 09:26 AM
(Mid-Atlantic)
Dude texts me pics of his meat all weekend, fails to mention he bought a fucking supercar
The following 2 users liked this post by 97BlackAckCL:
CCColtsicehockey (10-22-2018), teh CL (10-29-2018)
Flipster23's Avatar
What a shitty friend.
97BlackAckCL (10-22-2018)
Old 10-22-2018, 09:28 AM
Turd Polisher
TylerT's Avatar
Received 3,006 Likes on 1,514 Posts
Congrats Jason! What a beautiful machine
Old 10-22-2018, 09:30 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
You Cccocksuck
er
The following 4 users liked this post by Majofo:
97BlackAckCL (10-22-2018), CCColtsicehockey (10-22-2018), CLtotheTL32 (11-09-2018), rockstar143 (11-01-2018)
Old 10-22-2018, 09:31 AM
Majofo's Avatar
If you don't get pussy in that, J will suck yo dick
You know this already
Old 10-22-2018, 09:33 AM
Turd Polisher
TylerT's Avatar
Any more details on the car? Mileage? 6MT?
Old 10-22-2018, 09:34 AM
Flipster23's Avatar
Even if he gets pussy in that, J will suck his dick.
Old 10-22-2018, 09:36 AM
Turd Polisher
TylerT's Avatar
J is a giver.
Old 10-22-2018, 09:38 AM
Majofo's Avatar
#facts
Old 10-22-2018, 09:50 AM
AZ Community Team
Legend2TL's Avatar
Received 4,019 Likes on 2,497 Posts
Very nice! Congrats
Love the pics, very professional
CCColtsicehockey (10-23-2018)
Old 10-22-2018, 09:55 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
It begins....
Old 10-22-2018, 09:57 AM
Congrats.
No I still have the V. It has been kicked outside for the time being.
Congrats!
Yeah the old stuff is great.
Sorry bud I was too busy driving it all weekend when I wasn't cooking.
Thank you
Old 10-22-2018, 09:58 AM
teh Senior Instigator
CLpower's Avatar
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
FUCK YESSSSSSS
I've gotta say, 15 years ago I never thought we'd have the garages we all do
The following 5 users liked this post by CLpower:
97BlackAckCL (10-22-2018), CCColtsicehockey (10-22-2018), juniorbean (10-22-2018), neuronbob (10-29-2018), rockstar143 (11-01-2018)
Old 10-22-2018, 10:02 AM
CLpower's Avatar
Btw, adrienne has been begging me to add one of these to the stable. I'm hesitant since I can't fit the kids int he back of.
Old 10-22-2018, 10:26 AM
Received 5,827 Likes on 3,849 Posts
Congrats man, that thing looks awesome. Definitely jelly over here.
Old 10-22-2018, 10:31 AM
I guess that would have been good information to put in the first post
2002 NSX 6MT with 32,197 when I picked it up.
Old 10-22-2018, 10:38 AM
Turd Polisher
TylerT's Avatar
This generation definitely has the best looking front end. LOVE it.
Old 10-22-2018, 10:47 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
LISTEN TO THE WIFE! That's what trailers are for!
Old 10-22-2018, 10:48 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
That's it?!
Old 10-22-2018, 10:59 AM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
I hate you CCColtsicehock
ey, in the nicest way possible. But seriously, congratu- I hate you.
The following 2 users liked this post by cu2wagon:
Old 10-22-2018, 11:00 AM
Received 8,575 Likes on 6,626 Posts
Nice Prelude
The following 3 users liked this post by thoiboi:
00TL-P3.2 (10-23-2018), CCColtsicehockey (10-22-2018), TylerT (10-22-2018)
Needs more Lemon Pledge
stogie1020's Avatar
Received 2,000 Likes on 1,173 Posts
Whoa congrats! She is a beauty!
Old 10-22-2018, 12:07 PM
FUCK YESSSSSSS
I definitely didn't think I would that is for sure
Do it! One of the best driving experiences I have ever had. Although I haven't driven the 911 like you have to compare.
Thank you
Old 10-22-2018, 12:12 PM
I like this generation in Black but honestly had this not fallen in my lap I prefer the flip up headlights one. This one was just too much done up the exact way I would have done it already so it saved me a bunch of money that way.
That's it?!
Yeah that is it. Crazy. My buddy bought it 8 years ago with 19k miles on it. He did long distance cross country trucking for a long time so he only got to drive it like 1 or 2 times a month.
Thank you
Nice Prelude
Thank you
Quick Reply: One step closer to a complete garage
