The Official Honda S2000 Thread
Old 09-23-2014, 02:17 AM
  #3761
jtrix21's Avatar
Definitely more likely to be wheels/tires than the buckets. Sticky weights just aren't as secure as hammer weights, also.
Assuming tires are new and not worn unevenly, like scalloped or feathered.
Old 09-23-2014, 06:45 AM
  #3762
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
Recently installed rear tires and balanced all 4 and now I am having vibrations around 65-75 mph. I suspect an improper balance at this time. Also my rear end feels unstable. Did some reading and it turns out I have break in the new tires. Reason enough for me drive the car daily this week
Old 09-23-2014, 07:45 AM
  #3763
The Dumb One
Rockstar21's Avatar
Originally Posted by TommySalami
worn CV buckets vibrate on-throttle because they get pitted when they're at the normal wear spot, so if the vibration is mainly while on-throttle then that could be the culprit.
after 65-ish, it vibrates whether on on throttle, off throttle or braking..
height change didn't alter it at all. im going to throw my stock wheels on today and drive home, if they don't vibrate, the new wheels will already be off the car and i'll run them to the shop before they close.
thanks for the input guys.
also, im going to buy the axles spacers regardless. I've read that even when the axles aren't the culprit, the spacers help prolong the life of axles anyways.
and for $100, I cant find a reason not to run them.
Old 09-23-2014, 09:00 AM
  #3764
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,140 Likes on 4,807 Posts
If its happening on and off throttle, its the wheels.
Rockstar21 (09-23-2014)
Old 09-23-2014, 11:32 AM
  #3765
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
Are your new tires happen to be the V12 Evo?
Old 09-23-2014, 03:13 PM
  #3766
TLDude876's Avatar
No Kumhos. You had a similar experience?
Old 09-23-2014, 03:48 PM
  #3767
oonowindoo's Avatar
i had something similar on my s2000 with the V12 Evo and i only replaced the rear also (front ones were V12 Evo also at about 60%)
it was so scary at 60mph+ on the fwy, i had to pull over to check if they were flat.
the full break-in period was about 1500 miles.
I have the same set on my 335i and they were fine since day 1. The break in period is a lot less dramatic than s2000.
Maybe because of the weight or maybe uneven thread (new match with old) but it took me a while to get rid of the "driving on snow" feeling.
Old 09-23-2014, 03:53 PM
  #3768
TLDude876's Avatar
I've come to realize that the s2k is a very sensitive piece of machinery. When I first felt it I was like wtf
Old 09-23-2014, 04:22 PM
  #3769
oonowindoo's Avatar
yes.
it is one high maint. bitch but when she knows how to make you happy.
I'd suspect it is very similar to NSX. It is precisely engineered car. So you will feel every little difference if it is not the same as stock.
Old 09-24-2014, 11:52 AM
  #3770
Turd Polisher
TylerT's Avatar
Received 3,006 Likes on 1,514 Posts
Morgan is back!
Welcome
So, I drove my car for the first time in 3 1/2 weeks after traveling abroad and yes, it was absolutely orgasmic - it really puts you in perspective after driving 1.2L Opel Corsas & Peugeot 208 diesels every day over the course of 1700 miles
No real updates other than destroying my driver-side door & unibody after tagging a pole pulling out of my parking spot
I already went ahead and purchased an GPW AP1 door and plan on swapping over all of the electrical, windows / window regulator / rails, switches, and etc - Good news is it has OEM paint & no dents.
I'll address the unibody repair at another time, so far it's not looking like an easy task.
Anybody have any insight on that?
Old 09-24-2014, 12:23 PM
  #3771
civicdrivr's Avatar
Which broad were you traveling?
As far as the damage, post a pic. The car sounds totaled though. I'll buy it from you for $100, for...you know...parts.
TylerT (09-24-2014)
Old 09-24-2014, 12:40 PM
  #3772
Turd Polisher
TylerT's Avatar
I traveled all over Croatia and I must say, women there are stunning to look at
I have an excellent girl back home and while I was tempted, not just any girl would volunteer to help you swap out the driverside door on your car .
Door will be replaced, unibody is dented pretty deep - see pic:
The following 2 users liked this post by TylerT:
civicdrivr (09-24-2014), rockstar143 (09-24-2014)
Old 09-24-2014, 01:39 PM
  #3773
The Dumb One
Rockstar21's Avatar
ouch
TylerT (09-24-2014)
Old 09-24-2014, 01:43 PM
  #3774
I drive a Subata.
JS + XES's Avatar
Received 2,603 Likes on 1,571 Posts
Welcome back, Tyler!
Let's hit the track in October!
TylerT (09-24-2014)
Old 09-24-2014, 02:04 PM
  #3775
Turd Polisher
TylerT's Avatar
Originally Posted by Rockstar21
ouch
Tell me about it - I have to walk up to that 2 - 3 times a day
Thanks Jin!
While I like entertaining the idea of going in October, the car is in need of some work before I put it through it's paces once again.
To do list:
Clutch - feels like it's getting a bit tired. No idea when it was last changed, but it slips on quick high rev shifts.
Tires - Ventus V12 Evo2s are good for every day use, but I wouldn't want them on a track day. I'd like to invest in different wheels & more aggressive tire setup and alternate when necessary.
Coilovers - Old & mushy Form and Function Type 2s ... enough said
Really considering KW or a Bilstein / spring combo, just don't have that kind of cash to throw around. I've heard decent ratings on BuddyClub, I'd just prefer getting a higher quality suspension setup and be done with it.
Bushings - The car just turned over 130,000 and I think a wide range of bushings could be replaced, car still feels pretty tight but I think there's improvement to be made.
Old 09-24-2014, 02:40 PM
  #3776
civicdrivr's Avatar
Originally Posted by TylerT
http://i109.photobucket.com/albums/n53/Engage373/image1_zpsa852ace4.jpg
Yep. Just what I was afraid of, totaled.
My offer still stands
Old 09-24-2014, 03:26 PM
  #3777
Turd Polisher
TylerT's Avatar
Only if you get Eiffel towered by Tyler and myself - Tyler sandwich.
Despite the car being hit with an ugly stick a bit, I love this thing .. it's almost become more than "just a car".
Old 09-24-2014, 06:32 PM
  #3778
I drive a Subata.
JS + XES's Avatar
Thanks Jin!
To do list:
Man. That's some juicy stuff you need to take care of.
Will definitely go when you are done with all that later.
Old 09-24-2014, 09:19 PM
  #3779
E92
TommySalami's Avatar
Thanks Jin!
To do list:
I have custom race valved Konis with an assortment of springs for sale
I'll drop the price a little for you, lemme know if you're interested
http://www.s2ki.com/s2000/topic/1094...-amsoil-5w-40/
Old 09-24-2014, 09:23 PM
  #3780
oonowindoo's Avatar
i miss my s2000(s) =(
On Buddyclub Coils
on Tein Springs
The following 4 users liked this post by oonowindoo:
MarbleGT (09-26-2014), MEKO (09-30-2014), neuronbob (09-29-2014), RPhilMan1 (09-25-2014)
Old 09-25-2014, 06:36 PM
  #3781
Turd Polisher
TylerT's Avatar
FS: Custom Koni Yellows, Gendron FSB, AMSOIL 5w-40 - S2KI Honda S2000 Forums
If they don't move in the next 2 - 3 weeks, I will be PMing you.
Thank you for the offer.
JS + XES (09-25-2014)
Old 09-26-2014, 04:38 AM
  #3782
zac
zac's Avatar
Reading Mayor says his car was stolen; "it was my baby" | Regional: Berks - Home
The Reading mayor got his S stolen yesterday. He owned it new from 2001.
Old 09-26-2014, 08:37 AM
  #3783
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Old 09-26-2014, 01:15 PM
  #3784
I drive a Subata.
JS + XES's Avatar
That would break my heart.
Can Honda step up their PR with building a new one for him?
NOPE.
Old 09-26-2014, 01:52 PM
  #3785
'08 MX5 GT 6spd.
MarbleGT's Avatar
Received 1,192 Likes on 485 Posts
on Tein Springs
Are Tein springs as fucking terrible on the S as they are for the MX5? I had them at first and the drop was completely uneven on every corner and the spring rates were laughable...under 100lbs in the rear. Lots of verified issues within the MX community.
Old 09-26-2014, 03:59 PM
  #3786
oonowindoo's Avatar
i had coils and it was just too much as a DD.
I had Tein S tech on my G35 and felt like stock. so i tried the S tech on S2000, felt like stock, which was exactly what i wanted. I did not want it to be any stiffer.
other than ride height, it did absolutely nothing. better or worse.
Old 09-26-2014, 04:33 PM
  #3787
E92
I love my Ohlins DFV, such a comfortable ride
Old 09-27-2014, 04:02 AM
  #3788
Those are pricey, huh?
Old 09-27-2014, 05:51 AM
  #3789
neuronbob's Avatar
Received 4,612 Likes on 2,193 Posts
I was about to post this as I saw the discussion on S2KI. He parked it on the street, at night, IN REDDING, which is well known to have a car theft problem, and walked home. What could go wrong? I feel sick for him at this loss, but it's likely already stripped.
Old 09-27-2014, 07:15 AM
  #3790
zac
zac's Avatar
I don't know what he was thinking. Its not a pleasant city, I live near it, but will not cross the bridge in unless I'm passing straight through to get to the Pagoda.
Old 09-27-2014, 08:33 AM
  #3791
TLDude876's Avatar
Why would he leave it out and not take it home?
Old 09-27-2014, 08:43 AM
  #3792
Turd Polisher
TylerT's Avatar
Personally, I would never leave my S2000 overnight unless it was out of plain sight with some kind of protection (Parking garage, friend's garage, parent's house, etc), especially in an area like that.
Old 09-27-2014, 10:58 AM
  #3793
'08 MX5 GT 6spd.
MarbleGT's Avatar
$2K~. Average for high end street stuff.
The following 2 users liked this post by MarbleGT:
Costco (09-27-2014), rockstar143 (09-29-2014)
Old 09-27-2014, 12:42 PM
  #3794
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
I was once in the school of thought that stiffer = better and couldn't imagine spending even $1.5k on coils. Then I rode in cars with more than double the factory spring rate, yet they rode better than stock
Old 09-28-2014, 07:21 PM
  #3795
E92
What they said. You get far better handling, plus a better ride on the street. Really amazing technology with their valving
Old 09-28-2014, 07:37 PM
  #3796
'08 MX5 GT 6spd.
MarbleGT's Avatar
It all works together and there has to be a balance.
Old 09-29-2014, 10:38 AM
  #3797
Good to know, thanks.
Also,
S2000 is gone. 401k loan payoff for down payment on our new house was more important right now. Sold to a close friend on the forums. He made a solid offer that made me consider parting with it...He flew down and drove back to Jersey in it on Saturday.
I'll miss it dearly.
Old 09-29-2014, 11:06 AM
  #3798
Turd Polisher
TylerT's Avatar
Noooo
You'll be back, they always come crawling back
This weekend was productive
I started my door swap and unfortunately, I did not finish. I started at around noon and called it quits at around 6:30pm, swapping over the door handle, door lock, door lock actuators & windows was a pain in the ass .
All the leg work is done, door is mounted, window & rails are in, electrical is run - just need to figure out why the lock isn't engaging & disengaging .. it tries, but never makes the full transition from unlock to lock
Here are the pics:
Before:
Work area:
Door removed:
The door is gone ... why not go for a drive? - felt like I had a Wrangler.
Final product:
Once I get the locking situation figured out, I'm home free.
Not thrilled about the paint, now my car has 3 different shades of white on the driverside .
Old 09-29-2014, 01:31 PM
  #3799
Thanks, Tyler. I do hope so.
Looks fantastic, man...much better. I bet that door incident hurt...
Old 09-29-2014, 01:33 PM
  #3800
The Dumb One
Rockstar21's Avatar
well whattaya know... had the tire shop re-balance the wheels... every single wheel had a staggering less amount of weights and in very different locations.. im wondering if they tried to balance them correctly at all the first time.
threw the wheels back on... smooth sailing up to 120 before laying off it.
I had still ordered the axles spacers the day before just in case. I guess i'll be installing them on a rainy weekend.
thanks for the suggestions and input. glad to be motoring around smoothly again.
civicdrivr (09-29-2014)
Quick Reply: The Official Honda S2000 Thread
