New Sideskirts and custom molded rear bumper!
#41
Originally Posted by mclarenf3387
That rear is not a full bumper replacement. The rear apron was molded to his bumper. Notice the line across the middle of the bumper on this car with the same rear His is molded on so that line doesn't appear.
#42
I went with the saga gauges. Good rep on the evo forums and great for the price. I have been looking for the Defi D series (I really want stand alone gauges), but cannot find them anywhere since they've been discontinued for months! Actually, the D Series for temp, EGT, and a few others are readily available online, but boost is impossible to find. I was going to bite the bullet and get the BF series...but luckily I found these before.
I got the ones with an amber face and lighting....and also in American (Imperial) readings (F/PSI)
Some sample pics:
Functions:
* High Precision, full angle step motor used by the core.
* Full series electronic High-Precision Sensor (+/- 1% Error RATE)
* Max panel (68mm Face), and 60mm cylinder shell design
* Abnormality self-detection warnings function.
* ON/OFF self-sweeping inspection function. On, a slow then fast arm
secondary sweep. Off, a fast then slow arm secondary sweep
* Alert value setting, arm flickering, buzzer sounding function
* Nighttime light source brightness automatic attenuation function.
* Black, heat resistant, anti-UV optical Mask design.
* Self-illumination, high contrast, optical panel lighting design. Use
high-illumination, longer life LED light source.
* Light weight, high heat dissipation, full aluminum alloy precious metal
shell.
* Aluminum alloy seat and dashboard sunscreen (Visor)
* External connection large size warning indicator (optional)
* External control box not required Peak value record play back functions.
50-sec traffic record function
* Traffic record play, pause, rewind function
Let’s break it down, this is what I was going to go with: Boost, Oil Temp, Oil Pressure (will replace stock gauges with these).
Saga 2.0 (from 500whp.com)
Boost…………$175
Temp………….$95
Oil Pressure….. $185
Control Unit……N/A
Shipping:………FREE
TOTAL……..$455 SHIPPED
Now let’s compare with Defi’s BF Series (egauges.com)
Boost…………$230.40
Temp………….$201.60
Oil Pressure….. $269.10
Control Unit……$97.75
Shipping………..FREE
TOTAL……..$798.85
DIFFERENCE of $343.85 that can go into a wideband.
Some sample pics:
Functions:
shell.
Boost…………$175
Temp………….$95
Control Unit……N/A
Shipping:………FREE
Boost…………$230.40
Temp………….$201.60
Shipping………..FREE
TOTAL……..$798.85
Originally Posted by njzprettyboy
i see, what kind of gauges did you go with? i will be needing some soon :spy:
#44
^ blitz is in metric if you don't mind that. The replacement for the Defi D series will be out in September (no controller needed), but the gauges will be in a blue LED.... you should check out the saga's if you need an amber lighting...... great alternative! What kind of car you have?
#45
i have an 00 tlp. i changed to the type s gauges....upon further research, the autometer ultra lite 2 look good...full sweep, good price and they will match the gauges i have somewhat...i really dont want a blue led gauge...would like to stick to white, or amber if necessary. i forgot about the metric/us deal, so the blitz will be a no go...i will also chk out the sagas....
#46
and with saga, you can get em in white or amber.
#47
BoricuaTL
04-08-2016 01:08 PM
Iakonafuji
09-21-2015 02:39 PM
obsessedmotors
09-10-2015 10:49 AM
09-04-2015 08:03 AM
