need help with stick shift
#81
Registered Member
Originally Posted by wonton
I read that double clutching is highly not recommended on the newer cars. well I have a 97 cl and when i shift from 4th to 5th i always feel this grind on my shift knob and when i double clutch then the gear can get into 5th without the grinding. I thought i would be doing more damage if i went to 5th with the grind then double clutching witout the grind. So whats better for my car? i hate the grind but i feel i need to double clutch just so that it wont grind. and when i mean double clutch i sometimes have to press the clutch from 4th then put it into neutral then clutch-cluctch then shift to 5th instead of just one clutch other wise it would have a slight grind. Anyone tell me if this is better?
It is not uncommon for many manual transmissions to have stronger synchronizers in the lower gears than in the higher gear because those are the ones that are most commonly used. What you're describing sounds to me like your 5th gear synchronizers are worn. Either that or the blocker rings are damaged. In order to try to minimize your problem, note the RPM difference between 4th and 5th gear and try to make sure that when you upshift, you are at that RPM for 5th.
As for "..double clutching is highly not recommended on the newer cars", this is not true at all.
#82
like everyone said practice. but "roll in and out" of the throttle when your trying to get used to a stick shift. it's a tough technic at first to get but once you get it like second nature.
SidhuSaaB
05-30-2020 12:40 AM
Joe Avesyan
09-29-2015 03:57 PM
Hines57
09-24-2015 01:58 PM
